On Friday, March 20, 2020 at 12:02:00 AM UTC-4, FZ wrote:
There are a few hundred oxygen masks and O2 tanks in a gliding community. Are those of any potential use in a CronaVirus emergency? The short answer is no. Oxygen delivery to the tissues is a result of a complex interaction of the circulatory and respiratory systems. In the case of the Corona virus, the problem is pneumonia which leads to abnormalities in the perfusion/ventilation ratio which no amount of oxygen can correct. Mechanical ventilation and other supportive measures are required. As aside, I would also note that pulse oximeters are great but they are not infallible. There are many reasons why you might get an incorrect reading, especially in the less expensive models. |
On Monday, March 23, 2020 at 7:19:53 AM UTC+13, BobWa43 wrote:
As aside, I would also note that pulse oximeters are great but they are not infallible. There are many reasons why you might get an incorrect reading, especially in the less expensive models. Dr. Dan pointed out in his SoarRX article a few years ago that pulse oximeters are designed to be used sitting quietly in a chair, indoors and on the ground. Sitting in a glider in turbulence, a bit cold, and in bright sunshine is a rather different challenge for a device that relies on light transmission through the finger. |
A pulse oximeter is quite reliable at cold altitudes in turbulence. It does not measure oxygen or hypoxia, but rather some molecule bound to hemoglobin that changes light absorption from 2 different LEDs (one IR, one red). Many units can't differentiate between wavelength absorp of bound carbon monoxide or oxygen, so you could get a reading of 98% but still have carbon monoxide poisoning (there are CO oximeters available) or hypoxemia. In any case, we've gotten off message. If you have a pulse oximeter, you can use it to assist your physician in determining if you should get tested for coronavirus or be hospitalized. When you have real data (temperature, low PO reading) rather than subjectively (under)-reported symptoms, that will almost surely get their attention....it's evidence. If you have minimal training, buy/borrow a cheap stethoscope or amped microphone and have someone listen for "crackling" sounds over both lungs from the back. Fluid buildup sounds like when you scratch your scalp on the hair line. I'll make you a deal; if you can't afford a basic PO ($8-$30), are 70 yrs old or care for such, I will commit to deliver at least 5 units (1/ea) to those making a request. That includes outside North America if AmazonGlobe-worthy. PM me
Someone in respiratory distress usually has impaired breathing, so a nose cannula might not be as helpful as a face mask to get them more oxygen. What might be more helpful is to loan your pulse oximeter to those at higher risk. This would help them decide if they should seek medical treatment, e.g., when ox sat falls below 90% (a common threshold to receive resp support is 88%). The catch is (no pun intended) a hospital is a good place to get pneumonia if you don't already have it. Duster |
You, Sir, are a hero!
I have both a pulse oximeter and a stethoscope and almost 72 years old, but thanks for the offer! On 3/23/2020 10:44 AM, Duster wrote: A pulse oximeter is quite reliable at cold altitudes in turbulence. It does not measure oxygen or hypoxia, but rather some molecule bound to hemoglobin that changes light absorption from 2 different LEDs (one IR, one red). Many units can't differentiate between wavelength absorp of bound carbon monoxide or oxygen, so you could get a reading of 98% but still have carbon monoxide poisoning (there are CO oximeters available) or hypoxemia. In any case, we've gotten off message. If you have a pulse oximeter, you can use it to assist your physician in determining if you should get tested for coronavirus or be hospitalized. When you have real data (temperature, low PO reading) rather than subjectively (under)-reported symptoms, that will almost surely get their attention....it's evidence. If you have minimal training, buy/borrow a cheap stethoscope or amped microphone and have someone listen for "crackling" sounds over both lungs from the back. Fluid buildup sounds like when you scratch your scalp on the hair line. I'll make you a deal; if you can't afford a basic PO ($8-$30), are 70 yrs old or care for such, I will commit to deliver at least 5 units (1/ea) to those making a request. That includes outside North America if AmazonGlobe-worthy. PM me Someone in respiratory distress usually has impaired breathing, so a nose cannula might not be as helpful as a face mask to get them more oxygen. What might be more helpful is to loan your pulse oximeter to those at higher risk. This would help them decide if they should seek medical treatment, e.g., when ox sat falls below 90% (a common threshold to receive resp support is 88%). The catch is (no pun intended) a hospital is a good place to get pneumonia if you don't already have it. Duster -- Dan, 5J |
