K2 battery endurance
Old June 2nd 20, 07:10 PM posted to rec.aviation.soaring
Dan Marotta
Default K2 battery endurance
My Bioenno batteries worked just fine for several years.Â* Just sayin'...
On 6/2/2020 10:26 AM, Richard Pfiffner wrote:
On Monday, June 1, 2020 at 9:46:09 PM UTC-7, kinsell wrote:
On 5/25/20 9:47 PM, Eric Greenwell wrote:
2G wrote on 5/25/2020 2:20 PM:
On Wednesday, May 13, 2020 at 8:00:09 PM UTC-7, kinsell wrote:
The BMS in all LFPs may not have the same functionality regarding
balancing but at the very least they should start/stop accepting
charge appropriately.
It matters not what you think should happen, the truth is not all LFP
batteries have a BMS, and of those that do, not all of them protect from
over and under voltage.
Which LFP batteries don't have a BMS?
Tom
The "powersports" (ie, for engine starting) LFP don't always have a BMS.
A motorglider pilot might be tempted to use one for the engine, for
example.
StarkPower had a series of batteries aimed at motorcycles that they were
quite open about not having a BMS. Unfortunately they're in Chapter 7
now and the website is gone.
More commonly, some batteries with BMS don't have over and under voltage
protection. Richard Pfiffner one time was testing batteries, and his
vendor shipped 24 volt chargers accidentally for 12 volt batteries. All
the white stuff leaked out of the battery. Some electrical genius on
R.A.S. (don't remember which one) declared that they really had
overvoltage protection, but 24 volts just wasn't enough to trigger it.
One of our fellow Schleicher motorglider pilots had an LFP, left the
transponder on, and ruined the battery. A 15-20 AH battery intended as
a starter battery can easily find it's way into other applications. You
may have read about the ASG 32 mi that got fried when the solar
controller malfunctioned, drained the battery, and got quite hot when
charged from another charger. Did it have a BMS? Doesn't really matter.
Dave
The problem batteries were Bioenno Batteries.
Richard
Dan, 5J
  #32
Old June 2nd 20, 08:52 PM posted to rec.aviation.soaring
Tom
example.
Dave
Richard
Dan, 5J
The BMS boards must be changing over the years. I don't expect a company like Bioenno could keep getting the same model BMS over time, even if they tried. Not at a reasonable price anyway. You just get whatever is being churned out in large numbers by a few Chinese factories at the moment. If you want to know whether your specific battery has overvoltage cutoff, try it! Connect to a source with about 15-18 volts, via a resistor to limit the current, and watch the voltage on the battery. It should eventually drop (when cut off at something less than 15V if it's a "12V" LFP), and then the voltage on the resistor should drop to zero (no current). A smart charger such as the iMax B6 can serve for the test, tell it the battery has 5 LFP cells in series ("15V" battery), limit the current to 0.1A, and watch what happens.
Last year I bought an "energized outside" brand (since renamed) LFP battery.. When I charge it with my B6 smart charger, the BMS cuts out at about 14.4V, a bit earlier than the B6 would stop the charge at about 14.6V. As a result, the B6 yells at me about the battery being disconnected, and I can't see what the total amphours charge was. Minor annoyance. At least I know that that battery has a high-voltage cutoff.
And another LFP battery I recently bought, PowerSync brand, shuts itself off when it tries to start up the motor in an electric mower I am using it in.. (Actually two 12V batteries in series.) The initial current surge is somewhat over the 20 amps peak that this battery allows. I solved that problem by adding a longish spool of wire in series with the motor to serve as extra resistance (0.3 ohms) to limit that current surge. And now I know that that BMS really does have an over-current shut-off.
  #33
Old June 3rd 20, 04:02 AM posted to rec.aviation.soaring
MNLou
I'm with Dan. I'm running Bioenno batteries and am very happy with them. 2 are 4 years old and work like new.
