Minimum acceptable self-launch climb rate
Old April 26th 20, 11:44 PM posted to rec.aviation.soaring
Kenz Dale
Default Minimum acceptable self-launch climb rate
Thanks, Dan, you knocked it out of the park with this answer.
CS 22 - Certification Specifications for Sailplanes and Powered Sailplanes - has standards.
"CS 22.51 Take-off
(a) For a powered sailplane the take-off distance at maximum weight and in zero wind, from rest to attaining a height of 15 m must be determined and must not exceed 500 m when taking off from a dry, level, hard surface. In demonstration of the take-off distance, the powered sailplane must be allowed to reach the selected speed promptly after lifting off and this speed must be maintained throughout the climb.
(b) The selected speed must not be less than;
(1) 1·3 VS1, or
(2) any lesser speed, not less than 1·15 VS1, that is shown to be safe under all reasonably expected operating conditions, including turbulence and complete engine failure.
CS 22.65 Climb
(a) For a powered sailplane the time for climb from leaving the ground up to 360 m above the field must not exceed four minutes with:
(1) not more than take-off power;
(2) landing gear retracted;
(3) wing-flaps in take-off position;
(4) cowl flaps (if any) in the position used in the cooling tests.
(b) For self-sustaining powered sailplanes, the maximum altitude that can be sustained must be determined."
https://www.easa.europa.eu/sites/def...S-22_Amendment 1 revised.pdf
Old April 27th 20, 02:37 AM posted to rec.aviation.soaring
Dan Marotta
My Stemme gets 800 ft/min at 8,000' density altitude but it's
turbocharged. :-D If I'm repositioning for a safari or such, I climb
straight up to 18,000' MSL and cruise at 140 KTAS.Â* But it sure isn't a
fingertip light ship to fly. :-(
"CS 22.51 Take-off
(1) 1·3 VS1, or
CS 22.65 Climb
Dan, 5J
Minimum rates of climb/descent for VFR Mxsmanic Piloting 113 February 17th 08 06:42 AM
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