This link
On Monday, March 23, 2020 at 12:44:30 PM UTC-4, Duster wrote:
A pulse oximeter is quite reliable at cold altitudes in turbulence. Another factor to ponder is the effect of bright sunshine on a device that depends on a red LED. https://www.danlj.org/~danlj/Soaring...-p18-20-22.pdf On the other hand, pulse oximeter ARE designed to work indoors sitting quietly in a chair or resting in bed. |
On Thu, 09 Apr 2020 13:57:46 -0700, son_of_flubber wrote:
On the other hand, pulse oximeter ARE designed to work indoors sitting quietly in a chair or resting in bed. What about units such as those sold by https://www.welluehealth.com/ like their Sleep-U with the electronics on a wrist-band with the sensor clipping on a finger at the end of a flying lead or the Contec CMS50F, where the entire unit is on your wrist. Sure, the Sleep-U is probably unsuitable, though I like its physical setup, which is unlikely to get in the way in the air, while the Contec unit advertises itself as suitable for sports use, though not while exercising, but that probably isn't a problem for us. I'm curious about the medical-grade devices because I bought one of the El-cheapo ($25) Anapulse units 4 years ago before a trip to Scotland in search of wave, which never materialised. Had me doubts about it from the start because its a bulky *******, but seemed work OK when I bought it. I put new batteries in recently to see if it still worked. Turns out that it detects my pulse, but seems to have entirely lost its ability to measure O2 percentage - nothing on the display works apart from the flashing pulse...pulse... bar graph. No O2 percentage or pulse rate are shown. IOW its now a piece of junk. -- Martin | martin at Gregorie | gregorie dot org |
On Thursday, April 9, 2020 at 5:38:04 PM UTC-4, Martin Gregorie wrote:
On Thu, 09 Apr 2020 13:57:46 -0700, son_of_flubber wrote: On the other hand, pulse oximeter ARE designed to work indoors sitting quietly in a chair or resting in bed. What about units such as those sold by https://www.welluehealth.com/ like their Sleep-U with the electronics on a wrist-band with the sensor clipping on a finger at the end of a flying lead Those are nice. Nonin has similar for $$$s. The last time I had hypoxia-induced euphoria in flight, I had to resist a very strong urge to climb higher. Funny how euphoria works. |
On the other hand, pulse oximeter ARE designed to work indoors sitting quietly in a chair or resting in bed. You can test this pretty easily, of course. I have 4 different models, only one of which went into error mode when moved real close to an incandescent bulb. It first must capture your HR via arterial pulse, then will read out saturation. Not as accurate as measuring arterial SaO2 via blood draw. You can find units that will send an alert if your SpO2 goes below a set %. If you want to fly with one, the finger units are too cumbersome when handling the stick, so you could consider buying an earlobe PO that isn't. https://heymedsupply.com/clip-pulse-...0aAi5DEALw_wcB https://erj.ersjournals.com/content/48/suppl_60/PA3702 |
On Thursday, April 9, 2020 at 6:32:47 PM UTC-4, Duster wrote:
You can test this pretty easily, of course. Testing is good. One of the reasons I find the Logging Pulse-Oximeters attractive is that I might gradually (over multiple flights) gain confidence in the unit by reviewing that the log captured expected O2 saturation vs. altitude (post-flight review). These units also log heart rate. An exercise physiologist told me that heartrate commonly increases in parallel with altitude induced reduction in O2 saturation. Physiology is complicated. |
GPS Nav question .... | Ron Gleason | Soaring | 16 | August 17th 11 02:59 PM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
CH question | Frode Berg | Simulators | 4 | July 18th 03 10:04 AM |
