SeeYou incorrect waypoint altitudes
Old February 3rd 20, 01:35 AM posted to rec.aviation.soaring
Default SeeYou incorrect waypoint altitudes
On Sunday, February 2, 2020 at 5:26:56 PM UTC-5, Tango Eight wrote:
On Sunday, February 2, 2020 at 4:12:02 PM UTC-5, Darryl Ramm wrote:
Post the actual waypoint data here... it’s just ASCII text. Then we have a chance of seeing what is going on.
Here you go. I created this waypoint about 3 minutes ago. Use whatever tool you like to correlate lat/long/elevation. Actual elevation closer to 1220m....
"Brumley Mountain",,,3650.274N,08206.228W,1091.5m,1,,,,,,
T8
The elevation data built into the map that is within SeeYou is only approximate, as it is presumably based on a "grid elevation model" with limited resolution. The more varied (mountaneous) the local topography, the more inaccurate it would be, since those grid points are farther apart than the actual local slopes. I always enter waypoint elevations "manually", from other sources.
Old February 3rd 20, 02:11 AM posted to rec.aviation.soaring
soaringjac
T8
Cool thanks, that's basically the answer i thought i would get. Pretty much "enter your elevations manually"
LXNAV 8000 OAT Incorrect Deming Gray Soaring 27 December 13th 18 10:05 PM
Seeking help regarding SeeYou waypoint management [email protected] Soaring 2 February 16th 18 01:19 AM
Warning: GPS data incorrect Cheetah236 Instrument Flight Rules 17 September 23rd 05 07:50 AM
SeeYou to LX7000 Waypoint Task Files Ken Kochanski (KK) Soaring 1 May 28th 05 12:22 AM
Incorrect Coastlines..Channel Islands....HELP !!!! Derek Simulators 0 March 23rd 05 11:50 PM
