On Tuesday, April 14, 2020 at 1:00:45 AM UTC-4, 2G wrote:
On Monday, April 13, 2020 at 9:49:26 PM UTC-7, wrote: On Monday, April 13, 2020 at 9:37:18 AM UTC-7, Duster wrote: Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. There are 4 Electro's in the USA and about a dozen Rotax powered. I've flown a Rotax-powered one for about 10 years, but only have a few flights in an Electro. It flies like an older generation, lightly loaded 15 meter ship. Lots of fun soaring, but not for unhandicapped competition or records. The company's objective in designing the electric version was to have it achieve the same performance, at the same price, as the gas powered. I understand that the electric will climb slightly faster (bigger prop, IIRC), and the price probably isn't that much more than the Rotax version. I think the empty weight is similar, though the batteries consume a lot of space. But the run time, like all of the electrics, is the big difference. I think Pipistrel used to advertise 6,000' of climb on a charge, though that was a while back and they probably have better numbers today. (The Rotax powered version has a max fuel capacity of something like 14 gallons (with dual tanks). I have only the single tank configuration, but have never had "range anxiety" with probably over an hour of run time, should it be needed.. (Typical flight has 5-7 minutes for initial launch and another 5-10 minutes of run time if I need a relight, and I would guess that the Electros have a similar profile.)) The solar trailer for the Electro is quite cool. You can park at an unelectrified gliderport, and the sun charges the battery array in the trailer. Then you hook-up your Taurus overnight and recharge the on-board batteries. Rinse and repeat. Pipistrel has a big lead over others in actual, in-the-field application and improvements vs. projected and theoretical systems. If they elected to market their systems in a higher-performance sailplane I think they would have a superior product. For VFR cross country flight the FAA requires you to have a 30 minute fuel reserve. Note that electric gliders don't even have 30 minutes of run time, let alone a reserve. All this discussion assumes running the battery totally flat - no reserve WHATSOEVER and perfect battery performance (no degradation for temperature or age). This is an unacceptable level of even token, lip-service safety. GIVE ME A BREAK! Tom - I guess I should never venture out flying my motorless (pure) glider, since it has no fuel reserve at all! :-) |
Jump starting solo motor glider with automobile 12 volt starter | [email protected] | Soaring | 2 | April 2nd 15 07:25 PM |
America Wills Justice as Freedom for Our Stays The Rightardstates 'No Public Option! No Public Option!' | Daryl | Naval Aviation | 0 | May 14th 12 04:40 AM |
Electric Duct Fan (EDF) Self-Launch Glider? | CLewis95 | Soaring | 26 | January 20th 11 06:27 PM |
Electric Glider | Mal | Soaring | 20 | November 2nd 05 10:46 PM |
Toronto Area Glider Pilot Ground School starting Tuesday September 20 | Ulf | Soaring | 0 | September 11th 05 04:59 PM |
