Minimum acceptable self-launch climb rate
Old April 29th 20, 09:53 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Minimum acceptable self-launch climb rate
waremark wrote on 4/29/2020 1:03 PM:
"You can simulate an engine failure during a launch at a safe altitude. I've done
at 2000'-3000':
- set your flight recorder to 1 second intervals, to get the best flight trace data
- at altitude, configure the glider for takeoff: gear down, flaps normally used
- line up on a long, straight road or similar
- establish a steady, full power climb at your normal climb speed
- climb for 200' or so, then set throttle to idle, and do a 180 degree turn,
lining up on the that road
- repeat the test, but this time, turn the ignition off, then turn as before"
You cannot do that last bit in an Arcus M - when you turn the engine off it commences the prop lowering process. In the ASH 26 I had before I did try this sort of stuff and would have been confident of a turn back from 200 foot. I think it would also be fine in the Arcus. However from my club's small grass field I am vulnerable to a potentially damaging off field arrival from about 50 foot to about 200 foot.
The only relevant power failure I have had was in the Arcus just after lift off, at 5 foot or less off the ground. There was a drive belt failure, and the glider plonked down rather heavily on the ground - instead of the lift component of the engine power I now had no power and a high drag prop mast.. Happily no damage done other than by the flailing drive belt(s). Since then I have tried to stay just above the ground until achieving say 55 knots.
In the Arcus while best climb rate is supposed to be about 52 knots, you can climb quite a lot faster without over-revving and without much sacrifice of climb rate - and there is a rev limiter which you could only hit in level flight, probably about 90 knots.
That 50' to 200' "window of discomfort" is disturbing, but would be still be there
when using a climb speed a few knots higher than the "speed for max climb rate"
that Steve M is looking for. It does sound like the Arcus M would be much more
suited to Steve's flying than the N3D, unfortunately at a much greater cost.
  #32
Old April 29th 20, 10:15 PM posted to rec.aviation.soaring
at 2000'-3000':
The only relevant power failure I have had was in the Arcus just after lift off, at 5 foot or less off the ground. There was a drive belt failure, and the glider plonked down rather heavily on the ground - instead of the lift component of the engine power I now had no power and a high drag prop mast. Happily no damage done other than by the flailing drive belt(s). Since then I have tried to stay just above the ground until achieving say 55 knots.
I'm curious why motorglider pilots don't practice that at 200ft agl, as all student pilots do on aerotows as part of normal training.
  #33
Old April 30th 20, 12:29 AM posted to rec.aviation.soaring
FYI- the L/D of the Arcus M with mast extended and engine not running is approximately 13:1 with a sink rate in level flight of 495 fpm. Do you want to try a turn back to the runway with those numbers?
  #34
Old April 30th 20, 01:07 AM posted to rec.aviation.soaring
Ron Gleason
Come on Mark, 1980 vintage hang glider performance. Not an issue, could probably do a 360!
  #35
Old April 30th 20, 01:36 AM posted to rec.aviation.soaring
Straight from the Schempp-Hirth Arcus M Flight Manual. Dave Nadler calls it "Plummet Mode."
When we converted four Arcus M gliders to jet power, we measured 38:1 with the engine extended but not running.
  #37
Old April 30th 20, 02:17 PM posted to rec.aviation.soaring
38:1 -- is that with the jet engine extended, gear retracted?
Yes- gear retracted, engine extended but not running.
The biggest cause of the terrible performance of the Arcus M with the prop and pylon up is the fact that the two huge 6 ft. long doors remain open and the big engine bay and the rest of the hole in the fuselage gives all those draggy little air molecules a place to run around before finally jumping out.
The ASH-26E appears to have smaller doors and a smaller engine bay, and possibly less drag because of this.
And for those of you who still don't believe, 495 fpm is 8.25 feet per second. 60 knots is 101.27 feet per second. 101.27/8.25 = 12.275.
  #38
Old April 30th 20, 03:05 PM posted to rec.aviation.soaring
Dave Walsh[_2_]
with the prop
remain open
and=
all
thos=
jumping
out.
engine bay, and
pos=
per
seco=
nd. 60 knots is 101.27 feet per second. 101.27/8.25 =3D
12.275.
Just out of interest the electric 20m Antares20E which has a
"book" L/D of 56:1 does 30:1, engine out and prop windmilling,
gear retracted. The main engine doors are closed when the engine
is erected. The prop is stopped by the "electronics", if it throws a
wobbly the pilot has no way to stop the prop. The prop is 2m
diameter, two blades. The engine is direct drive to the prop so the
engine would have had to seize up for the prop to be stopped &
erected. The circuit & landing are a bit of a non event, rather like a
K13.
I've never experienced "plummet mode" in an Arcus; the
DG400/800 plummet rather well.
Dave Walsh
  #39
Old April 30th 20, 03:21 PM posted to rec.aviation.soaring
jld
L/D with pylon out highly depends on IAS.
On a Ventus 2 CM with gear up, failed spindle drive, prop stopped, I was getting ~18 L/D at 50 kts. This was dropping fast below 15 L/D when accelerating above 55 kts.
  #40
Old April 30th 20, 03:48 PM posted to rec.aviation.soaring
Jonathan St. Cloud
with the prop
remain open
and=
all
thos=
jumping
out.
engine bay, and
pos=
per
seco=
12.275.
K13.
Dave Walsh
Someone please correct me if I am wrong but I believe only 4 Arcus E's were sold and one of those was written off in an accident?
Minimum rates of climb/descent for VFR Mxsmanic Piloting 113 February 17th 08 06:42 AM
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Minimum rate of climb or descent Aaron Kahn Instrument Flight Rules 3 July 25th 03 03:22 PM
