A couple SSA 2020 convention presentations online...
Old February 28th 20, 06:04 PM posted to rec.aviation.soaring
Dave Nadler
Default A couple SSA 2020 convention presentations online...
On Friday, February 28, 2020 at 12:26:31 PM UTC-5, Stephen Szikora wrote:
I’m seeing a lot of nonsense rationalization here. Any jump is better experience than no jump at all. If nothing else, you will learn to fly the canopy including judgung the flare on landing. Besides, anything you do in life is first practiced in “ideal” conditions (other than a first kiss!)
Nope, a lot of just-plain-nonsense period.
1) With an emergency chute there is no 'flare on landing'.
Most of these chutes pulling both toggles decreases the effective chute
diameter and increases your sink rate (as explained to me by the chute designer).
DO NOT TRY TO FLARE AN EMERGENCY CHUTE.
2) A practice jump will not be with an emergency round chute.
You will get some practice landing but it will be very different...
3) Ground school will include specifics of how to land,
practice landing jumping of a small platform, etc.
Not to mention the mechanics of chute deployment (ie push, not pull).
Please, go get the ground school.
If you want to take a jump, great, but most important is the ground school.
Hope that helps someone out there,
Best Regards, Dave
Old February 28th 20, 06:33 PM posted to rec.aviation.soaring
Dan Marotta
All of what Dave said is true, unless you wear a ram-air rectangular
emergency chute.* For me training at the sky diving club was a great
improvement over my Air Force training since that was geared to round
chutes and I now have a much more maneuverable square chute.
Dave, what do you mean by "push, not pull" on chute deployment? Assuming
you're talking about rip cord use, I'd advise pull straight down with
both hands, not straight out.
Cheers
Best Regards, Dave
Dan, 5J
Old February 28th 20, 07:03 PM posted to rec.aviation.soaring
Cheers
It has always been and still is called pulling, throwing for main parachutes, but a reserve pull is technically a push. Straight out is best combination of strength and splitting the difference of direction of cable housing. Cables are always from the top on sport gear varies on emergency rigs.
The few glider static lines I've seen clipped to the reserve handle, which isn't ideal but will work. A lot of pilot rigs cannot be reasonably modified to pull the pin from the back.
Old February 28th 20, 07:04 PM posted to rec.aviation.soaring
Paul Agnew
There appears to be several schools of thought on egress and deployment of an emergency canopy. Having a plan and rehearsing it regularly is the key, I believe.
I was taught to hold one hand over the D-ring as you egress (if possible) to keep it from flapping around, then grab the D-ring with both hands and punch straight out away from your chest (push/punch vs pull.)
Strong deployment training video - https://youtu.be/ccIta-dO40E
Egress procedures - https://youtu.be/hCldGXL-yYo
Why Practice video - https://youtu.be/G8QcTow7t1M
Strong Parachutes has a static line option.
Paul A.
Jupiter, FL
US: 2020 Pilot Ranking List First Release Online John Leibacher Soaring 2 October 14th 19 02:28 AM
SSA 2018 - Weather Presentations WaltWX[_2_] Soaring 9 March 9th 18 10:47 PM
2016 SSA Convention Presentations Jonathan St. Cloud Soaring 10 February 5th 16 07:55 PM
SSA Speaker Presentations Available ContestID67 Soaring 15 March 12th 07 03:11 AM
SSA eNewsletter with Convention Photos online Jim Skydell Soaring 0 February 24th 05 03:34 AM
