Oudie gear warning?
Old March 31st 20, 08:57 PM posted to rec.aviation.soaring
Scott Williams[_2_]
Default Oudie gear warning?
On Tuesday, March 31, 2020 at 2:27:02 PM UTC-5, Scott Williams wrote:
On Tuesday, March 31, 2020 at 12:57:38 PM UTC-5, MNLou wrote:
You are welcome!
I am one of many who exhorted Naviter to add an altitude based gear warning. It was included in an update, I believe, at the beginning of last year.
It is based on your AGL - about 200m / 660 ft. It knows where you are and it knows the ground level where you took off. If A = B, you get the warning.
It also has a gear warning at altitude to make sure you are "gear up". I can't remember what the logic is behind that. Circling I think.
Anyway, a very useful reminder in the pattern.
Lou
Is this function added to an IGC with an update?
Scott
Got it, If only I would read the posts in order,
Thanks for the heads up!!
Scott
Old April 1st 20, 05:32 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Where in the settings screens is the gear warning? I don’t have a page that says Profile.
DC
Old April 1st 20, 05:41 PM posted to rec.aviation.soaring
Scott Williams[_2_]
DC
turn on, see you mobile, menu button, settings, next, next, next, misc,
Middle of screen, "before landing... check landing gear
Oudie IGC version 9.17.00 on mine,
Good luck
Scott
Old April 1st 20, 06:05 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Does this work with a Oudie 2?
DC
Old April 1st 20, 07:03 PM posted to rec.aviation.soaring
Marc V
DC
Yes, the post above by Scott is exactly what you do to turn that feature on for the Oudie 2... I have it set on mine and it works great, but regarding the post above from Lou, mine does not give a "gear up" notification and I don't see anywhere to enable that feature, if someone has more info on that, please post ... Thanks, Marc
Old April 1st 20, 07:26 PM posted to rec.aviation.soaring
Scott Williams[_2_]
DC
I have a newer oudie IGC, and the second original oudie made. Serial #2 and the landing gear check is on both after an update.
Scott
Old April 1st 20, 08:20 PM posted to rec.aviation.soaring
Dennis Cavagnaro
Got it Thx
Mine is checked for landing gear
Now what exactly will happen if I forget my gear during a landing? Will I see a message or hear a sound?
DC
Old April 1st 20, 09:34 PM posted to rec.aviation.soaring
Scott Williams[_2_]
On Wednesday, April 1, 2020 at 2:20:17 PM UTC-5, Dennis Cavagnaro wrote:
Got it Thx
DC
while I have not flown since this update, the previous posts by others seem to indicate that if I get to an altitude of 660feet in close proximity to my launch gps location, the oudie will announce or have a popup window something like "check landing gear"
I suppose this may or may not be the case, maybe it compares altitude and ground elevation? be interesting to see how it works!
Scott
Cessna 172 gear warning Paul Kassel Owning 0 March 27th 17 04:29 PM
Gear Warning Gadget Guy Soaring 118 November 30th 05 10:43 PM
Gear Warning Gordon Schubert Soaring 11 November 22nd 05 03:27 AM
Gear Warning Gordon Schubert Soaring 0 November 18th 05 08:22 PM
gear warning plus K.P. Termaat Soaring 0 September 8th 03 08:33 AM
