Wood glider outdoor storage
Old July 11th 20, 04:11 PM posted to rec.aviation.soaring
Default Wood glider outdoor storage
Mice are nearly as much of a hazard as moisture. Even if completely protected from moisture if you don’t exclude mice completely they will ruin aircraft
Old July 12th 20, 02:13 AM posted to rec.aviation.soaring
Shouldn't make aircraft out of edibles. Or gnawables. No beavers in Moriarty, but we do have mice. And snakes.
I hang my glider from the ceiling. So far, it's worked fine
Old July 12th 20, 02:20 PM posted to rec.aviation.soaring
Even inedible metal can be ruined by mice. I have an Ercoupe wing in my shop with career ending corrosion on the main spar due to urine saturation from long term mouse nesting.
Old July 12th 20, 06:23 PM posted to rec.aviation.soaring
howard banks
But Mark your glider is made of genuinely inedible plastic. I thought the roof hanging bit was to give double use to a large slab of hangar floor?
Old July 12th 20, 06:30 PM posted to rec.aviation.soaring
Yes, that's one purpose. But hanging it also discourages the snakes. And the mice have to work harder.
Winter glider storage? soartech[_2_] Soaring 10 November 14th 11 07:49 PM
Preparing glider for storage Ben C Soaring 6 September 27th 11 02:13 AM
tube and fabric and outdoor storage Robert Loer Home Built 23 June 2nd 08 10:20 PM
wood in aircraft manufacturing, was First Glider stephanevdv Soaring 2 October 3rd 04 08:41 PM
Wood glider plans? Scott Soaring 4 January 18th 04 05:04 PM
