On Monday, April 13, 2020 at 2:42:54 PM UTC-7, jld wrote:
Taurus is a nice glider. Very roomy, nice side by side configuration when flying with friends or for instruction. It is very well build. Typical WL with 2 pilots is 38-40 kg/m2 The cruise performance is similar to lightly loaded standard class. The climb performance is more like a heavy loaded standard. It would be an excellent 2 seater with a wing more specifically designed for soaring.With modern 18m wings would make it a fantastic 2 seater. I know the 503 version. I have never flown the electro but it has too limited battery capacity for my need. It would need at least 10 kwh batteries for comfortable operation. Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. Tom |
2G wrote on 4/13/2020 5:54 PM:
On Monday, April 13, 2020 at 2:42:54 PM UTC-7, jld wrote: Taurus is a nice glider. Very roomy, nice side by side configuration when flying with friends or for instruction. It is very well build. Typical WL with 2 pilots is 38-40 kg/m2 The cruise performance is similar to lightly loaded standard class. The climb performance is more like a heavy loaded standard. It would be an excellent 2 seater with a wing more specifically designed for soaring.With modern 18m wings would make it a fantastic 2 seater. I know the 503 version. I have never flown the electro but it has too limited battery capacity for my need. It would need at least 10 kwh batteries for comfortable operation. Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. The Williams case is one I considered before choosing the Jeta. On the map, it looks like about 20 NM the to hills to the west. Most electric gliders have that much range; eg, the Gp15 Jeta with the large battery could launch, motor the 20 miles, and still have about 55-60 NM range left. The small battery would only have 30-35 nn range left, though. The AS34 would have about 45 NM range left after motoring from Williams to the hills; the miniLak FES also about 45 NM, maybe more. Everyone knows the gasoline powered self-launchers all have powered ranges that exceed the best electric range, but that is irrelevant for most of the people buying an electric glider. They want to eliminate the tow and dramatically increase their chances of getting home, and the electric glider gives them what they want. If you dream of flights that require hours of power, or airfields that don't have electricity, you must stay with gasoline. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Monday, April 13, 2020 at 7:48:51 PM UTC-7, Eric Greenwell wrote:
2G wrote on 4/13/2020 5:54 PM: On Monday, April 13, 2020 at 2:42:54 PM UTC-7, jld wrote: Taurus is a nice glider. Very roomy, nice side by side configuration when flying with friends or for instruction. It is very well build. Typical WL with 2 pilots is 38-40 kg/m2 The cruise performance is similar to lightly loaded standard class. The climb performance is more like a heavy loaded standard. It would be an excellent 2 seater with a wing more specifically designed for soaring.With modern 18m wings would make it a fantastic 2 seater. I know the 503 version. I have never flown the electro but it has too limited battery capacity for my need. It would need at least 10 kwh batteries for comfortable operation. Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. The Williams case is one I considered before choosing the Jeta. On the map, it looks like about 20 NM the to hills to the west. Most electric gliders have that much range; eg, the Gp15 Jeta with the large battery could launch, motor the 20 miles, and still have about 55-60 NM range left. The small battery would only have 30-35 nn range left, though. The AS34 would have about 45 NM range left after motoring from Williams to the hills; the miniLak FES also about 45 NM, maybe more. Everyone knows the gasoline powered self-launchers all have powered ranges that exceed the best electric range, but that is irrelevant for most of the people buying an electric glider. They want to eliminate the tow and dramatically increase their chances of getting home, and the electric glider gives them what they want. If you dream of flights that require hours of power, or airfields that don't have electricity, you must stay with gasoline. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The launch has to be 4kft, min and the distance is more like 22nm. And what if the lift is further into the hills? And what if you have a headwind? And if you don't connect you don't have a glide back to Williams. The same thing goes for Minden. The margins are either non-existent or too thin for my tastes. Of course, you could always get a tow. In fact, save the cost of a FES and fly a pure glider. Tom |
2G wrote on 4/13/2020 9:19 PM:
On Monday, April 13, 2020 at 7:48:51 PM UTC-7, Eric Greenwell wrote: 2G wrote on 4/13/2020 5:54 PM: Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. The Williams case is one I considered before choosing the Jeta. On the map, it looks like about 20 NM the to hills to the west. Most electric gliders have that much range; eg, the Gp15 Jeta with the large battery could launch, motor the 20 miles, and still have about 55-60 NM range left. The small battery would only have 30-35 nn range left, though. The AS34 would have about 45 NM range left after motoring from Williams to the hills; the miniLak FES also about 45 NM, maybe more. Everyone knows the gasoline powered self-launchers all have powered ranges that exceed the best electric range, but that is irrelevant for most of the people buying an electric glider. They want to eliminate the tow and dramatically increase their chances of getting home, and the electric glider gives them what they want. If you dream of flights that require hours of power, or airfields that don't have electricity, you must stay with gasoline. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The launch has to be 4kft, min and the distance is more like 22nm. And what if the lift is further into the hills? And what if you have a headwind? And if you don't connect you don't have a glide back to Williams. The same thing goes for Minden. The margins are either non-existent or too thin for my tastes. Of course, you could always get a tow. In fact, save the cost of a FES and fly a pure glider. There are several ways to deal with your worst case scenario: 1) don't fly on a difficult day 2) take a 5 mile, 4000' tow, leaving plenty of reserve to return to Williams 3) accept the possibility you might have to land at Antelope Valley 4) own a GP15: motor the 25 NM to 4000', and have 45-50 NM range left. For 4), there no worries about getting back to Williams with that 10 knot tail wind, 2500 agl height where you gave up trying to connect. The AS34 and miniLak should be OK, too. Connecting with difficult lift will be easier in the electrics: run at low power while searching around until you find something, turn it off, and 5 seconds later you are flying a glider again. Maybe not quite so easy in the AS34, with it's more conventional pylon. The fact is, most people do not fly where a lot of range is required, and most are currently flying gliders with ZERO powered range (pure gliders). To these pilots, the range of current electric gliders is very appealing. Think about it: if maximum range was the crucial factor in selecting a motorglider, we'd all be flying Stemme S10s! Right, Dan? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
True dat, Eric.
