I’m our club’s A&P but haven’t seen it yet. His tow bar broke and glider rolled into the back of his vehicle. It may be repairable but I’m covering our bases just in case it’s not.
Larry Ruggiero |
At 12:08 13 April 2020, Larry Ruggiero wrote:
I=E2=80=99m our club=E2=80=99s A&P but haven=E2=80=99t seen it yet. His tow= bar broke and glider rolled into the back of his vehicle. It may be repair= able but I=E2=80=99m covering our bases just in case it=E2=80=99s not. Larry Ruggiero The problem with rudders is mass balance. Any work done on the trailing edge adds weight at the max distance from the pivot point so you need to be able to add a lot more forward of the pivot. Typically 12 " to the Trailing edge 2"to the leading edge. So for a 2oz repair you are trying to find space for 12oz of lead. |
The rudder on my LS4 had a repair to the trailing edge. The rudder was refinished in polyurethane rather than gelcoat and that helped bring it within the weight and balance limits (which are very specific re trailing edge weight.)
That’s good to know, thanks.
On Mon, 13 Apr 2020 05:08:40 -0700, Larry Ruggiero wrote:
I’m our club’s A&P but haven’t seen it yet. His tow bar broke and glider rolled into the back of his vehicle. It may be repairable but I’m covering our bases just in case it’s not. Larry Ruggiero I had exactly the same thing happen to an ASW-20. Fortunately, a replacement rudder was available fron the UK Schleicher agent. The cause of the accident was a remarkably badly engineered towbar mount on the tail dolly: it must have been an accident waiting to happen for several years. Photos and analysis he https://www.gregorie.org/gliding/dolly/index.html I hope this page stops anybody else having a smashed rudder caused by a similar failure. -- Martin | martin at Gregorie | gregorie dot org |
WTB SGS 1-35 Rudder | Karen | Soaring | 0 | April 4th 10 04:29 AM |
Right Rudder | Ol Shy & Bashful | Piloting | 19 | August 16th 08 04:38 AM |
WTD. SGS 2-33 Rudder | [email protected] | Soaring | 0 | December 20th 06 04:31 AM |
c-152 rudder??? | houstondan | Owning | 39 | December 21st 04 09:21 PM |
c-152 rudder??? | houstondan | Owning | 28 | December 15th 04 09:55 PM |
