On Monday, July 27, 2020 at 9:45:05 AM UTC-7, Ian Wright wrote:
The wind direction/speed info on our butterfly vario is only working intermittently. When no direction and value is given it just shows WIND N/A. Sometimes it shows STILL AIR. All other functions seem to work just fine. Any ideas much appreciated? Is the inertial system working? Go to the AHRS page, far right. In the upper right hand corner there will be between none and 3 green dots. This is an indication of confidence in the stability of the inertial platform. You hope to see two or three. One or none is weak. If the inertial system is hosed, the wind indication will indicate N/A. |
Today after a long hiatus, my Butterfly vario was showing wind in 3 digits.
Now I did substitute a GPS antenna after the cable got mangled during the annual. The GPS position seems to be fine. |
FS Butterfly Vario | Ken | Soaring | 3 | January 13th 17 01:40 PM |
AA Butterfly versus CNv LCD wind calculation | [email protected] | Soaring | 103 | October 4th 16 04:12 AM |
Where are you Butterfly vario? | [email protected] | Soaring | 17 | May 25th 14 05:49 AM |
Butterfly Vario IGC | Richard[_9_] | Soaring | 3 | April 3rd 13 03:24 PM |
Airspeed Indication and Relative Wind | Scott Lowrey | Piloting | 24 | May 8th 04 08:20 PM |
