On Sun, 2 Aug 2020 13:40:28 -0700, Eric Greenwell
wrote: The tighter turn works for gliders after a rope break, so I'm thinking (as did Paul B), it would work for the P51 pilot. There is an optimum bank for minimizing the loss of altitude (and he did have some altitude). Had he turned tighter (about 40 degrees typically), he would have made it further around the turn than making a wide turn. Yes, initially he would be a bit lower, but his greater turn rate would more than compensates for that, and he can get back some of the that altitude when he stops turning and slows down. Hi Eric, From the video one can clearly see that his energy is barely enough to cross the extended center line, including the flare. Definitely not enough energy to make a turn, not to mention to drop the gear. Let's do some maths: When he started the turn to base leg he was between 250 and 350 ft AGL (depending on his altimeter settings) and 150 mph. P-51D stall speed clean: 100 mph, hence stall speed at 40 degreed bank: 114 mph . So, if he had flown a perfect approach at 120 MPH and 40 degrees of bank, he would have had a turn diameter of 2305 ft, resulting in a flight path distance of 3620 ft. Having an altitude of 350 ft AGL, this would have needed an L/D of 10.3, with 250 ft he would have needed 14.5. At 175 mph the L/D of the P-51D is 15:1, prop in high pitch. Close to the stall speed L/D is an estimated 30 percent less, hence 10:1. Propellor in low pitch will further reduce this number. I found no numbers on the influence of open cooling flaps. Let's assume an L/D of 10:1 for now (from the video probably a lot lower). Hence, the pilot might have had the chance to complete his turn if all his factors had been in his favour, but even under these circulstances he would not have had the energy to extend the gear. He didn't have the altitude to extend it over the runway after the turn, and extending it during the turn would have affected his L/D so much that a crash was unavoidable. If he had run out of energy (altitude and/or speed) in the last phase of the turn, he would have definitely crashed, directly in front of him the M-11 motorway, his flightpath still pointing at the thousands of spectators. Hardly survivable. Conclusion: This landing is a perfect example of getting one's priorities right: Fly the plane to a safe controlled landing instead of trying to get back to the airfield, risking a probably deadly crash if only the slightest thing goes wrong. Cheers Andreas |
"Conclusion:
This landing is a perfect example of getting one's priorities right" Yes, but only in the last 5 seconds of the flight. Right before he aborted the left hand turn, he was going to land on the strip. That was his plan. My point is that he should have turned before he reached the freeway. Not necessarily when it was all happening, I am aware of the pressure that he was under. However he clearly was desperate to make the runway and that mistake, to me, was a teaching moment. He did allude to the fact that a disabled aircraft is simply a tool dissipate energy, but did not discussed the fact that he was trying to reach the runway when he should not have. Also, Martin G, from the video and the topology, his downwind was to the south of the airfield, flying West to East (approx), otherwise a left hand turn could not take him across the freeway. And as you have noted there are no obstacles or crowds on that side. So he had choices. To reiterate, I am NOT discussing his performance during the event. I know nothing about flying P-51 etc. I am only discussing the debrief. Cheers Paul On Tuesday, 4 August 2020 10:34:35 UTC+10, Andreas Maurer wrote: On Sun, 2 Aug 2020 13:40:28 -0700, Eric Greenwell wrote: The tighter turn works for gliders after a rope break, so I'm thinking (as did Paul B), it would work for the P51 pilot. There is an optimum bank for minimizing the loss of altitude (and he did have some altitude). Had he turned tighter (about 40 degrees typically), he would have made it further around the turn than making a wide turn. Yes, initially he would be a bit lower, but his greater turn rate would more than compensates for that, and he can get back some of the that altitude when he stops turning and slows down. Hi Eric, From the video one can clearly see that his energy is barely enough to cross the extended center line, including the flare. Definitely not enough energy to make a turn, not to mention to drop the gear. Let's do some maths: When he started the turn to base leg he was between 250 and 350 ft AGL (depending on his altimeter settings) and 150 mph. P-51D stall speed clean: 100 mph, hence stall speed at 40 degreed bank: 114 mph . So, if he had flown a perfect approach at 120 MPH and 40 degrees of bank, he would have had a turn diameter of 2305 ft, resulting in a flight path distance of 3620 ft. Having an altitude of 350 ft AGL, this would have needed an L/D of 10.3, with 250 ft he would have needed 14.5. At 175 mph the L/D of the P-51D is 15:1, prop in high pitch. Close to the stall speed L/D is an estimated 30 percent less, hence 10:1. Propellor in low pitch will further reduce this number. I found no numbers on the influence of open cooling flaps. Let's assume an L/D of 10:1 for now (from the video probably a lot lower). Hence, the pilot might have had the chance to complete his turn if all his factors had been in his favour, but even under these circulstances he would not have had the energy to extend the gear. He didn't have the altitude to extend it over the runway after the turn, and extending it during the turn would have affected his L/D so much that a crash was unavoidable. If he had run out of energy (altitude and/or speed) in the last phase of the turn, he would have definitely crashed, directly in front of him the M-11 motorway, his flightpath still pointing at the thousands of spectators. Hardly survivable. Conclusion: This landing is a perfect example of getting one's priorities right: Fly the plane to a safe controlled landing instead of trying to get back to the airfield, risking a probably deadly crash if only the slightest thing goes wrong. Cheers Andreas |
