Mini-Winch for FES
Old March 7th 20, 12:20 AM posted to rec.aviation.soaring
Default Mini-Winch for FES
I did watch a live demo of a high-performance jet sustainer glider using an auto tow on a short rope (IIRC, a conventional aerotow rope) to get the sailplane moving fast enough to spin up the jet and get off the ground, at which point (less than 100 feet) the pilot released and climbed away, with plenty of room to land straight ahead on the [hard surface] runway if necessary. Pretty impressive. But no interference with an FES prop to worry about.
I also watched an FES ASW 27 self launch a few years ago from a hard surface runway. Also pretty impressive.
Chip Bearden
JB
Old March 7th 20, 12:36 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Chip Bearden
JB
Chip,
I talked to a JS pilot at Little Rock that does that regularly. He and his wife have it pretty well dialed in.
As I understood the initial discussions, I didn't hear anyone proposing launching with FES running. They would just use the belly hook on the aircraft for the initial launch and then start the FES. Not a bad option if you have enough runway to leave options.
Waiting for spring...
Craig Funston
JN
LX Mini Map Andrew Blanchard Soaring 36 March 8th 14 04:07 AM
Mini-Imp Curt Fennell Home Built 7 November 10th 09 12:43 PM
Best winch metrics - what is the best winch operationally? Bruce Soaring 19 July 19th 09 11:45 AM
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? Bill Daniels Soaring 20 December 27th 04 12:33 AM
Mini Imp Randall Robertson Simulators 3 December 17th 03 05:56 AM
