Wing wheel from Craggy Aero
Old May 1st 20, 12:38 AM posted to rec.aviation.soaring
2G
Default Wing wheel from Craggy Aero
I wanted to replace the Cobra wing wheel I had been using because 1) it goes with the ASH26e I have for sale and 2) the tire scrubs the tarmac as I go around turns, putting stress on the wing. I ordered the CA WingWheel from Craggy Aero because the wheel swivels with the direction of travel:
http://www.craggyaero.com/ground_handling.htm
And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it.
Tom
Old May 1st 20, 03:20 AM posted to rec.aviation.soaring
Andrzej Kobus
Tom
The best wheel I have had is the one from MM Fabrication. Very sturdy, well fitting and does not stress ailerons.
Old May 1st 20, 06:31 AM posted to rec.aviation.soaring
2G
And the length is adjustable which helps greatly for storage. It is also has a spring shock absorber that the Cobra wheel does not have. I tried it out today and towed my ASH31Mi (with the 21M tips) around the Richland, WA airport (KRLD). The wing wheel worked great and put no stress on the wing.. The Cobra wing wheel would bend inwards as the tire was dragged sideways in a turn - the CA wing wheel tracked perfectly and was always in a vertical position. The height of wheel was more than adequate to keep the wing tip above obstructions (taxiway markers and signs). This version also has improved straps over the earlier design. Fabrication of all components is excellent - no thin walled aluminum tubing, for example. The tire is not pneumatic, so it can't go flat. It is wide enough so it will not drop into pavement cracks. It is well worth the additional cost over the Cobra wing wheel - I was always holding my breath when I used it.
Tom
That wheel does not swivel, so it will suffer from the same scrubbing problem that the Cobra wheel has.
Old May 1st 20, 12:09 PM posted to rec.aviation.soaring
Andrzej Kobus
Tom
Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer!
Old May 1st 20, 05:08 PM posted to rec.aviation.soaring
2G
Tom
Not true, the other wheels have scrubbing problems because they are flimsy and they fit poorly. I tow on concrete all the time, never have had a problem. I had all kinds of wheels before and they were all terrible, especially on concrete. I had the same concern as you before I bought the MM Fabrication wheel and I asked Mark to modify the wheel to include swivel. He said to try it they way he makes it and it works perfectly. He uses precise wing airfoil to manufacture the wheel, so each wheel fits only one glider type.. This is why it sits on the wing perfectly and it does not move at all. I am a very happy customer!
While the clamping of the Mark's wing wheel is better than Cobra's, scrubbing is inevitable because of the geometry of towing. I actually tried to buy Mark's wing wheel and even mailed him a check after he complained about others cancelling orders, but he still didn't want to make it. The CA wing wheel works better, is adjustable, has a shock absorber, is well made and is cheaper. And it was in stock.
Tom
Old May 1st 20, 06:36 PM posted to rec.aviation.soaring
Not exactly true. Tom inquired about a wing wheel, wing cuffs and a tow bar.. I explained that tow bars were out of stock and wing wheels and wing cuffs are custom fabricated. Because of my involvement in another project, I informed him that delivery times were questionable, if at all possible. I don't recall receiving a check at all.
As far as "scrubbing" being "inevitable," also not true. Over 300 of my wing wheels are out there, and if properly positioned and aligned with the direction of travel, they track well.
But you can't convince Tom, since he is always right.
Old May 1st 20, 08:31 PM posted to rec.aviation.soaring
I second that opinion. The MM Fabrication wing wheel for my Libelle is built like a tank, and fits like a glove. I don't have a scrubbing problem either. My MM wing wheel and tow bar are some of the best money I have spent on gliding equipment.
Doug
Old May 2nd 20, 04:47 AM posted to rec.aviation.soaring
2G
On Friday, May 1, 2020 at 10:36:38 AM UTC-7, wrote:
Not exactly true. Tom inquired about a wing wheel, wing cuffs and a tow bar. I explained that tow bars were out of stock and wing wheels and wing cuffs are custom fabricated. Because of my involvement in another project, I informed him that delivery times were questionable, if at all possible. I don't recall receiving a check at all.
Come on, Mark. I sent you the check - I've got a copy of it - along with a purchase order, which I also have a copy of. You said you could make more money on another project. I said, "Ok, then shred the check and forget it, no hard feelings."
Scrubbing is what happens when you turn a tire on a radius. I have seen it happen with my Cobra wing wheel. If the wing is long enough and the turning radius tight enough, you get to the limit where the wing wheel is at the exact center of the turn and is being turned around a point. This scrubbing pushes the wing wheel sideways and is very obvious with the Cobra wing wheel. It's not me that's right, it's physics that's right.
Tom
Old May 2nd 20, 08:09 AM posted to rec.aviation.soaring
I am a convert to the swivelling wing wheel - for me the IMI one which is beautifully designed and has a decent sized wheel unlike some others.
There are 2 factors that can make any fixed wheel twist or rock. Firstly the tight turn or on the spot rotation when if the wheel is not precisely longitudinally aligned it will twist badly. Secondly, if the wheel is not absolutely vertical then there is a castoring effect as you tow straight. This pulls the wheel in or out. On rough ground with unballasted wings it can self-correct with each bounce of the wing and wobble along. When ballasted, especially on smooth grippy hard surfaces, the cuff can't twisted sufficiently to dent the wing skin or damage a control surface - both of which I have had over the years with three different wing dolly designs on three different gliders.
A broad rigid custom fitted cuff masks the underlying concept flaw but a good swivelling wheel eliminates it. The worst designs have heavy legs, a fixed wheels, and a generic cuffs with spongy padding.
Old May 2nd 20, 09:51 AM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
But you can't convince Tom, since he is always right.[/i][/color]
Tom[/quote]
Go back to school Tom.
Craggy Aero Navigation unit 4 sale [email protected] Soaring 0 March 21st 14 08:18 AM
Brand New Craggy Aero Ultimate LE for sale [email protected] Soaring 0 December 27th 13 11:12 AM
Big thanks to Richard at Craggy Aero Bruce Barnard[_2_] Soaring 4 February 15th 12 03:55 PM
Craggy Aero Ultimate & SeeYou Mobile Richard[_1_] Soaring 2 October 29th 08 06:45 PM
Craggy Aero Introduces the Ultimate Flight System Richard[_1_] Soaring 18 August 14th 08 04:56 AM
