Electronic TE compensation, will this work?
Old February 12th 20, 06:46 AM posted to rec.aviation.soaring
Tim Taylor
Default Electronic TE compensation, will this work?
I was told by one of the top Polish pilots that the ASG-29 used by Polish Team was using electronic compensation and they felt it was as good or better than using a TE probe.
Old February 12th 20, 06:54 AM posted to rec.aviation.soaring
soaringjac
That I what I have heard as well, but just don’t know if my leaking TE line acting as a static will give me any reasonably accurate electronic TE compensation
Old February 12th 20, 07:09 AM posted to rec.aviation.soaring
That is extremely unlikely to work as even if the TE tube is completely detached in the fin you have no idea how closely the pressure inside the fin is following true static. The reason for having co-located ports is to minimise differences in time response. Electronic TE compensation requires really accurate pitot and static inputs with simultaneous signals to work properly. If you have them there is a better chance getting it to work (even if not well) by using aft fuselage static ports, which are usually fairly accurate, than a completely unknown source inside the fin.
Lx9070 V80 and Butterfly electronic and pnuemantic compensation Jonathan St. Cloud Soaring 2 May 5th 16 06:47 PM
Electronic versus Pneumatic compensation (conclusions) [email protected] Soaring 0 September 26th 05 05:02 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 4 September 20th 05 06:21 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 2 September 20th 05 06:04 AM
Electronic versus Pneumatic compensation in LX7000 [email protected] Soaring 8 September 15th 05 02:49 AM
