Libelle suitability for beginners
"Not recommended for inexperienced pilots (from Gliding Safety - by
Derek Piggott) The Libelle The beauty of the Libelle is the light weight of the wings and the ease of rigging and derigging. However, it is not for you unless you have already made a few field landings and are an above-average pilot. Although it is nice and easy to fly, the airbrakes are ineffective compared with those on most other machines-an extra 5 knots on the approach and you will be in the far hedge or the next field! Because of these airbrakes, you must be able to side-slip quickly and accurately while using full airbrake on the final approach. With less experienced pilots, it is inevitable that the occasional approach will end up a little high or fast, and only a quick side-slip can prevent an overshoot and an expensive accident. The Libelle suffers a serious loss of performance and buffets badly unless it is flown accurately. This is probably due to the sharply pointed top of the fuselage which causes a breakaway of the airflow if the glider is flown with the slightest slip or skid. Having a short, stubby fin and rudder, the Libelle is also not as directionally stable as later machines, and this makes it more difficult to fly accurately than most other types. In the air it is docile and pleasant to fly, but the poor airbrakes make it unsuitable for an inexperienced pilot. Larger pilots may find the cockpit avery snug fit, as the top is rather narrow." |
On Sunday, February 16, 2020 at 3:30:06 AM UTC-7, Paul T wrote:
"Not recommended for inexperienced pilots (from Gliding Safety - by Derek Piggott) The Libelle The beauty of the Libelle is the light weight of the wings and the ease of rigging and derigging. However, it is not for you unless you have already made a few field landings and are an above-average pilot. Although it is nice and easy to fly, the airbrakes are ineffective compared with those on most other machines-an extra 5 knots on the approach and you will be in the far hedge or the next field! Because of these airbrakes, you must be able to side-slip quickly and accurately while using full airbrake on the final approach. With less experienced pilots, it is inevitable that the occasional approach will end up a little high or fast, and only a quick side-slip can prevent an overshoot and an expensive accident. The Libelle suffers a serious loss of performance and buffets badly unless it is flown accurately. This is probably due to the sharply pointed top of the fuselage which causes a breakaway of the airflow if the glider is flown with the slightest slip or skid. Having a short, stubby fin and rudder, the Libelle is also not as directionally stable as later machines, and this makes it more difficult to fly accurately than most other types. In the air it is docile and pleasant to fly, but the poor airbrakes make it unsuitable for an inexperienced pilot. Larger pilots may find the cockpit avery snug fit, as the top is rather narrow." Many years ago there was a Libelle 201(b?) at the RAFGSA Centre when it was located at RAF Bicester. It was purchased by the Nuffield Trust and also had a plaque stating 150hrs P1 required. Just an observation. Frank Whiteley |
On Mon, 17 Feb 2020 04:08:09 -0800, Frank Whiteley wrote:
Many years ago there was a Libelle 201(b?) at the RAFGSA Centre when it was located at RAF Bicester. It was purchased by the Nuffield Trust and also had a plaque stating 150hrs P1 required. The GSA bought two 201s, built in 1969, arrived in UK 1970. One was flown in the Marfa WGC. I own the other one. -- Martin | martin at Gregorie | gregorie dot org |
Similar Threads | ||||
Std. Libelle vs Club Libelle | [email protected] | Soaring | 10 | August 21st 19 01:00 AM |
Libelle | Ross[_3_] | Soaring | 38 | August 13th 18 08:23 PM |
Libelle 201 canopy | [email protected] | Soaring | 0 | July 4th 16 02:03 PM |
Beginners? | vic20owner | Soaring | 4 | April 28th 09 07:57 PM |
Suitability of Proven Technologies for Defending Against Airborne Terrorism | Yossarian | Military Aviation | 13 | January 8th 04 03:30 AM |
