On Tuesday, June 23, 2020 at 7:20:47 AM UTC-6, Dan Marotta wrote:
Once again Skylines.aero will not load on either of my computers. Has anyone else had this problem? -- Dan, 5J Try this https://brave.com/?ref=bvp360 Mike |
It's working again.Â* I just wiped the disk in my hangar computer and
loaded it with Ubuntu v. 20.Â* It's so very much better than Windows... On 6/23/2020 7:02 PM, Mike C wrote: On Tuesday, June 23, 2020 at 7:20:47 AM UTC-6, Dan Marotta wrote: Once again Skylines.aero will not load on either of my computers. Has anyone else had this problem? -- Dan, 5J Try this https://brave.com/?ref=bvp360 Mike -- Dan, 5J |
On Thursday, 25 June 2020 03:40:41 UTC+2, Dan Marotta wrote:
It's working again.Â* I just wiped the disk in my hangar computer and loaded it with Ubuntu v. 20.Â* It's so very much better than Windows.... -- Dan, 5J +1 If you find there are applications which only run on Windows you can run them in a Windows VM using Virtualbox, KVM, etc. without fiddling with Wine. Even Microsoft are moving towards Linux (WSL on Windows, Azure practically runs on Linux, etc.) |
At 05:37 25 June 2020, Surge wrote:
On Thursday, 25 June 2020 03:40:41 UTC+2, Dan Marotta wrote: It's working again.=C2=A0 I just wiped the disk in my hangar computer and= =20 loaded it with Ubuntu v. 20.=C2=A0 It's so very much better than Windows.= ...=20 --=20 Dan, 5J +1 If you find there are applications which only run on Windows you can run th= em in a Windows VM using Virtualbox, KVM, etc. without fiddling with Wine. = Even Microsoft are moving towards Linux (WSL on Windows, Azure practically = runs on Linux, etc.) I've had no success with Wine or Virtual Box to run LX Styler or indeed Garmin Express since only windows 10 dev versions are available. Older ran OK. If you know a good howto, please post a link. Thanks . (running Ubuntu 18.04.4 LTS) |
Skylines Trouble? | Dan Marotta | Soaring | 1 | June 15th 20 10:55 PM |
IOS App for Skylines? | Sean Fidler | Soaring | 29 | May 13th 15 01:49 PM |
skylines down? | Brad[_2_] | Soaring | 0 | April 28th 15 05:01 AM |
How are flights in SkyLines scored? | kirk.stant | Soaring | 2 | April 12th 14 08:43 AM |
SkyLines Updates | Tobias Bieniek | Soaring | 3 | April 24th 13 07:33 AM |
