VNE vs altitude: glider specs vs rules of thumb
Old June 10th 20, 09:47 PM posted to rec.aviation.soaring
cdeerinck
Default VNE vs altitude: glider specs vs rules of thumb
Mike - VNE should not change based on Wing Loading, so ballast should not affect it.
I'm pretty sure both of the units you measured calculate TAS.
My LX9070 actually has an Overspeed warning, and it is calibrated to go off based on TAS.
Don't ask me how I found this out.
Old June 11th 20, 01:51 AM posted to rec.aviation.soaring
Mike N.
So the S80 does have an alert for VNE.I assume at calculated TAS.
So I'm looking to put in the VNE alert with a safety factor of 85 to 90% of POH specified VNE
Old June 11th 20, 04:00 PM posted to rec.aviation.soaring
Dan Marotta
Flying a glider at or near Vne is pretty risky given that we fly most
often in turbulent air.Â* Besides, your rate of descent increases more
rapidly the faster you go.Â* Better to do better final glide planning.
My 2 cents...
Dan, 5J
Old June 11th 20, 07:12 PM posted to rec.aviation.soaring
Mike N.
Agreed completely.
My primary reason for adding the VNE alert is when flying through areas of heavy sink.
Flying faster in sink is of course SOP in most cases.
So obviously as I fly faster through sink I will be seriously watching my airspeed, but having a secondary alert to my instrument scan while flying fast through sink, or even final glide, is an additional safety measure to help mitigate human errors.
Old June 16th 20, 11:08 PM posted to rec.aviation.soaring
Bret Hess
If you're interested in knowing more about the science behind the protocol, a very good paper is "Critical Flutter Speed of Sailplanes Calculated
for High Altitude: Examples of computation" by Wojciech Celcstyn, 1993, a featured article in Technical Soaring: https://journals.sfu.ca/ts/index.php...e/view/216/200.
Fig 1 top half shows shaded flutter region for one oscillation mode and the dashed line how one would enter it flying fast enough IAS at 2000m (EAS and IAS are the same for glider speeds). If you flew at higher altitudes you would enter it at a lower speed, given by the parabolic looking curve going upward to the left, which gives the true altitude change of IAS-VNE flutter. The real change is NOT given by constant TAS, but the TAS line is shown for comparison. It's simply a convenient line that has enough slope so it will keep you out of danger in most cases.
The other figures show other modes. If you read the conclusion, it's clear that the standard (German and everyone else I guess) VNE protocol is not based on knowing where flutter is, either by testing or calculation. It's based on testing to a certain altitude and finding no flutter. Then IAS-VNE is chosen to drop off as TAS is held constant to stay away from unknown flutter at higher altitudes.
Old June 16th 20, 11:23 PM posted to rec.aviation.soaring
Bret Hess
I don't fly above VNE and don't plan to. But I hear that the most aggressive racing pilots do, often as their average speed! This makes some sense now because VNE is simply based on the testing altitude chosen, not knowledge of flutter (see my post just above this).
So you aggressive racing pilots, you are basically test pilots. Do you share the velocity and height space you've explored without flutter? Or do you just see how fast others with your same model fly? We could define new faster IAS-VNE plots for your model based on your experience.
Old June 17th 20, 07:47 PM posted to rec.aviation.soaring
Steve Koerner
Not so. Racing pilots have no competitive motive to fly above Vne. Decades ago there was a potential motive to do so when optical start gates were in use. That all ended when GPS came on the scene.
Perlan GLIDER ALTITUDE: 52004 ft Tom Kelley #711 Soaring 15 September 5th 17 03:54 PM
Rules for Logging Glider PIC Time Markus Graeber Soaring 7 January 8th 12 12:30 AM
Rules of Thumb for Cross-Country Flying Roy Clark, \B6\ Soaring 1 October 17th 08 01:42 PM
Glider Altitude (Record?) over Mt. Everest [email protected] Soaring 2 January 19th 06 02:26 PM
Best Glider for Altitude Record Attempt? Jerome Conners Soaring 24 December 17th 03 10:54 AM
