On Sunday, June 14, 2020 at 10:38:04 PM UTC-4, Mike N. wrote:
I'd like to do some light repairs on my S.H. Ventus Ct. With original finish in very good condition. I just want to clean up a couple of areas of light hanger rash. Some light dings and chips. I've read several articles on Gel Coat repairs, but would like to get a good idea on the best gel coat to order for this type of work. Thank you, Mike N.http://www.simteccoatings.com/Productlist.ivnu |
On Monday, June 15, 2020 at 8:15:21 AM UTC-4, KG wrote:
On Sunday, June 14, 2020 at 10:38:04 PM UTC-4, Mike N. wrote: I'd like to do some light repairs on my S.H. Ventus Ct. With original finish in very good condition. I just want to clean up a couple of areas of light hanger rash. Some light dings and chips. I've read several articles on Gel Coat repairs, but would like to get a good idea on the best gel coat to order for this type of work. Thank you, Mike N.http://www.simteccoatings.com/Productlist.ivnu Order 2481 and catalyst from Simtec. UH |
![]() Order 2481 and catalyst from Simtec. UH Interesting, the instructions say before applying to wipe down with slow evaporating lacquer thinner or IPA (Isopropyl Alcohol). instead of acetone. |
On Monday, June 15, 2020 at 9:20:56 AM UTC-4, wrote:
Order 2481 and catalyst from Simtec. UH Interesting, the instructions say before applying to wipe down with slow evaporating lacquer thinner or IPA (Isopropyl Alcohol). instead of acetone. Water and very fine sandpaper will get contaminants off and proved tooth for new material. Every solvent I've tried smears contaminants and provides no assurance of a good surface to bond to. Just one guy's experience. UH |
Wipe down with IPA???Â* I'd rather drink it! :-D
On 6/15/2020 7:20 AM, wrote: Order 2481 and catalyst from Simtec. UH Interesting, the instructions say before applying to wipe down with slow evaporating lacquer thinner or IPA (Isopropyl Alcohol). instead of acetone. -- Dan, 5J |
If your near SE Georgia USA I have everything you need left over from refinishing XF I’ll give you for free. Pickup only though!
Lane Bush |
Thanks, I am in Utah.
How about I pay for shipping? Mike |
Agree on the Simtec 2781. The will include a flex additive to the paint if requested if painting bendy bits.
On Monday, June 15, 2020 at 4:18:39 PM UTC-6, Dan Marotta wrote:
Wipe down with IPA???Â* I'd rather drink it! :-D IPA is fine as beer, (India Pale Ale) but as IPA (isopropyl alcohol) it isn't. The label says, "For external use only. If taken internally, serious gastric disturbances will result." But then again, eight or ten India Pale Ales will also lead to serious gastric disturbances. |
gel coat | BobWa43 | Soaring | 54 | November 1st 19 08:20 PM |
Gel coat removal - is this okay?!? | Kevin Christner | Soaring | 13 | July 10th 15 03:44 PM |
Gel coat inspection | Matt Keast[_2_] | Soaring | 12 | October 26th 07 09:14 PM |
Gel Coat Question | Gary Emerson | Soaring | 2 | September 12th 07 11:56 AM |
Gel Coat for Dummies | Ray Lovinggood | Soaring | 2 | December 12th 04 08:15 PM |
