![]() How robust are the pressure sensors? I assume if the electronics are not switched on that there is no danger of damaging them even if some idiot blows into a probe or port. The datasheet say that the proof pressure is 35psi.. about 2.3 bar... So not foolproof, but I bet that neither the mechanical ASI, nor the electronic calculator will do better... The port is just under the nose... If you land into a swamp or a very soft field other parts of the plane will be clogged and need cleaning... It's not impossible that a bug crashes precisely there... But we have no MCAS to worry about if the AoA fails. |
AOA indicator | Jonathan St. Cloud | Soaring | 116 | May 2nd 16 05:53 PM |
Need VOR indicator | blanche cohen | Owning | 5 | July 23rd 07 04:37 AM |
Need VOR indicator | blanche cohen | Instrument Flight Rules | 5 | July 23rd 07 04:37 AM |
Which Indicator for KLN-89b | N7936T | Instrument Flight Rules | 3 | June 1st 06 06:50 PM |
Non TSO'd IFR indicator | Paul Lee | Home Built | 1 | September 19th 03 07:00 PM |
