On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote:
Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. |
Well then, I must be really confused.Â* If the switch was a BREAK before
MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J |
![]() Inrush current seems to be a big bugaboo Seem to have time to kill. Lets try for some numbers. Here's the fuse data sheet https://www.littelfuse.com/~/media/a..._datasheet.pdf I use a 7.5 amp fuse on each battery. Assuming the battery full and empty voltages differ by 1 volt. The current with both batteries on the bus also depends on the wiring resistance. If there is 0.1 ohms, then the fuse current is 10 amps. at 25C, that could blow it in a few seconds. The I2T rating for the fuse is 60. That is measured over 8 milliseconds. So I think that says the fuse will blow quickly with 86 amps. Seems like unless you have really good wiring or a big charge difference, quickly switching make before break should be ok. That matches your experience with the Stemme and also the Walmart run at the recent contest where the switch was left with both batteries on the bus for a while. |
On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote:
Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't.. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom |
On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote:
On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. |
On Wednesday, April 8, 2020 at 9:04:00 AM UTC-7, jfitch wrote:
On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote: On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. All decent suggestions. I can deduce the series resistance from the time constant of the waveforms, which is about 200 mohm. This includes the battery internal resistance, wiring resistance, and capacitor ESR. So forget about "hundreds of amps" flowing. Any more measurements will have to wait until I get out to the airport again, but including a series resistor of a few ohms, depending upon you total panel current drain, won't hurt. I did look up the NKK switch you mentioned and that is definitely not the one used in my panel. Tom |
On Wednesday, April 8, 2020 at 2:51:22 PM UTC-7, 2G wrote:
On Wednesday, April 8, 2020 at 9:04:00 AM UTC-7, jfitch wrote: On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote: On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately.. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. All decent suggestions. I can deduce the series resistance from the time constant of the waveforms, which is about 200 mohm. This includes the battery internal resistance, wiring resistance, and capacitor ESR. So forget about "hundreds of amps" flowing. Any more measurements will have to wait until I get out to the airport again, but including a series resistor of a few ohms, depending upon you total panel current drain, won't hurt. I did look up the NKK switch you mentioned and that is definitely not the one used in my panel. Tom What switch did Schleicher use on your 31? Mine originally had that NKK switch, searching for a replacement I could not find any with better specs than the NKK MRT. There are many different manufacturers of an equivalent MRY106, but all seemed to mirror the spec. |
On Friday, April 10, 2020 at 4:55:12 PM UTC-7, jfitch wrote:
On Wednesday, April 8, 2020 at 2:51:22 PM UTC-7, 2G wrote: On Wednesday, April 8, 2020 at 9:04:00 AM UTC-7, jfitch wrote: On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote: On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath.. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. All decent suggestions. I can deduce the series resistance from the time constant of the waveforms, which is about 200 mohm. This includes the battery internal resistance, wiring resistance, and capacitor ESR. So forget about "hundreds of amps" flowing. Any more measurements will have to wait until I get out to the airport again, but including a series resistor of a few ohms, depending upon you total panel current drain, won't hurt. I did look up the NKK switch you mentioned and that is definitely not the one used in my panel. Tom What switch did Schleicher use on your 31? Mine originally had that NKK switch, searching for a replacement I could not find any with better specs than the NKK MRT. There are many different manufacturers of an equivalent MRY106, but all seemed to mirror the spec. I don't know what they used, but it is definitely not the NKK model you posted. Tom |
On Wednesday, April 8, 2020 at 9:04:00 AM UTC-7, jfitch wrote: On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote: On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately.. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. All decent suggestions. I can deduce the series resistance from the time constant of the waveforms, which is about 200 mohm. This includes the battery internal resistance, wiring resistance, and capacitor ESR. So forget about "hundreds of amps" flowing. Any more measurements will have to wait until I get out to the airport again, but including a series resistor of a few ohms, depending upon you total panel current drain, won't hurt. I did look up the NKK switch you mentioned and that is definitely not the one used in my panel. Tom 200 mohms seems like it would still send a lot of current through the switch, at least briefly. 70A? |
