On Monday, July 6, 2020 at 6:38:46 AM UTC-7, wrote:
I have a v2Cx with 4 lift pins where the wings connect to the fuselage. These get cleaned and greased with white grease on each assembly. I'm noticing that the grease under the lift bearings gets squeezed out in flight. (Looks like maybe metal to metal contact.) Is there a preferred grease to use there. Maybe something with a graphite or moly fill? There are 2 prior threads that addressed this subject. Both are very informative. Check them out. https://groups.google.com/forum/?fromgroups#!searchin/rec.aviation.soaring/Red$20n$20tacky/rec.aviation.soaring/w78L5_PtszE/HCk8muk-AgAJ https://groups.google.com/forum/?fromgroups#!searchin/rec.aviation.soaring/Red$20n$20tacky/rec.aviation.soaring/WzrvfnwifrU/8aB5F6EmAgAJ |
Rigging grease recommendations for long-term-rigged gliders | Jim Hogue | Soaring | 19 | February 4th 20 03:29 PM |
Youth soaring program looking for wing wheel for large-chord wing | Jay[_2_] | Soaring | 1 | September 17th 14 02:44 AM |
Grease recommendation | Bastoune | Soaring | 20 | April 2nd 10 08:57 PM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
2.4 hours - no oil/grease on prop/windshield | Jay Honeck | Owning | 8 | September 30th 06 01:25 PM |
