"Peter" == Peter Stickney writes:
Peter Actually, it's fairly easy to see why - The Imperial Peter Japanese Navy was only so large - they didn't have enough Peter ships to be everywhere in the Pacific at once. /../ Peter /../ They could fly htier land-based bombers from their Peter forward based in Indochina and Formosa, but they'd arrive Peter without fighter escorts. The same, of course, would apply Peter to any sea-borne invasions force - no fighter cover, and Peter they'd be sitting ducks in the target area. Peter /../ One of the most closely held secrets if the IJN was Peter the unprecedented range of the A6M (Year Zero) Peter fighter. /../ Peter Much has been made of teh Zero's maneuverability as the key Peter to its success early in the war. /../ Sorry, but that's not true AFAIK: the fact that it came as a surprise to some of the Allies is not the same as the IJN keeping it a strict secret. The IJN never considered it secret, using it in China. Chennault wrote of this fighter in 1940 and 1941, and the Chinese certainly knew of this successor to the Type 96 'Claude'. -- G Hassenpflug * IJN & JMSDF equipment/history fan |
Gernot Hassenpflug writes: "Peter" == Peter Stickney writes: Peter Actually, it's fairly easy to see why - The Imperial Peter Japanese Navy was only so large - they didn't have enough Peter ships to be everywhere in the Pacific at once. /../ Peter /../ They could fly htier land-based bombers from their Peter forward based in Indochina and Formosa, but they'd arrive Peter without fighter escorts. The same, of course, would apply Peter to any sea-borne invasions force - no fighter cover, and Peter they'd be sitting ducks in the target area. Peter /../ One of the most closely held secrets if the IJN was Peter the unprecedented range of the A6M (Year Zero) Peter fighter. /../ Peter Much has been made of teh Zero's maneuverability as the key Peter to its success early in the war. /../ Sorry, but that's not true AFAIK: the fact that it came as a surprise to some of the Allies is not the same as the IJN keeping it a strict secret. The IJN never considered it secret, using it in China. Chennault wrote of this fighter in 1940 and 1941, and the Chinese certainly knew of this successor to the Type 96 'Claude'. The existance of the Zero wasn't a secret - the fact that the Japanese had built a single-engine fighter that could fly from Taipei to Manila and back was. That was certainly not apparent to anybody, and the IJN wasn't advertising that fact. A short range fighter with extremely high performance certainly wasn't unexpected - consider teh case of the Curtiss CW-21 "Demon" - a lightweight short-ranged interceptor that exceeded the A6M in climb and agility. The KNIL had a bunch of them in Java. Without the ability to be warned in time to get off the ground and into position, it didn't do them a bit of good. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Peter Stickney wrote:
In article , Gernot Hassenpflug writes: "Peter" == Peter Stickney writes: Peter Actually, it's fairly easy to see why - The Imperial Peter Japanese Navy was only so large - they didn't have enough Peter ships to be everywhere in the Pacific at once. /../ Peter /../ They could fly htier land-based bombers from their Peter forward based in Indochina and Formosa, but they'd arrive Peter without fighter escorts. The same, of course, would apply Peter to any sea-borne invasions force - no fighter cover, and Peter they'd be sitting ducks in the target area. Peter /../ One of the most closely held secrets if the IJN was Peter the unprecedented range of the A6M (Year Zero) Peter fighter. /../ Peter Much has been made of teh Zero's maneuverability as the key Peter to its success early in the war. /../ Sorry, but that's not true AFAIK: the fact that it came as a surprise to some of the Allies is not the same as the IJN keeping it a strict secret. The IJN never considered it secret, using it in China. Chennault wrote of this fighter in 1940 and 1941, and the Chinese certainly knew of this successor to the Type 96 'Claude'. The existance of the Zero wasn't a secret - the fact that the Japanese had built a single-engine fighter that could fly from Taipei to Manila and back was. That was certainly not apparent to anybody, and the IJN wasn't advertising that fact. One reason was that the Japanese were unaware that they had the capability until sometime in 1941. Clark and Iba were over 450nm from the closest Formosan bases, Manila was 500nm away. They'd never made attacks at such ranges in China, and they were flying over land there, where navigation was much easier. They'd originally planned to use three small carriers (the big ones were going to PH), but that was inconvenient as they were slow and unable to operate sufficient numbers of a/c (only 75 vs. the 250 or so Zeros they had assembled on Formosa and believed to be necessary). So in 1941, they started to see just how much they could safely stretch the fuel economy of the Zero, individually and then in larger groups. Ten hour missions became routine, then 11 and eventually they were able to stay in the air for 12. Okumiya describes this in "Zero!", with average fuel consumption dropping to 21 gal./hr. and Saburo Sakai holding the record at only 18 gal./hr. Guy |
