The Decline of Soaring Awards
Old March 24th 20, 09:41 PM posted to rec.aviation.soaring
Dan Marotta
Default The Decline of Soaring Awards
You could do like me and take off with a case of the flu (back in the
'80s), sit miserably in the cockpit for 5 1/2 hours, and land to find
that you'd not screwed the nut tightly enough on the barograph drum and
it did not rotate.
Or you could save that 5 hour duration flight for your first of many
Gold Distance/Diamond Goal attempts.Â* It'll likely take you 5 hours or
more in early attempts, anyway.Â* Good luck!
On 3/24/2020 3:29 PM, son_of_flubber wrote:
Maybe I'm the only pilot put off the entire badge system by the 5 hour duration flight. I'd surely get dull and bored after ~3.5 hours and flying dull increases risk. The benefit that I'd subjectively assign to a longer flight does not offset the risk that I subjectively perceive.
Even though I'm already an old guy, my endurance in the air has slowly increased over a decade of flying to about 3 hours. For a younger pilot, 5 hour duration flight might be more a matter of skillfully finding lift, and less a matter of raw endurance.
Dan, 5J
2011 Performance Soaring Seminar and Colorado Soaring Awards BravoCharlie Soaring 0 December 30th 10 04:06 PM
Colorado Soaring Seminar and Awards Banquet Frank Whiteley Soaring 2 February 24th 07 05:33 AM
Colorado Soaring Pilots/SSA Governor 2007 Seminar and 2006 Soaring Awards Banquet Frank Whiteley Soaring 0 February 15th 07 04:52 PM
2005 Colorado Soaring Seminar and Awards Dinner Frank Whiteley Soaring 0 October 24th 05 06:33 AM
Soaring's decline SSA club poll Craig Freeman Soaring 4 May 4th 04 01:07 PM
