Ben:
The best advice I ever got on the subject was, "If you are thinking about dumping the water, DUMP IT!" And that has remained pretty good advice. The question you have to ask yourself is "why am I thinking about dumping water?" Is it because the last few thermals were weaker? (Dump it). Or, "I am perilously low and I need to float to a save?" (Dump it) Or, "The guys without water are seriously out climbing me and running away" (you guessed it - start dumping). I think the only time to hold on to the water (when doubts emerge about its helpfulness) is when you are reasonably certain that you will get back to better conditions. This may be because you have started early in the morning before it cooks up or when you have drifted down to the weak area of the height band and can climb back up to the strong lift. But it's not a science - it's an educated guess about the future. ROY |
I understand...BUT...the leading pilots in Condor simulator racing are all, as best I can tell, holding onto their water as long as possible, i.e. they aren't leaning toward the conservative side. This is probably because it is virtual racing, and no one is going to break a real glider (or their real bodies) if they make a water mistake. If I dump water and they don't, they invariably beat me in the cruise segments and especially in final glide..
That's why I was looking for rules of thumb and formulas when racing, as opposed to cross-country. Ben |
On Saturday, May 16, 2020 at 9:09:25 AM UTC-7, Charles Ethridge wrote:
I understand...BUT...the leading pilots in Condor simulator racing are all, as best I can tell, holding onto their water as long as possible, i.e. they aren't leaning toward the conservative side. This is probably because it is virtual racing, and no one is going to break a real glider (or their real bodies) if they make a water mistake. If I dump water and they don't, they invariably beat me in the cruise segments and especially in final glide. That's why I was looking for rules of thumb and formulas when racing, as opposed to cross-country. Ben While Condor is an Excellent tool, many people, fly different on Condor than they would or could in real life! |
On Sat, 16 May 2020 09:09:22 -0700 (PDT), Charles Ethridge
wrote: I understand...BUT...the leading pilots in Condor simulator racing are all, as best I can tell, holding onto their water as long as possible, i.e. they aren't leaning toward the conservative side. This is probably because it is virtual racing, and no one is going to break a real glider (or their real bodies) if they make a water mistake. If I dump water and they don't, they invariably beat me in the cruise segments and especially in final glide. That's why I was looking for rules of thumb and formulas when racing, as opposed to cross-country. Ben Condor is great, but its thermal model isn't correct at low altitudes (thermals don't get a lot weaker or tighter close to the ground), therefore there's hardly any penalty if you get very low. I once got a 6 kts thermal after (!) an outlanding when I bounced back into the air... and completed my 150 miles task. Cheers Andreas |
Discus CS wing water dump seats (seals) | [email protected] | Soaring | 5 | August 6th 19 01:54 PM |
SZD 55 water dump valve sticking. | Mark B[_2_] | Soaring | 0 | February 1st 19 10:15 PM |
ASG-29 water dump rates | Jonathan St. Cloud | Soaring | 9 | June 10th 16 04:37 PM |
Chapstick In Water Dump Valves | Dan Marotta | Soaring | 4 | June 21st 12 01:16 AM |
Water dump valve rotary seal | Bill Daniels | Soaring | 6 | May 10th 04 11:02 AM |