in 1941, they started to see just how much they could safely stretch the fuel economy of the Zero, individually and then in larger groups. Ten hour missions became routine, then 11 and eventually they were able to stay in the air for 12. Okumiya describes this in "Zero!", with average fuel consumption dropping to 21 gal./hr. and Saburo Sakai holding the record at only 18 gal./hr. Interesting. The Wright R-2600 engine burned about 75gph at 60 percent power. Any details on how the Japanese achieved such frugal fuel consumption figures? What was "normal" fuel consumption for the Zero? Chris Mark |
Orval Fairbairn writes: In article , ost (Chris Mark) wrote: From: Guy Alcala in 1941, they started to see just how much they could safely stretch the fuel economy of the Zero, individually and then in larger groups. Ten hour missions became routine, then 11 and eventually they were able to stay in the air for 12. Okumiya describes this in "Zero!", with average fuel consumption dropping to 21 gal./hr. and Saburo Sakai holding the record at only 18 gal./hr. Interesting. The Wright R-2600 engine burned about 75gph at 60 percent power. Any details on how the Japanese achieved such frugal fuel consumption figures? What was "normal" fuel consumption for the Zero? Chris Mark They achieved thos numbers by cutting back to 20%-30% power and aggressive leaning. Lindbergh taught the same concepts to USAAF P-38 pilots -- this technique is part of what enabled the Yamamoto shootdown. The P-38s were operating way outside their expected normal combat radius. Y'know, that's been mentioned any number of times about Lindberg's trip to the Pacific. But I have some doubts about it. The Carbs used on the later model P-38s were Bendix-Stromberg PD 12 pressure carbs. IIRC, These didn't have manual adjustment - you had settings of "Full Rich", Auto-Rich", "Auto-Lean", and "Idle Cutoff". you couldn't manually lean the engines. The secret to a low fuel burn is low RPM/High BMEP. To get this, you need to crank the prop to the desired cruise RPM (Usually Full Decrease or thereabouts, set the throttle to the maximum setting that maintains that RPM, and pull the mixture back to Auto-Lean. If you've chosen the proper cruise altitude, you'll be chugging along at the minumum drag IAS (Speed for best climb), and what determines your endurance will be whether the relief tube's plugged. I suspect that that's wht Lindy really taught them. It's not a great condition to be in if you're bounced, however - you can't just shove teh throttle forward & go. A Big recip can be remarkably delicate at times, and just shoving the throttle forward at low revs with a lean mixture is asking it to come apart. To spool things up, you've got to do the hand-jive, shoving teh mixture to Full Rich first, the prop to Full Increase, and then you can bring up the power with the throttle. I can see somebody who's concerned about being bounced keeping the mixture up in the AUto-Rich range and just fiddling with the revs (Prop) and Manifold Pressure (Throttle). -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
In article , Orval Fairbairn writes: In article , ost (Chris Mark) wrote: From: Guy Alcala in 1941, they started to see just how much they could safely stretch the fuel economy of the Zero, individually and then in larger groups. Ten hour missions became routine, then 11 and eventually they were able to stay in the air for 12. Okumiya describes this in "Zero!", with average fuel consumption dropping to 21 gal./hr. and Saburo Sakai holding the record at only 18 gal./hr. Interesting. The Wright R-2600 engine burned about 75gph at 60 percent power. Any details on how the Japanese achieved such frugal fuel consumption figures? What was "normal" fuel consumption for the Zero? Chris Mark They achieved thos numbers by cutting back to 20%-30% power and aggressive leaning. Lindbergh taught the same concepts to USAAF P-38 pilots -- this technique is part