Ventus CM starting problems
Old July 13th 20, 11:37 PM posted to rec.aviation.soaring
Dave Nadler
Default Ventus CM starting problems
On Sunday, July 12, 2020 at 6:13:50 PM UTC-4, wrote:
...I have a voltage lost of aprox 2 volts over the positive wire
and 1.5 over the negative one.
That's a ENORMOUS voltage drop!
I never owned one of these beasts, but...
1) If you let it crank (or try) for a brief period,
the area dropping the voltage will heat up.
First expose as many as possible cables, connection points,
and relays. Then crank for a bit, and feel for hot spots.
You might be able to find problem areas quickly this way...
2) This beast is a kinda old. You've got most likely got bad
connections, maybe starter relay, and possibly cables.
Connection points corrode over time, especially if the beast
has lived in humid climates. Consider undoing, cleaning,
and reattaching ALL connection points.
3) You're absolutely on the right path looking for drops,
and obviously you see there's a horrible problem on both
high and 'ground' sides...
Hope that helps, and let us know what you find!
Best Regards, Dave
Ventus 2 ASI problems? John McLaughlin Soaring 4 February 15th 20 02:09 AM
Starting out the top [email protected] Soaring 4 November 9th 13 04:04 PM
Starting a 135 op? Dan[_1_] Piloting 32 February 22nd 08 02:13 PM
Just starting out... Jase Vanover Piloting 20 April 24th 05 08:23 PM
Starting FS9 Hector Relva Simulators 1 September 22nd 03 02:21 PM