YMMV -
Lou
  #34
Old June 3rd 20, 01:35 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
On Tuesday, June 2, 2020 at 10:09:21 AM UTC-7, Eric Greenwell wrote:
Richard Pfiffner wrote on 6/2/2020 9:26 AM:
Dave
Were they Bioennos with a BMS that protects against overvoltage? For example, I
use the BLF-1220AS, which ....
"Includes built-in PCM (protection circuit module) which provides internal cell
balancing and management, protection from overcurrent, undervoltage
(overdischarge), overvoltage and short circuiting, and has integrated charging
circuitry "
I haven't tried applying 24 volts to it, but I'd expect it to protect against 24
VDC being applied to it. I've just emailed Bioenno this question, but have not
heard back.
Eric,
I don't know about the BMS. All I know is Bioenno supplied the batteries with a 24 volt charger. When the batteries were charged they were destroyed. Bioenno replaced the batteries and chargers although it took a long time to get the replacements.
Richard
  #35
Old June 3rd 20, 02:11 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Richard Pfiffner wrote on 6/3/2020 5:35 AM:
Dave
circuitry "
heard back.
Eric,
Richard
I emailed this question to Bioenno:
"Does the BLF-1220AS protect itself if a charger for a 24 volt Bioenno is
connected to it?"
Their answer:
"The BLF-1220AS can only accept a charging voltage from 13.8VDC to 15.3VDC. If
you exceed 15.3VDC, the BMS will trip and the battery shuts off. However, high
voltage should not be left attached continuously to the battery which can cause
permanent damage to the BMS/cells. If the voltage is less than 13.8VDC, the
battery will charge, but not be 100% charged.
-Kevin"
I don't consider 24 volts (or the likely charging voltage of 28 volts) to be a
"high voltage", but it sounds like leaving a 24 volt charger applied to a 12 volt
Bioenno battery will damage the battery after a while. So, while the battery does
protect itself in the short term, neither the battery nor the charger indicate
that there is a problem. Since the battery can be hidden from view, I think the
charger should be smart enough to indicate it's been connected to the wrong
battery AND it should disconnect itself. The Bioenno charger does neither,
unfortunately.
If you do connect the 24 volt charger to the 12 volt battery, the LED indicator
(all it has) will show GREEN, indicating the battery is fully charged, instead of
RED, your expectation to indicate it is charging. Too subtle, I think.
  #36
Old June 3rd 20, 08:06 PM posted to rec.aviation.soaring
  #37
Old June 3rd 20, 09:12 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
wrote on 6/3/2020 12:06 PM:
Dave
circuitry "
heard back.
Eric,
Richard
connected to it?"
Their answer:
-Kevin"
unfortunately.
The battery does not "know" that it is connected to a 24V charger. The battery itself should clamp the voltage to a value consistent with it's state-of-charge. If a 24V charger is able to deliver current at the relatively low voltage of the 12V battery, then current will flow and the battery will absorb this current, charge, and reach the BMS cutoff voltage at which time the overcharge protection FET should open. The voltage across the battery terminals will then be 24V but with no current flow since the FET is open. The internal battery cell cluster will not "see" this high voltage but portions of the BMS circuit will. This 24V "may" damage the BMS if it is not rated for it. There may be some small leakage current through the overcharge FET which may get through to the inner cell cluster which, over a (very, very) long period of time, damage the cells.
Danny Brotto
Perhaps I wasn't clear. I want to the battery to have an LED indicator that
announces it has shut off the battery due to an overvoltage. And definitely shut
off - not clamp the voltage. It doesn't matter what is supplying the high voltage.
I also want the 24 volt battery charger to shut off it's output if it doesn't
detect a 24 volt battery on it's output, and have an LED indicator to show that's
why it shut off. I very much do not want a 24 volt charger to attempt charging
anything but a 24 volt battery.