of what enabled the Yamamoto shootdown. The P-38s were operating way outside their expected normal combat radius. Y'know, that's been mentioned any number of times about Lindberg's trip to the Pacific. But I have some doubts about it. The Carbs used on the later model P-38s were Bendix-Stromberg PD 12 pressure carbs. IIRC, These didn't have manual adjustment - you had settings of "Full Rich", Auto-Rich", "Auto-Lean", and "Idle Cutoff". you couldn't manually lean the engines. The secret to a low fuel burn is low RPM/High BMEP. To get this, you need to crank the prop to the desired cruise RPM (Usually Full Decrease or thereabouts, set the throttle to the maximum setting that maintains that RPM, and pull the mixture back to Auto-Lean. If you've chosen the proper cruise altitude, you'll be chugging along at the minumum drag IAS (Speed for best climb), and what determines your endurance will be whether the relief tube's plugged. I suspect that that's wht Lindy really taught them. Exactly right. They'd been cruising in auto-rich, low MP/high rpm. He told them to put it in auto-lean, pull the prop back to 1,800 rpm and then advance the throttle until they got 180mph IAS (they'd been cruising at higher speeds). It's not a great condition to be in if you're bounced, however - you can't just shove teh throttle forward & go. A Big recip can be remarkably delicate at times, and just shoving the throttle forward at low revs with a lean mixture is asking it to come apart. To spool things up, you've got to do the hand-jive, shoving teh mixture to Full Rich first, the prop to Full Increase, and then you can bring up the power with the throttle. I can see somebody who's concerned about being bounced keeping the mixture up in the AUto-Rich range and just fiddling with the revs (Prop) and Manifold Pressure (Throttle). The advantage of the late-war Pacific was that most of the time you were flying over uninhabited areas or the sea, so really didn't need to worry about getting bounced except in the vicinity of airfields. The Japanese lack of fuel also played a part. The details are in Lindbergh's wartime journal, but IIRR the increased radii guarantees he made to Kenney, or maybe it was Whitehead, included going to auto rich and (IIRC) combat cruise speed in the combat zone, which I think he defined as 100 miles both in and out, plus combat allowance, etc. The crews didn't necessarily believe him the first couple of missions, but when they noticed he was returning to base with 100-200 gallons more fuel than they while flying the same missions, they paid attention. Guy |
Chris Mark wrote:
From: Guy Alcala in 1941, they started to see just how much they could safely stretch the fuel economy of the Zero, individually and then in larger groups. Ten hour missions became routine, then 11 and eventually they were able to stay in the air for 12. Okumiya describes this in "Zero!", with average fuel consumption dropping to 21 gal./hr. and Saburo Sakai holding the record at only 18 gal./hr. Interesting. The Wright R-2600 engine burned about 75gph at 60 percent power. Any details on how the Japanese achieved such frugal fuel consumption figures? What was "normal" fuel consumption for the Zero? I have a vague memory of reading 30-35gal./hr. somewhere, but don't hold me to it. The A6M2 had the Sakae 12 engine, which was only rated at 950 hp or so. When they got the A6M3 Model 32 in the Solomons, which had the more powerful Sakae 21 engine of 1,130 hp (and slightly less fuel) plus clipped tips, they found that its range was inadequate to make it from Rabaul to Guadalcanal and back (it was pushing it for the A6M2), which IIRR was something like 550 sm one way. They built intermediate strips down the Solomons (Buin, etc) so that it could get there and back, and put the A6M3 Model 22 with increased internal fuel and the full wingspan (non-folding, like the first production model, the A6M2 Model 11) into production for land use. The USN found that for carrier operations, overall they could plan on R-2600s burning 45-50 gal./hr average per sortie (which includes lots of low speed loiter for landing and ASW patrol) depending on whether it was in an Avenger or a Helldiver, while the R-2800 in the Hellcat burned about 75 or so (same landing loiter, CAP loiter). The exact mix of sortie types flown would affect the average, but as far as planning for carrier AVGAS replenishment needs, that gave them good numbers. Guy |
Remember Pearl Harbor: Special Program Tonight at EAA | Fitzair4 | Home Built | 0 | December 7th 04 07:40 PM |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
