#111
On Monday, April 13, 2020 at 9:00:45 PM UTC-8, 2G wrote:
On Monday, April 13, 2020 at 9:49:26 PM UTC-7, wrote: On Monday, April 13, 2020 at 9:37:18 AM UTC-7, Duster wrote: Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. There are 4 Electro's in the USA and about a dozen Rotax powered. I've flown a Rotax-powered one for about 10 years, but only have a few flights in an Electro. It flies like an older generation, lightly loaded 15 meter ship. Lots of fun soaring, but not for unhandicapped competition or records. The company's objective in designing the electric version was to have it achieve the same performance, at the same price, as the gas powered. I understand that the electric will climb slightly faster (bigger prop, IIRC), and the price probably isn't that much more than the Rotax version. I think the empty weight is similar, though the batteries consume a lot of space. But the run time, like all of the electrics, is the big difference. I think Pipistrel used to advertise 6,000' of climb on a charge, though that was a while back and they probably have better numbers today. (The Rotax powered version has a max fuel capacity of something like 14 gallons (with dual tanks). I have only the single tank configuration, but have never had "range anxiety" with probably over an hour of run time, should it be needed.. (Typical flight has 5-7 minutes for initial launch and another 5-10 minutes of run time if I need a relight, and I would guess that the Electros have a similar profile.)) The solar trailer for the Electro is quite cool. You can park at an unelectrified gliderport, and the sun charges the battery array in the trailer. Then you hook-up your Taurus overnight and recharge the on-board batteries. Rinse and repeat. Pipistrel has a big lead over others in actual, in-the-field application and improvements vs. projected and theoretical systems. If they elected to market their systems in a higher-performance sailplane I think they would have a superior product. For VFR cross country flight the FAA requires you to have a 30 minute fuel reserve. Note that electric gliders don't even have 30 minutes of run time, let alone a reserve. All this discussion assumes running the battery totally flat - no reserve WHATSOEVER and perfect battery performance (no degradation for temperature or age). This is an unacceptable level of even token, lip-service safety. GIVE ME A BREAK! Tom The 30 minutes is a flight planning requirement for Airplanes....Helicopters 20 minutes. For the glider category there is no such flight planning requirement. |
#112
Thanks to those providing opinions/experiences with the Taurus Electro. I asked my local dealer if Pipistrel was planning on a longer wing. His reply was "The planform is a more forward sweep with a slight increase in span. it will be a 4 piece wing with the outer sections easily removable to permit hangaring in European smaller T-hangars. L/D 43:1 or slightly better. The wing will be plug and play with all current Taurus Electro G2.5 fuselages. Not sure if it will be plug and play with Taurus M fuselages.There is no estimated in service date as of yet."
#113
I see that the same circular arguments and dogmatic thinking exists in the
wider world of gliding as it does in UK gliding. On the topic of powered gliders, one side will argue that this is the way the market is heading and that one of the benefits is faster turnaround and fewer people required for launches. The other side will engage in circular logic and argue that it is safer to fly aircraft without engines as using an engine introduces the possibility of engine failure. My opinion: Do as you like. Buy a powered glider, preferably an SSDR, if that's what you want. If your club is headed up by old-school dogmatic individuals who won't 'allow' you to fly from the site, find somewhere better. |
#114
I'll describe the requirements I am trying to satisfy for me with my project. I suspect this is much like many but obviously not all.
