On Thursday, August 30, 2018 at 4:46:35 AM UTC+2, Charlie Quebec wrote:
In the last east issue of Gliding Australia there is an incident report shown below. During the course of a cross country flight, the pilot elected to start the jet sustainer to self retrieve. The engine started normally, and the pilot tracked for the home airflield The engine failed catastrophically 830ft. AGL and a safe outlanding was conducted. Things that make you go hmmmm... I own and operate an EASA certified JS1 w/ an M&D jet sustainer engine in the Alps. I have found the system very reliable, but I don't trust it to save me from an outlanding or, worse, being trapped down low in an alpine valley. With one exception I kick myself for this very day, I have always started the engine within easy range of an airport. Often I'll start the motor earlier to avoid a situation where I am forced to fire it up down low, when my only option is a field. I am perhaps too prudent but I fly over some pretty nasty territory. Even when it looks flat, it's not. And the JS1-21m requires some care to land safely and short. The nicest thing about the jet vs. classical sustainer is this - if it does not start, you have almost 0% added drag with the thing hanging out the fuselage. The proof is in the pudding... Shortly after I received the beast, I fired up the motor before a cross-country flight to re-assure myself it would start. I usually don't let the automated system retract the motor when the EGT sensor says the hardware is 50C. I do that manually and usually wait for the equipment to cool to much lower tempertures before stowing it. I must have been distracted with ATC or something. I was flying around the Lyon TMA that day. I shut the engine system off withough retracting the engine. I managed for fly 650 km with the jet windmilling. I did not even notice. As for fuel, I usually use BP excellium and Cross T 2 stoke oil. I wish I could buy the Shell Gas-Diesel in my kneck of the woods. I've never noticed any start up issues related to altitude or temperature. Then again, I can't imagine any reason why I might start the beast up at 3000m. I can glide at least 100km on that without the motor. Yes, the mountains are high in the Alps but the valleys are quite low and the density of airports is more than adequate. I can imagine a high and hot start in South Africa or the Western US. Different conditions. A+ |
I've been digging around trying to find out what the process has been for pilots that have added jets other than the MD-TJ 42. This group seems to have a lot of knowledge on this niche subject. The jets are coming down in price and getting a lot more reliable to start, so it seems it would be a more considered option for a lot of pilots. Are there many self-installs, or are there a handful of companies that specialize in the retrofit?
On Monday, October 26, 2020 at 6:33:02 PM UTC-4, wrote:
I've been digging around trying to find out what the process has been for pilots that have added jets other than the MD-TJ 42. This group seems to have a lot of knowledge on this niche subject. The jets are coming down in price and getting a lot more reliable to start, so it seems it would be a more considered option for a lot of pilots. Are there many self-installs, or are there a handful of companies that specialize in the retrofit? You didn't say where in the world you are but for the US, Bob Carlton in Moriarty would be my first choice to call, if I wanted to have 'my ride pimped out' with a jet. Uli 'AS' P.S.: Bob - as soon as that lottery thing works out for me, I'll be giving you a call! ;-) |
I'm in the US and familiar with Bob. What he does is fantastic, but I'm more curious about some less expensive, less pimped out options. Everything I've seen of his so far uses PBS engines which are extremely expensive. The Jetcats and some other options are much more affordable and I know there are pilots that use them.. I'm wondering how they went about the retrofit.
mmm, on the RC side I'm not sure they are much better since I last posted on this thread couple years back. Since then: -bad egt probe -bad glow plug -newish turbine had stiction on the starter motor but if you could reach in and spin the bendix by hand it would start. -another with bad starter motor. But no catastrophies. Above were all fixable for a price. Darren |
I've been operating the microturbines for about 15 years (only up to the 90lb thrust class) and all those problems have been addressed for much more reliability. The EGT probe sheaths were switched to much higher temperature materials and were moved internal to avoid being deflected in any way that would fatigue the material to a point of breaking. The glow plugs were horrible and failed all the time. They used to be the ones used in RC nitro engines but are now ceramic and have proven to last way beyond multiple service intervals. The starter motors have transitioned from high friction brushed motors to virtually zero friction brushless. Same with the fuel pumps. I'm just addressing Darren's list but there are a lot of other improvements. The biggest issue I ever found consistently with starting the microturbines is variations in the atmospheric conditions that don't jive with the programmed start parameters which are set for a most likely "window" of conditions. But there are operator techniques to remedy even this scenario on the fly.
Obviously I'm biased toward the jets but always looking for the failure stories because it motivates me to figure out how the potential for those situations can be minimized. |
I'm actually reporting on turbines less than 5 years old and it was a ceramic "glow plug"(igniter) that failed. In the case of the Jetcat starter motor I was able to fix that myself which was nice.
Darren |
wrote on 10/26/2020 3:32 PM:
I've been digging around trying to find out what the process has been for pilots that have added jets other than the MD-TJ 42. This group seems to have a lot of knowledge on this niche subject. The jets are coming down in price and getting a lot more reliable to start, so it seems it would be a more considered option for a lot of pilots. Are there many self-installs, or are there a handful of companies that specialize in the retrofit? Chris Esselstyn has converted a Schreder glider and an ASW 27 to twin jet self-launch. You can probably find his contact info on the SSA website or the FAA aircraft registration lists. Both have flown successfully at Parowan during the annual motorglider event there. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On 10/26/20 9:39 PM, Eric Greenwell wrote:
wrote on 10/26/2020 3:32 PM: I've been digging around trying to find out what the process has been for pilots that have added jets other than the MD-TJ 42. This group seems to have a lot of knowledge on this niche subject. The jets are coming down in price and getting a lot more reliable to start, so it seems it would be a more considered option for a lot of pilots. Are there many self-installs, or are there a handful of companies that specialize in the retrofit? Chris Esselstyn has converted a Schreder glider and an ASW 27 to twin jet self-launch. You can probably find his contact info on the SSA website or the FAA aircraft registration lists. Both have flown successfully at Parowan during the annual motorglider event there. Chris posted extensively to the earlier version of this thread, 9/17/2018 he talked about his uncontained Jet Cat rear turbine wheel failure on his HP-18 conversion. Easy to find if you Google rec.aviation.soaring. That ship is Miss August 2021 if you have the new SSA calendar. Dave |
I really like what Chris has done and have reached out to him. What's on my mind is two 40kg class engines. You would have 175lbs of thrust, and in the event of one failing, you still have an adequate sustainer. I'm estimating the system would be around $25,000 (15k for the engines and 10k for the install). Where I am guessing entirely is the cost of the install, and if there would be enough room for two of this size engine. Two P300s are 10.5" wide next to each other, while two 40kg motors would be 11.5". So it seems they would fit in a lot of cases.
Interestingly, the P300 has a bit of a track record of catastrophic failure.. I'm sure there is an explanation out there as to why, but I followed many incident threads and I never found a definitive answer. There was speculation that the rotor sizing resulted in a resonant frequency that was causing stress on the bearings. |
Boyer retires - Catastrophic mission failure | Skylune | Piloting | 4 | July 9th 08 08:49 PM |
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports | BarneyFife | Piloting | 11 | December 8th 07 11:46 AM |
Study: High Risk of Catastrophic Runway Collisions in U.S. Airports | BarneyFife | Instrument Flight Rules | 0 | December 5th 07 08:15 PM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
