Ventus CM starting problems
Old July 15th 20, 12:11 AM posted to rec.aviation.soaring
Default Ventus CM starting problems
Dan, many times I connected car battery to glider battery with car battery emergency wires and the difference is very big. The starter "flies" and the engine starts very easily. I will try directly to the starter as you say. Thank you!
Old July 15th 20, 01:50 AM posted to rec.aviation.soaring
Lucas,
Try also to use only a car battery, without the glider battery.
Disconnect the wires from the glider battery and connect the wires to the car battery using the emergency cables.
See what happens.
Dan
Ventus 2 ASI problems? John McLaughlin Soaring 4 February 15th 20 02:09 AM
Starting out the top [email protected] Soaring 4 November 9th 13 04:04 PM
Starting a 135 op? Dan[_1_] Piloting 32 February 22nd 08 02:13 PM
Just starting out... Jase Vanover Piloting 20 April 24th 05 08:23 PM
Starting FS9 Hector Relva Simulators 1 September 22nd 03 02:21 PM