  #38
Old June 3rd 20, 09:50 PM posted to rec.aviation.soaring
I have recently moved from my still good, 8 year old K2 to the rated 9 amp version of these PowerSonic Iron Phosphate batteries:
https://www.power-sonic.com/batterie...etooth-series/
I am very happy with it so far. My tester shows that at a 1 amp discharge rate I'm getting 10.3 Amp Hours. The battery has over/under voltage protection although I have not tested the feature. The app (Android only) is very useful providing SOC, voltage, current measurement in/out, number of discharge cycles, individual cell voltage readings, and battery use event errors (over/under voltage, etc.) It works great. I am able to insure that starting the flight I'm at 100% SOC (well, 99% because I know that my charger slightly undercharges.) After 5 hours of use I'm down to 60% very consistently. The Bluetooth system is TI-based and I believe that the BMU is also TI-based. It is a tremendous value for what you get.
Danny Brotto
  #39
Old June 3rd 20, 11:19 PM posted to rec.aviation.soaring
kinsell
they were
quite open about not having a BMS.Â* Unfortunately they're in
Chapter 7
voltage
protection.Â* Richard Pfiffner one time was testing batteries, and
his
batteries.Â* All
the white stuff leaked out of the battery.Â* Some electrical
genius on
trigger it.
transponder on, and ruined the battery.Â* A 15-20 AH battery
intended as
applications.Â* You
when
charged from another charger.Â* Did it have a BMS?Â* Doesn't really
matter.
Dave
For example, I
internal cell
integrated charging
circuitry "
protect against 24
but have not
heard back.
Eric,
I don't know about the BMS.Â* All I know is Bioenno supplied the
they were destroyed.Â* Bioenno replaced the batteries and chargers
Richard
Bioenno is
connected to it?"
Their answer:
15.3VDC.Â* If
However, high
can cause
permanent damage to the BMS/cells.Â* If the voltage is less than
13.8VDC, the
-Kevin"
volts) to be a
to a 12 volt
battery does
indicate
think the
wrong
neither,
unfortunately.
indicator
charged, instead of
email me)
Danny Brotto
that announces it has shut off the battery due to an overvoltage. And
definitely shut off - not clamp the voltage. It doesn't matter what is
doesn't detect a 24 volt battery on it's output, and have an LED
indicator to show that's why it shut off. I very much do not want a 24
volt charger to attempt charging anything but a 24 volt battery.
My first priority would be to have an overvoltage circuit that performs
as you would reasonably expect it to, along with clear specs such as
"withstands 50 volt continuous voltage on the terminals with no damage"
and "withstands 20 volt reverse voltage on the terminals". Many smart
chargers will refuse to try to charge a backwards connected battery, but
not all of them.
EaarthX makes LFP's for experimental and certified aircraft, and they do
have an error output that drives an LED and/or an EFIS system to warn of
problems like a weak cell. They require that this info be provided to
the pilot in flight.
I was a little confused by Danny's answer, he seems to be confusing how
he thinks the Bioenno batteries should work, rather than how they
actually DO work. This after the vendor confirmed they can't withstand
continuous overvoltage, and Richard dramatically demonstrated the
problem on a number of units. Fortunately Richard does 100% incoming
inspection on his batteries, and was able to catch the issue. Doesn't
speak well to the vendor's quality control. Maybe not as bad as
sprinkling metal shavings in the lithium-cobalt batteries, but still not
good.
-Dave
  #40
Old June 4th 20, 12:24 AM posted to rec.aviation.soaring
Dave,
The Bioenno site shows this 14.6V 2A charger to be the one recommended on their web site. I suspect the supplied 24V chargers were a QC issue in pack out; somebody packed 24V chargers with 12V batteries. Bioenno also sells 24V packs with a compatable charger.
https://www.bioennopower.com/collect...-to-dc-charger
Danny Brotto
NY Kart Endurance Challenge 3 Hour Race - Arrive & Drive OVRPNY Piloting 0 June 9th 05 11:18 PM
NY Kart Endurance 3 Hour Challenge Race - Arrive & Drive OVRPNY Owning 0 June 9th 05 11:17 PM
NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed OVRPNY Owning 1 May 19th 05 04:56 PM
NY Go Kart Endurance Racing - Arrive & Drive - No Experience Needed OVRPNY Piloting 0 May 19th 05 02:01 AM
Speeds for best range or endurance don't depend on altitude John T Lowry Piloting 5 April 16th 04 02:02 AM