For me the Stemme's range is only used to reposition to another soaring location as I don't have a trailer.* That money is better spent on other toys.* The big down side to the Stemme for me is it's limitation to paved runways.* I know a lot of them are flown off of grass fields, but there are none of those where I fly.* Gravel is also pretty much out of the question, again for me, due to the cost of a propeller. On 4/14/2020 7:17 AM, Eric Greenwell wrote: 2G wrote on 4/13/2020 9:19 PM: On Monday, April 13, 2020 at 7:48:51 PM UTC-7, Eric Greenwell wrote: 2G wrote on 4/13/2020 5:54 PM: Electric gliders won't cut it when you have to motor a was to the lift, like at Williams. Once, Jim Leedy and I motored from KRLD to Mt. Rainier in his Taifun to get to the wave lift. The Williams case is one I considered before choosing the Jeta. On the map, it looks like about 20 NM the to hills to the west. Most electric gliders have that much range; eg, the Gp15 Jeta with the large battery could launch, motor the 20 miles, and still have about 55-60 NM range left. The small battery would only have 30-35 nn range left, though. The AS34 would have about 45 NM range left after motoring from Williams to the hills; the miniLak FES also about 45 NM, maybe more. Everyone knows the gasoline powered self-launchers all have powered ranges that exceed the best electric range, but that is irrelevant for most of the people buying an electric glider. They want to eliminate the tow and dramatically increase their chances of getting home, and the electric glider gives them what they want. If you dream of flights that require hours of power, or airfields that don't have electricity, you must stay with gasoline. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 The launch has to be 4kft, min and the distance is more like 22nm. And what if the lift is further into the hills? And what if you have a headwind? And if you don't connect you don't have a glide back to Williams. The same thing goes for Minden. The margins are either non-existent or too thin for my tastes. Of course, you could always get a tow. In fact, save the cost of a FES and fly a pure glider. There are several ways to deal with your worst case scenario: 1) don't fly on a difficult day 2) take a 5 mile, 4000' tow, leaving plenty of reserve to return to Williams 3) accept the possibility you might have to land at Antelope Valley 4) own a GP15: motor the 25 NM to 4000', and have 45-50 NM range left. For 4), there no worries about getting back to Williams with that 10 knot tail wind, 2500 agl height where you gave up trying to connect. The AS34 and miniLak should be OK, too. Connecting with difficult lift will be easier in the electrics: run at low power while searching around until you find something, turn it off, and 5 seconds later you are flying a glider again. Maybe not quite so easy in the AS34, with it's more conventional pylon. The fact is, most people do not fly where a lot of range is required, and most are currently flying gliders with ZERO powered range (pure gliders). To these pilots, the range of current electric gliders is very appealing. Think about it: if maximum range was the crucial factor in selecting a motorglider, we'd all be flying Stemme S10s! Right, Dan? -- Dan, 5J |
Jump starting solo motor glider with automobile 12 volt starter | [email protected] | Soaring | 2 | April 2nd 15 07:25 PM |
America Wills Justice as Freedom for Our Stays The Rightardstates 'No Public Option! No Public Option!' | Daryl | Naval Aviation | 0 | May 14th 12 04:40 AM |
Electric Duct Fan (EDF) Self-Launch Glider? | CLewis95 | Soaring | 26 | January 20th 11 06:27 PM |
Electric Glider | Mal | Soaring | 20 | November 2nd 05 10:46 PM |
Toronto Area Glider Pilot Ground School starting Tuesday September 20 | Ulf | Soaring | 0 | September 11th 05 04:59 PM |
