How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
Old June 9th 20, 11:09 PM posted to rec.aviation.soaring
Default How reliably do CG hooks disconnect when the angle of the ropeexceeds the autorelease angle
While inspecting, look for small (maybe 1/32 inch?) cracks.
That seems to happen before noticeable wear changes.
Old June 10th 20, 12:53 AM posted to rec.aviation.soaring
AS
On Tuesday, June 9, 2020 at 1:27:45 PM UTC-4, wrote:
A quick way is to only use a TOST ring set where you can still read (most) of the TOST part number stamped on the side of the small ring. With dimension change due to wear&tear, the part number will become unreadable.
This has the dual benefit of also ensuring you are being hooked up with a proper TOST ring set and not a home made or repaired set.
PS- Remind me to take a calipers out to the airfield next visit and validate a suspect worn ring’s dimensions. Thanks, whoever posted the spec dims.
Welcome!
Uli
'AS'
Aluminum angle Lou Home Built 11 June 25th 07 11:57 PM
Blue Angle #3 Elmshoot Naval Aviation 10 May 24th 04 10:35 PM
Another angle... tongaloa Home Built 0 February 27th 04 11:13 PM
The Dan Rather Angle Dude Owning 7 January 18th 04 09:10 PM
Angle of climb at Vx and glide angle when "overweight": five questions Koopas Ly Piloting 16 November 29th 03 10:01 PM
