DG-303 spar issues - puchase?
Old May 23rd 20, 05:39 PM posted to rec.aviation.soaring
Paul[_11_]
Default DG-303 spar issues - puchase?
On Saturday, May 23, 2020 at 12:32:56 PM UTC-4, John Good wrote:
I owned a DG-300 for a good while, and really liked it - many memorable flights including the 1000-km task during the Regional contest at New Castle VA. I'd recommend it highly.
Here are two notable details worthy of attention, that seem not to be common knowledge among owners:
The gear-retract handle is a knob on the end of the actuator rod that rotates outboard to lock the gear up or down. Its rotation is restrained by a friction washer. Over time, this wears / compresses, so the friction decreases. It can reach the point where the knob rotates freely, making the gear somewhat prone to collapse, especially when landing on rough ground. The friction is easily adjusted by a nut that compresses the friction washer. Owners should be aware that a freely rotating knob is a problem waiting to happen - but it seems only a minority understand this issue.
The spoiler panels are often just a bit too high at their outboard end. This means that when you pull up and the wings flex, the spoiler box pushes the end of the spoiler up a few mm above the wing surface. You thus suffer a small performance loss each time you pull into a thermal, and perhaps when you thermal in a steep bank.
The problem is easy to detect: Pull the divebrakes open and inspect the bottom of the box at its outboard end. If it's been pushing on the spoiler panel, you'll see a black mark caused by aluminum rubbing on fiberglass. In my experience, about 60% of DG-300 gliders exhibit this (I have no info on the DG-303). The solution is fairly simple: shave a small wedge of aluminum off the outboard bottom edge of the panel - perhaps 6mm at the end, tapering to nothing over a distance of 80mm.
John, really great information, thank you!
Paul
Old May 26th 20, 07:40 AM posted to rec.aviation.soaring
Eric
The gear-retract handle is a knob on the end of the actuator rod that rotates outboard to lock the gear up or down. Its rotation is restrained by a friction washer. Over time, this wears / compresses, so the friction decreases. It can reach the point where the knob rotates freely, making the gear somewhat prone to collapse, especially when landing on rough ground. The friction is easily adjusted by a nut that compresses the friction washer.. Owners should be aware that a freely rotating knob is a problem waiting to happen - but it seems only a minority understand this issue.
Paul
DG also offers a retrofit kit that forces the brakes torque tube in the outboard position. Technical note TN 359/22 (service contract required)
https://www.dg-flugzeugbau.de/en/dow...-22/8FW25e.pdf
Old May 26th 20, 10:11 AM posted to rec.aviation.soaring
When I go try DG 400, the DG300 gear fix was already performed on the bird. Simple elegant solution that I would highly recommend.
Kevin
92
Got a problem with my wooden spar. Lou Home Built 3 June 4th 08 01:45 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
Spar workshop CD and DVD available mat Redsell Soaring 0 May 6th 04 03:52 PM
spar varnish Lou Parker Home Built 5 May 3rd 04 04:19 PM
Spar gluing Lou Parker Home Built 26 November 21st 03 08:29 PM