On Mon, 03 Aug 2020 22:01:17 -0700, Paul B wrote:
Also, Martin G, from the video and the topology, his downwind was to the south of the airfield, flying West to East (approx), otherwise a left hand turn could not take him across the freeway. And as you have noted there are no obstacles or crowds on that side. So he had choices. Yes, you're right - after reviewing the start of the video a few times I now see that I was 180 out of sync. He was turning to base when he crossed the M.11, and then realised that he wasn't going to make the runway, which would have required crossing the road a second time and put it down parallel to road. -- Martin | martin at Gregorie | gregorie dot org |
On Mon, 3 Aug 2020 22:01:17 -0700 (PDT), Paul B
wrote: "Conclusion: This landing is a perfect example of getting one's priorities right" Yes, but only in the last 5 seconds of the flight. Right before he aborted the left hand turn, he was going to land on the strip. That was his plan. Indeed. And instead of trying to scratch into the field, he chose the safe option while he was still high and fast enough. My point is that he should have turned before he reached the freeway. Not necessarily when it was all happening, I am aware of the pressure that he was under. Even if he had started his turn earlier (in the middle of the downwind leg) he would not have had the engery to complete it and would have crashed into the fields south of the runway, still heading toward the crowd - and the row of parked GA aircraft (and their personnel) in the South of the runway. Not to mention that the remaining runway length - if he had been able to reach the airfield - was very close to the landing distance of a P-51. Overshooting the runway in a tail dragger and risking a somersault? Hmmm... Clear case: He made the best decision, without a doubt. Cheers Andreas p.s. And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field. |
"And of course there are a couple of other points to consider - for
example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field." Andreas, you cannot have it both ways, if indeed the engine delivered power for extra four or five seconds AND he turned early, than he would landed without an issue. Instead his plan, up to the time when he straightened to land, was to cross a busy highway twice. Cannot see that as the best decision. |
On Tuesday, August 4, 2020 at 11:47:29 PM UTC-7, Paul B wrote:
"And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field." Andreas, you cannot have it both ways, if indeed the engine delivered power for extra four or five seconds AND he turned early, than he would landed without an issue. Instead his plan, up to the time when he straightened to land, was to cross a busy highway twice. Cannot see that as the best decision. Again, I am not questioning what he did, simply saying that he could have addressed his desire to reach the runway of a normal circuit in the briefing. I am sure that not modifying a circuit as appropriate has killed many. Cheers Paul On Wednesday, 5 August 2020 at 12:51:20 am UTC+10, Andreas Maurer wrote: On Mon, 3 Aug 2020 22:01:17 -0700 (PDT), Paul B wrote: "Conclusion: This landing is a perfect example of getting one's priorities right" Yes, but only in the last 5 seconds of the flight. Right before he aborted the left hand turn, he was going to land on the strip. That was his plan. Indeed. And instead of trying to scratch into the field, he chose the safe option while he was still high and fast enough. My point is that he should have turned before he reached the freeway. Not necessarily when it was all happening, I am aware of the pressure that he was under. Even if he had started his turn earlier (in the middle of the downwind leg) he would not have had the engery to complete it and would have crashed into the fields south of the runway, still heading toward the crowd - and the row of parked GA aircraft (and their personnel) in the South of the runway. Not to mention that the remaining runway length - if he had been able to reach the airfield - was very close to the landing distance of a P-51. Overshooting the runway in a tail dragger and risking a somersault? Hmmm... Clear case: He made the best decision, without a doubt. Cheers Andreas p.s. And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field. I'm still waiting for anyone to describe just when a P51 has ever been used as a towplane. Tom |
On Wednesday, August 5, 2020 at 4:39:42 PM UTC-5, 2G wrote:
