Solo 2350 Un-Pickle procedure
Old May 23rd 20, 02:32 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Solo 2350 Un-Pickle procedure
I was looking through the aircraft Maintenance manual and the solo 2350 engine manual, both have the same procedure for long term storage (over 2 months). Neither has the "un-pickle" procedure. Was looking for guidance from those knowledgable.
Thank you in advance,
Jon
Old May 23rd 20, 04:43 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Fri, 22 May 2020 18:32:39 -0700 (PDT), "Jonathan St. Cloud"
Jon
I can tell you what I do. 20 years flying a Ventus cT turbo with the
2350 engine.
Flying in N Texas, I remove the engine every fall and reinstall every
spring (6 months in - 6 months out).
1. I remove and clean the decompression valves.
2. I remove and clean the spark plugs.
3. I replace the lower portion of the fuel line that runs from the
impulse fuel pump up to the line tee. It always hardens over the 6
months of summer operation.
4. Following re-installation, I lube the prop.
No issues in 20 years of this process. I used to put in new plugs
every year and drain and use new gas (100LL), but don't bother now.
1-2 hours to remove, 3-4 hours to reinstall. Engine only, lift
mechanism left in place.
Bob
Old May 23rd 20, 08:51 AM posted to rec.aviation.soaring
Tango Whisky
I'm flying a Ventus cM for the 15th season. In fall, I do the maintenance as per the manual, put 5 ml oil in each carburettor, turn the prop a couple of times, seal the carburettors with plastic bags and tape off the exhaust outlet.
In spring, I take off the plastic bags and the tape and fire up the engine.
Boost performance of Solo 2350 turbo (sustainer) [email protected] Soaring 10 January 4th 19 12:37 PM
WTB solo 2350 engine [email protected] Soaring 1 May 27th 15 10:56 PM
Oil for Solo 2350 MNLou Soaring 3 May 26th 15 08:27 AM
solo 2350 engines Rocket Soaring 3 January 24th 07 03:58 PM
Help with Solo 2350 Limus Soaring 2 May 3rd 06 02:15 AM