1) The glider needs to be practical for one person to assemble in a reasonable period of time without heavy lifting. This means a ship that is not more than about 100 lb heavier than it's similar non powered counterpart. 2) Self launch capability with acceptable margins. I am using a takeoff distance of 900 feet, off pavement, and climb rate of at least 400 feet per minute. Ability to fly off unpaved surface knowing takeoff distance will increase. 3) Battery capacity for a 2000 foot launch and 2500 feet reserve to save and get home or to a safe airport. 4)System must have sufficient motor cooling to allow high power settings long enough to get to a safe altitude before power reduction. 5) Practical charging. In my project the battery can be removed for charging away from the glider. 6) Existing proven airframe. This is my "Wednesday afternoon" ship for when I have no tow pilot. FWIW UH In response to UH criteria above I would like to chime in with the AMS-Flight Carat meets all of the criteria except for being electric and how happy I am with my AMS-Flight Carat. Decent performance launching in the summers out of Moriarty, Parowan and Eli. This will be my 3rd season with her and still love it. Factory is still taking orders. |
#115
LOV2AV8 wrote on 4/14/2020 1:41 PM:
I'll describe the requirements I am trying to satisfy for me with my project. I suspect this is much like many but obviously not all. 1) The glider needs to be practical for one person to assemble in a reasonable period of time without heavy lifting. This means a ship that is not more than about 100 lb heavier than it's similar non powered counterpart. 2) Self launch capability with acceptable margins. I am using a takeoff distance of 900 feet, off pavement, and climb rate of at least 400 feet per minute. Ability to fly off unpaved surface knowing takeoff distance will increase. 3) Battery capacity for a 2000 foot launch and 2500 feet reserve to save and get home or to a safe airport. 4)System must have sufficient motor cooling to allow high power settings long enough to get to a safe altitude before power reduction. 5) Practical charging. In my project the battery can be removed for charging away from the glider. 6) Existing proven airframe. This is my "Wednesday afternoon" ship for when I have no tow pilot. FWIW UH In response to UH criteria above I would like to chime in with the AMS-Flight Carat meets all of the criteria except for being electric and how happy I am with my AMS-Flight Carat. Decent performance launching in the summers out of Moriarty, Parowan and Eli. This will be my 3rd season with her and still love it. Factory is still taking orders. I've often wondered why the Carat was not more popular, as it seemed like good compromise. What is the cost for a new one delivered to the US? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
#116
On Tuesday, April 14, 2020 at 10:16:57 AM UTC-7, Dan Marotta wrote:
The pure glider never has any fuel reserve (molecules or electrons), yet they go cross country all of the time.Â* Are you suggesting that flying cross country in a pure glider is illegal? On 4/13/2020 11:00 PM, 2G wrote: On Monday, April 13, 2020 at 9:49:26 PM UTC-7, wrote: On Monday, April 13, 2020 at 9:37:18 AM UTC-7, Duster wrote: Any opinions on the Taurus Electro? Side-by-side, pylon, self-launch, trailer option for solar array charging, etc. They claim the profile of the cockpit/fuselage acts like a lifting body. There are 4 Electro's in the USA and about a dozen Rotax powered. I've flown a Rotax-powered one for about 10 years, but only have a few flights in an Electro. It flies like an older generation, lightly loaded 15 meter ship. Lots of fun soaring, but not for unhandicapped competition or records. The company's objective in designing the electric version was to have it achieve the same performance, at the same price, as the gas powered. I understand that the electric will climb slightly faster (bigger prop, IIRC), and the price probably isn't that much more than the Rotax version. I think the empty weight is similar, though the batteries consume a lot of space.. But the run time, like all of the electrics, is the big difference. I think Pipistrel used to advertise 6,000' of climb on a charge, though that was a while back and they probably have better numbers today. (The Rotax powered version has a max fuel capacity of something like 14 gallons (with dual tanks). I have only the single tank configuration, but have never had "range anxiety" with probably over an hour of run time, should it be needed. (Typical flight has 5-7 minutes for initial launch and another 5-10 minutes of run time if I need a relight, and I would guess that the Electros have a similar profile.)) The solar trailer for the Electro is quite cool. You can park at an unelectrified gliderport, and the sun charges the battery array in the trailer. Then you hook-up your Taurus overnight and recharge the on-board batteries. Rinse and repeat. Pipistrel has a big lead over others in actual, in-the-field application and improvements vs. projected and theoretical systems. If they elected to market their systems in a higher-performance sailplane I think they would have a superior product. For VFR cross country flight the FAA requires you to have a 30 minute fuel reserve. Note that electric gliders don't even have 30 minutes of run time, let alone a reserve. All this discussion assumes running the battery totally flat - no reserve WHATSOEVER and perfect battery performance (no degradation for temperature or age). This is an unacceptable level of even token, lip-service safety. GIVE ME A BREAK! Tom -- Dan, 5J When you are flying a motorglider the FAA considers it to be a glider and fuel reserves don't apply. The point is that planning launches or retrieves w/o factoring in reserves is a bad idea. You will NEVER get the promised performance for a variety of reasons. It would be like planning a final glide using the max L/D. Tom |
#117
You're right, Tom.
