Is close_to_terrain slope and ridge soaring unavoidable in big mountain terrain in SW USA, or can you opt out and stay 1000+AGL when using ridge, thermal, wave, and convergence lift?
I did six hours of dual close_to_terrain slope soaring at Omarama in February largely to see if the risk/benefit made sense to me in a best case scenario where all factors (aircraft,pilot,terrain,weather) are top shelf. I understand that if you opt out of close_to_terrain soaring, you might also be opting out of the big OLC scores, and fly fewer days, but that's okay with me. |
son_of_flubber wrote on 7/21/2020 3:47 PM:
Is close_to_terrain slope and ridge soaring unavoidable in big mountain terrain in SW USA, or can you opt out and stay 1000+AGL when using ridge, thermal, wave, and convergence lift? I did six hours of dual close_to_terrain slope soaring at Omarama in February largely to see if the risk/benefit made sense to me in a best case scenario where all factors (aircraft,pilot,terrain,weather) are top shelf. I understand that if you opt out of close_to_terrain soaring, you might also be opting out of the big OLC scores, and fly fewer days, but that's okay with me. The situation we've been discussing is thermalling close to a mountain because that's where the thermals are, with the intent of getting above the ridge and thermalling higher. It's this need to stay in a small area (the thermal) that is the problem: you can use figure 8s, but that often doesn't keep you in the best lift. Wave soaring generally doesn't put you in that situation, as the wave forms downwind of the mountain; convergence also happens away from the mountain, so two air masses can interact. Slope soaring usually means you have a mostly steady wind against the slope, creating an updraft along the face of the mountain, so there is no need to circle. So, my experience is yes, most of the time I can stay safely away from the mountain. The most likely time I use thermals below the mountain top is right after launch, when I'm still low, and there aren't good thermals in the valley. High desert pilots in the southwest US tend to fly ABOVE the mountains, but New Zealanders (and pilots in some other mountainous areas) tend to fly AMONG the mountains. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Tuesday, July 21, 2020 at 7:18:33 PM UTC-4, Eric Greenwell wrote:
The situation we've been discussing is thermalling close to a mountain because that's where the thermals are, with the intent of getting above the ridge and thermalling higher. Does this happen often because the tops of the ridges in UT are higher than the typical aerotow? Are SW USA slopes steeper than NE USA slopes and would the thermals put you closer to terrain? According to an early post the accident happened on top of the ridge On Monday, July 13, 2020 at 1:08:32 AM UTC-4, 2G wrote: ...It is thought by another pilot that he was thermalling just above the ridge top and got blown to the lee (east) side of it and attempted to glide across to the windward side unsuccessfully. |
son_of_flubber wrote on 7/22/2020 10:03 AM:
On Tuesday, July 21, 2020 at 7:18:33 PM UTC-4, Eric Greenwell wrote: The situation we've been discussing is thermalling close to a mountain because that's where the thermals are, with the intent of getting above the ridge and thermalling higher. Does this happen often because the tops of the ridges in UT are higher than the typical aerotow? Are SW USA slopes steeper than NE USA slopes and would the thermals put you closer to terrain? According to an early post the accident happened on top of the ridge On Monday, July 13, 2020 at 1:08:32 AM UTC-4, 2G wrote: ...It is thought by another pilot that he was thermalling just above the ridge top and got blown to the lee (east) side of it and attempted to glide across to the windward side unsuccessfully. Generally, the ridges are a lot higher than an aerotow. Take look at a sectional for places like Minden, NV, Ely, NV, Parowan, UT, Nephi, UT. TAke a look at how steep the mountains are, but I'd say the big difference is the smaller ridges sticking out from the main ridge, so you don't get a relatively uniform sheet of air flowing over the main ridge. The thermals often form in the "bowls" between these minor ridges, so a circle is close to rocks over more of it's circumference. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
Ridge soaring barely exists in the Great Basin and most of western US. The terrain and wind does not favor ridge soaring. Occasionally at the end of the day after the thermal die we can extend the flight a little using ridge soaring. And even then it does not require hugging the terrain. These sort of crashes unfortunately happen when pilots get low below the terrain scratching for thermals or at the beginning of the day when looking for thermals near ridges. Usually it is not needed to get too close to terrain as the lift a little further is often better and easier to work. How close is too close depends on many factors.
Ramy |
BBF-109 CRASH | adelsonsl | Aviation Photos | 1 | May 30th 08 08:47 AM |
vampire or venom crash pic - wx904 crash.jpg (1/1) | [email protected] | Aviation Photos | 4 | January 1st 07 06:30 PM |
vampire or venom crash pic - wx904 crash.jpg (0/1) | [email protected] | Aviation Photos | 0 | December 30th 06 04:57 PM |
son of sam crash | houstondan | Piloting | 37 | July 1st 05 01:17 AM |
MiG-29 crash on take off | Iwan Bogels | Piloting | 9 | September 13th 04 05:35 PM |
