iGlide
Old February 12th 20, 06:09 AM posted to rec.aviation.soaring
John Foster
Default iGlide
On Tuesday, February 3, 2015 at 12:15:06 PM UTC-7, Ben S wrote:
If you are an Air Avionics iGlide user, please share your evaluation.
Also interested in knowing if you are happy with the sunlight
readability of your iPhone. Is iPhone 6 brighter than iPhone 5?
Is iGlide "secure" enough to use for badge flights here in the US? I have the basic version, which will show your flight path on the map, but doesn't offer much more than that, and am thinking of upgrading to a better version this season. I'll be running it on either an iPhone 6 Plus or an iPhone XS Max.
Old February 12th 20, 05:37 PM posted to rec.aviation.soaring
kinsell
Default iGlide
Nope. From page two of this guide:
https://www.ssa.org/files/member/b&rguide.pdf
SC3 provides for individual countries to approve
off-the-shelf GPS Position Recorders for recording Silver or Gold
Badge flights. As of 15 May2010, no such recorders have been
approved for use in the US.
Old February 12th 20, 10:14 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default iGlide
According to the list at http://www.ukiws.demon.co.uk/GFAC/po..._recorders.htm, which is maintained on the web site of the Chairman of the GNSS Flight Recorder Approval Committee (GFAC) of the International Gliding Commission of FAI, the Soaring Society of America has only approved the "FlyWithCE" and the "FlyWithCE FR300" as position recorders (updated 2018). I've OO'd a number of Silver badge legs with FR300's in Canada.
Old February 12th 20, 10:29 PM posted to rec.aviation.soaring
kinsell
Default iGlide
Looks like the SSA has updated info that matches what you postd. Page 7
of this:
https://www.ssa.org/files/member/B&RGuide_2019.pdf
I'll see if the record keeper can get the obsolete info removed.
Dave
iPad mini/iGlide Ross Whittle Soaring 10 July 28th 14 03:46 AM
Butterfly iGlide App now available in the US Marc - Butterfly Avionics Soaring 25 June 2nd 14 08:10 AM
iglide [email protected] Soaring 1 June 2nd 13 05:07 PM
Announcing the iGlide Software Give-Away! [email protected] Soaring 0 February 25th 13 01:14 PM
Butterfly iGlide Reed von Gal Soaring 4 May 2nd 12 06:00 PM
