Wing tip wheels, one or several?
Old June 5th 20, 07:54 PM posted to rec.aviation.soaring
Default Wing tip wheels, one or several?
Our self-launch glider has downturned wing tips. From the factory, there was nothing more than a skid to make contact with the ground. Over time, people seem to have settled on putting a roller-blade wheel there, presumably because it dramatically improves ground handling. However, the wheel isn't very pretty and because of the drooped tips there's no way to install the wheel without it dramatically disturbing airflow.
I'm wondering if two small inline wheels could suffice to replace the one big one. In my mind, the advantage of a bigger wheel is reduced rolling resistance on uneven ground. However, inline wheels might close that efficiency gap, without having as large an effect on airflow.
Thoughts?
Old June 16th 20, 06:07 PM posted to rec.aviation.soaring
PGS
Thoughts?
A roller blade wheel is not that large, I'm surprised that it would "dramatically" disrupt airflow. Perhaps you are correct in theory, but many times theory is not proportional to practical reality.
Old June 16th 20, 07:20 PM posted to rec.aviation.soaring
Kenz Dale
That's fair. Let me specify that it dramatically disturbs local airflow. I doubt it really affects things 2m away.
In our case, they're really chunky wheels and they're actually mounted outboard of the wingtips. So they have an outsized effect vs. more standard approaches. This is what motivates the desire to change. I'm just guessing here, but I wonder if they don't have as large an impact as not properly taping seals.
ASW 27 wing tip wheels [email protected] Soaring 15 April 6th 20 01:52 AM
Junkers G.38 pics [06/12] - First prototype at Berlin Tempelhof Airport showing spatted tandem main wheels, the aileron section of the 'double wing' and—most unusually—retractable oil and water radiators.jpg (1/1) Miloch Aviation Photos 0 February 16th 18 03:11 PM
Cessna CitationJet/M2 pics [06/12] - CJ2 planform view, showing its straight wing and uncovered main wheels.jpg (1/1) Miloch Aviation Photos 0 January 2nd 18 03:26 PM
WTB 1-34 wing tip wheels [email protected] Soaring 1 March 4th 13 08:44 PM
FS: Wings&Wheels Wing Stand James Hamilton[_2_] Soaring 0 September 12th 09 01:15 AM
