High Altitude operations (Turbo charge???)
Old July 4th 03, 07:31 PM
Roger Halstead
On Fri, 4 Jul 2003 12:46:52 +0200, "Andre" wrote:
How about RAM air?
Is that even worth considering?
Ram air is not effective at low speeds.
"Andre" wrote in message
I operate off an airfield with a ground elevation of 5327 feet ASL.
Obviously my engine (VW 1835cc with Zenith Carb) feels the altitude
somewhat.
Just somewhat?? :-))
I am thinking....
Would Turbo charging help?
Probably turbonormalizing...It's not as hard on the engine and would
give you take off power at 5300. With a carb it get a bit
complicated as the carb needs to be in a pressure box.
What about an electric blower to increase manifold pressure maybe?
Not familiar with them.
Or how about a NOS system?
NOS needs a rather healthy mixture to begin with (As I recall it helps
with cooling)...I'm not sure about the higher altitude effects.
Roger Halstead (K8RI EN73 & ARRL Life Member)
www.rogerhalstead.com
N833R World's oldest Debonair? (S# CD-2)
Old July 5th 03, 09:06 AM
Paul Millner
with cooling)...
NOS adds a bunch of heat to the engine, so no, it doesn't help with cooling.
Basically, it's a safer way to add oxygen to the incoming air than injecting
oxygen directly... so since the incoming air is now much more oxygen rich,
you need a bunch more fuel, or your mixture will go very lean. In that
sense, it's an alternative to turbocharging... but the NOS bottle will last
a minute or so, OK for one takeoff... then what? :-)
Paul, turbo Cardinal mode
Old July 6th 03, 06:48 AM
Roger Halstead
On Sat, 5 Jul 2003 01:06:22 -0700, "Paul Millner"
with cooling)...
Ummmm..no, that;'s not what I said.
I said it requires a rather healthy mixture which helps with the
cooling (need created by the NOS)
Old July 5th 03, 10:20 AM
Paul Millner
No pressure box required for Marvel Schebler / Precision Airmotive carbs...
just installation of a third throttle shaft seal (did it on my Cardinal when
I turbonormalized it).
Paul