I recall the time we got low over an airport about 60 nm from home. Rather than land, I started the engine and discovered that we were low on fuel.Â* Rather than give up, I climbed straight ahead under power, watching the glide back to the airport, until I had a certain glide home.Â* I had enough fuel, though not enough to make me comfortable.Â* I now won't take off with less than about 3/8 of a tank, or about 12 gallons. On 4/14/2020 7:38 PM, 2G wrote: When you are flying a motorglider the FAA considers it to be a glider and fuel reserves don't apply. The point is that planning launches or retrieves w/o factoring in reserves is a bad idea. You will NEVER get the promised performance for a variety of reasons. It would be like planning a final glide using the max L/D. Tom -- Dan, 5J |
#118
Dan Marotta wrote on 4/15/2020 2:30 PM:
You're right, Tom. I recall the time we got low over an airport about 60 nm from home. Rather than land, I started the engine and discovered that we were low on fuel.* Rather than give up, I climbed straight ahead under power, watching the glide back to the airport, until I had a certain glide home.* I had enough fuel, though not enough to make me comfortable.* I now won't take off with less than about 3/8 of a tank, or about 12 gallons. On 4/14/2020 7:38 PM, 2G wrote: When you are flying a motorglider the FAA considers it to be a glider and fuel reserves don't apply. The point is that planning launches or retrieves w/o factoring in reserves is a bad idea. You will NEVER get the promised performance for a variety of reasons. It would be like planning a final glide using the max L/D. Tom Contest pilots often start their final glide even lower than a max L/D glide, when they know the conditions on the way to the airport have some rising air. Uvalde is well-known for that kind of planning. I don't think it is always necessary to factor in reserves, either, as long as you have a safe place to land if it doesn't work out. That seems to be what Dan did: not enough fuel to provide an adequate reserve, but a bail-out plan if he didn't get lucky. I do agree with your point in general, however, which applies to all glider flying, powered or not. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
#119
On Wednesday, April 15, 2020 at 2:30:39 PM UTC-7, Dan Marotta wrote:
You're right, Tom. I recall the time we got low over an airport about 60 nm from home. Rather than land, I started the engine and discovered that we were low on fuel.Â* Rather than give up, I climbed straight ahead under power, watching the glide back to the airport, until I had a certain glide home.Â* I had enough fuel, though not enough to make me comfortable.Â* I now won't take off with less than about 3/8 of a tank, or about 12 gallons. On 4/14/2020 7:38 PM, 2G wrote: When you are flying a motorglider the FAA considers it to be a glider and fuel reserves don't apply. The point is that planning launches or retrieves w/o factoring in reserves is a bad idea. You will NEVER get the promised performance for a variety of reasons. It would be like planning a final glide using the max L/D. Tom -- Dan, 5J While the FAA considers motorgliders to be gliders, engines don't give a damn: they want fuel to run. PERIOD. Launching with a near empty tank is just plain stupid. |
#120
On Wednesday, April 15, 2020 at 4:10:28 PM UTC-7, Eric Greenwell wrote:
Dan Marotta wrote on 4/15/2020 2:30 PM: You're right, Tom. I recall the time we got low over an airport about 60 nm from home. Rather than land, I started the engine and discovered that we were low on fuel.Â* Rather than give up, I climbed straight ahead under power, watching the glide back to the airport, until I had a certain glide home.Â* I had enough fuel, though not enough to make me comfortable.Â* I now won't take off with less than about 3/8 of a tank, or about 12 gallons. On 4/14/2020 7:38 PM, 2G wrote: When you are flying a motorglider the FAA considers it to be a glider and fuel reserves don't apply. The point is that planning launches or retrieves w/o factoring in reserves is a bad idea. You will NEVER get the promised performance for a variety of reasons. It would be like planning a final glide using the max L/D. Tom Contest pilots often start their final glide even lower than a max L/D glide, when they know the conditions on the way to the airport have some rising air. Uvalde is well-known for that kind of planning. I don't think it is always necessary to factor in reserves, either, as long as you have a safe place to land if it doesn't work out. That seems to be what Dan did: not enough fuel to provide an adequate reserve, but a bail-out plan if he didn't get lucky. I do agree with your point in general, however, which applies to all glider flying, powered or not. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 I don't worry about what "contest" pilots do - they are trying to win a contest. I would NEVER plan a glide at best L/D where the consequences are a crash - and neither should you or anybody else. |
Jump starting solo motor glider with automobile 12 volt starter | [email protected] | Soaring | 2 | April 2nd 15 07:25 PM |
America Wills Justice as Freedom for Our Stays The Rightardstates 'No Public Option! No Public Option!' | Daryl | Naval Aviation | 0 | May 14th 12 04:40 AM |
Electric Duct Fan (EDF) Self-Launch Glider? | CLewis95 | Soaring | 26 | January 20th 11 06:27 PM |
Electric Glider | Mal | Soaring | 20 | November 2nd 05 10:46 PM |
Toronto Area Glider Pilot Ground School starting Tuesday September 20 | Ulf | Soaring | 0 | September 11th 05 04:59 PM |