On Friday, April 10, 2020 at 4:58:04 PM UTC-7, jfitch wrote:
On Wednesday, April 8, 2020 at 2:51:22 PM UTC-7, 2G wrote: On Wednesday, April 8, 2020 at 9:04:00 AM UTC-7, jfitch wrote: On Tuesday, April 7, 2020 at 6:19:36 PM UTC-7, 2G wrote: On Tuesday, April 7, 2020 at 9:32:07 AM UTC-7, Dan Marotta wrote: Well then, I must be really confused.Â* If the switch was a BREAK before MAKE, the equipment would be momentarily without power.Â* Some devices can survive that, perhaps with internal capacitance, but others will lose power momentarily.Â* This may or may not be an issue. Inrush current seems to be a big bugaboo to some people and, in some cases it is, but what is the time constant associated with the inrush?Â* How much current are we talking about and for how long? People keep talking about the high battery "charging" the low battery during the milliseconds that they are in parallel. Theoretically, yes, practically, hogwash.Â* The heat required to blow a fuse or burn a wire does not rise instantaneously; there's counter EMF to reduce the current...Â* So many details that meant a bunch when you were taking a test back in school but, practically speaking, don't mean squat in this case. So, switch your batteries and protect your circuits however you wish.Â* I'll stick with my make before break switches.Â* I'll even report back when something fails due to their use, but don't hold your breath.. On 4/6/2020 10:43 PM, 2G wrote: On Monday, April 6, 2020 at 11:23:21 AM UTC-7, Dan Marotta wrote: Tom, Isn't the rotary panel switch in a Schleicher glider a make before break? OK, I'll stop posting to this thread now.Â* My solution, which I've relied on for years without ever losing a connection or blowing a fuse seems to be too simple to be acceptable. On 4/5/2020 7:45 PM, 2G wrote: The glider, an ASH 31 Mi, is already wired with a battery selector switch for the avionics, and is the way to go. You definitely don't want to parallel Pb and LFP battery's accidentally. Tom -- Dan, 5J Dan, Think about it: if it were MAKE before BREAK I wouldn't have had this problem and sure as hell wouldn't post a solution to a non-existent problem. -- Dan, 5J If my power switch was a break-before-make (also called a shorting switch) I would not have had a problem and certainly wouldn't have posted a fix to a non-existent problem. But it isn't. It was easier for me to put in a capacitor than replace the switch. It also protects against any switch bounce while switching. People seem to be overly concerned with inrush current. High inrush current would only happen if there were a substantial amount of power supply capacitance in the LX9000 that needed charging. If that were the case it would handle a millisecond battery switch over without any problem, but it doesn't. Also, there is no inrush current during battery switching as the caps in the LX9000 are already charged. Tom The inrush current to the LX9000 is not the issue, nor is switching between batteries while the cap is charged. The issue (if there is one) is the inrush to the discharged cap when you first turn on the mains. It is a pretty complex and loosely speced system. Caps are very loosely spec'd, as are battery internal resistance, switch resistance, and of course the wiring in each glider is unique. That's why I suggested measuring it. When he switch is turned on, it will arc and bounce because that is what switches do. How much is the question. Quite easy to measure, hard to calculate accurately. It is quite possible that the step impedance in the system limits the inrush to an acceptable value - but you don't know what you don't know. It would have been easy for LX to spec a switching power supply with enough residual energy to cover, say 20 ms switching interval. Apparently they did not. Or perhaps they are using linear supplies, in which case the garbage can is the appropriate resting place. I'll second Dave's suggestion of using one large battery bank instead of seperate small ones. It is better for battery life too. (In the 31 the second battery may be the starting battery so that isn't practical). Or better still, use a higher capacity LFP - my small instrument battery will power the panel for around 12 hours. All decent suggestions. I can deduce the series resistance from the time constant of the waveforms, which is about 200 mohm. This includes the battery internal resistance, wiring resistance, and capacitor ESR. So forget about "hundreds of amps" flowing. Any more measurements will have to wait until I get out to the airport again, but including a series resistor of a few ohms, depending upon you total panel current drain, won't hurt. I did look up the NKK switch you mentioned and that is definitely not the one used in my panel. Tom 200 mohms seems like it would still send a lot of current through the switch, at least briefly. 70A? I modeled it in Spice, included series inductance, and saw peak currents in the range of 10-20A for a few msec. Tom |
Airplane tears off winglet on jet bridge | a[_3_] | Piloting | 0 | July 8th 10 08:06 PM |
Tears in the eyes, - 1 attachment | RobG | Aviation Photos | 4 | June 17th 08 10:51 AM |
The Tears Of Finding The Truth | algaga | Piloting | 9 | January 3rd 08 04:33 PM |
“Particularly on May 19th”— with the tears of his father | X98 | Military Aviation | 0 | May 18th 04 10:34 AM |
