Looking for a serviceable LS4 rudder
Old April 12th 20, 05:42 PM posted to rec.aviation.soaring
Larry Ruggiero
Default Looking for a serviceable LS4 rudder
One of our club members might have need of one.
Larry Ruggiero
Carolina Soaring Assoc, Spartanburg SC
Old April 13th 20, 10:32 AM posted to rec.aviation.soaring
Curious: What is wrong with the current one? It would have to be some really interesting damage to be unrepairable.
Old April 13th 20, 01:08 PM posted to rec.aviation.soaring
Larry Ruggiero
I’m our club’s A&P but haven’t seen it yet. His tow bar broke and glider rolled into the back of his vehicle. It may be repairable but I’m covering our bases just in case it’s not.
Larry Ruggiero
Old April 13th 20, 01:46 PM posted to rec.aviation.soaring
Jonathon May
At 12:08 13 April 2020, Larry Ruggiero wrote:
I=E2=80=99m our club=E2=80=99s A&P but
haven=E2=80=99t seen it yet. His
tow=
may be
repair=
able but I=E2=80=99m covering our bases just in case
it=E2=80=99s not.
Larry Ruggiero
The problem with rudders is mass balance.
Any work done on the trailing edge adds weight at the max
distance from the pivot point so you need to be able to add a
lot more forward of the pivot.
Typically 12 " to the Trailing edge 2"to the leading edge.
So for a 2oz repair you are trying to find space for 12oz of
lead.
Old April 13th 20, 02:29 PM posted to rec.aviation.soaring
Stephen Szikora
The rudder on my LS4 had a repair to the trailing edge. The rudder was refinished in polyurethane rather than gelcoat and that helped bring it within the weight and balance limits (which are very specific re trailing edge weight.)
Old April 13th 20, 02:50 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Larry Ruggiero
I had exactly the same thing happen to an ASW-20. Fortunately, a
replacement rudder was available fron the UK Schleicher agent.
The cause of the accident was a remarkably badly engineered towbar mount
on the tail dolly: it must have been an accident waiting to happen for
several years. Photos and analysis he
https://www.gregorie.org/gliding/dolly/index.html
I hope this page stops anybody else having a smashed rudder caused by a
similar failure.
Martin | martin at
Gregorie | gregorie dot org
Old April 13th 20, 04:59 PM posted to rec.aviation.soaring
Larry Ruggiero
That’s good to know, thanks.
WTB SGS 1-35 Rudder Karen Soaring 0 April 4th 10 04:29 AM
Right Rudder Ol Shy & Bashful Piloting 19 August 16th 08 04:38 AM
WTD. SGS 2-33 Rudder [email protected] Soaring 0 December 20th 06 04:31 AM
c-152 rudder??? houstondan Owning 39 December 21st 04 09:21 PM
c-152 rudder??? houstondan Owning 28 December 15th 04 09:55 PM