On Tuesday, August 4, 2020 at 11:47:29 PM UTC-7, Paul B wrote: "And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field." Andreas, you cannot have it both ways, if indeed the engine delivered power for extra four or five seconds AND he turned early, than he would landed without an issue. Instead his plan, up to the time when he straightened to land, was to cross a busy highway twice. Cannot see that as the best decision. Again, I am not questioning what he did, simply saying that he could have addressed his desire to reach the runway of a normal circuit in the briefing. I am sure that not modifying a circuit as appropriate has killed many.. Cheers Paul On Wednesday, 5 August 2020 at 12:51:20 am UTC+10, Andreas Maurer wrote: On Mon, 3 Aug 2020 22:01:17 -0700 (PDT), Paul B wrote: "Conclusion: This landing is a perfect example of getting one's priorities right" Yes, but only in the last 5 seconds of the flight. Right before he aborted the left hand turn, he was going to land on the strip. That was his plan. Indeed. And instead of trying to scratch into the field, he chose the safe option while he was still high and fast enough. My point is that he should have turned before he reached the freeway.. Not necessarily when it was all happening, I am aware of the pressure that he was under. Even if he had started his turn earlier (in the middle of the downwind leg) he would not have had the engery to complete it and would have crashed into the fields south of the runway, still heading toward the crowd - and the row of parked GA aircraft (and their personnel) in the South of the runway. Not to mention that the remaining runway length - if he had been able to reach the airfield - was very close to the landing distance of a P-51. Overshooting the runway in a tail dragger and risking a somersault? Hmmm... Clear case: He made the best decision, without a doubt. Cheers Andreas p.s. And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field. I'm still waiting for anyone to describe just when a P51 has ever been used as a towplane. Tom On a totally different note; turd in the punch bowl n. A person who spoils a pleasant social situation. This metaphor is powered by a particularly vivid contrast: the inviting sensory appeal of a festive beverage juxtaposed with the revolting suggestion of feculent contagion. Therefore, labeling someone a turd in the punch bowl is most appropriate when the individual's deleterious influence goes beyond mere faux pas or nuisance behaviors, and rises to the level of deliberate offense for its own sake. Consider that the literal act of depositing or excreting fecal matter into a communal food-service container would be sabotage. The punch bowl and the feces connote certain additional nuances. The former is a symbol of public community, as such dispensers are frequently encountered at parties where they become a focal point for interaction. Freud famously identified feces with aggression and the possessive instinct. Thus a turd in the punch bowl suggests rage toward, and / or the urge to conquer, a community or society as a whole. Defecating into a punch bowl is a very public act, in contrast with poisoning the well or laying an upper decker, which are generally surreptitious. In particular then, to be a turd in the punch bowl is to be a willful and attention-seeking obstructor to the success of a social community. |
Paul Bikle was retrieved by a P-51 in his 1-23 many decades ago....
On Wednesday, August 5, 2020 at 2:39:42 PM UTC-7, 2G wrote:
On Tuesday, August 4, 2020 at 11:47:29 PM UTC-7, Paul B wrote: "And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field." Andreas, you cannot have it both ways, if indeed the engine delivered power for extra four or five seconds AND he turned early, than he would landed without an issue. Instead his plan, up to the time when he straightened to land, was to cross a busy highway twice. Cannot see that as the best decision. Again, I am not questioning what he did, simply saying that he could have addressed his desire to reach the runway of a normal circuit in the briefing. I am sure that not modifying a circuit as appropriate has killed many.. Cheers Paul On Wednesday, 5 August 2020 at 12:51:20 am UTC+10, Andreas Maurer wrote: On Mon, 3 Aug 2020 22:01:17 -0700 (PDT), Paul B wrote: "Conclusion: This landing is a perfect example of getting one's priorities right" Yes, but only in the last 5 seconds of the flight. Right before he aborted the left hand turn, he was going to land on the strip. That was his plan. Indeed. And instead of trying to scratch into the field, he chose the safe option while he was still high and fast enough. My point is that he should have turned before he reached the freeway.. Not necessarily when it was all happening, I am aware of the pressure that he was under. Even if he had started his turn earlier (in the middle of the downwind leg) he would not have had the engery to complete it and would have crashed into the fields south of the runway, still heading toward the crowd - and the row of parked GA aircraft (and their personnel) in the South of the runway. Not to mention that the remaining runway length - if he had been able to reach the airfield - was very close to the landing distance of a P-51. Overshooting the runway in a tail dragger and risking a somersault? Hmmm... Clear case: He made the best decision, without a doubt. Cheers Andreas p.s. And of course there are a couple of other points to consider - for example the fact that the engine finally seized up just when he started his turn to final. If it had delivered power for another four, five seconds, he would have made it into the field. I'm still waiting for anyone to describe just when a P51 has ever been used as a towplane. Tom Tom this discussion has been helpful to point out there is a startle effect in any emergency. I have had multiple in flight emergencies (inflight fire, explosive decompression, throttle cable on twin came undone one short final (never covered that in any training), 90 degree flaps didn't 90 degrees....etc). Each event took a measurable amount of time to understand what was happening and how to respond. This discussion is directly applicable to soaring or any flight activity. This is why we practice 200 ft turn back and say 200 ft outbound on take offs. To lessen the startle effect and to have a plan without thinking. Hangar flying is the thing I miss most about not having a hangar now. Only a fool could not learn from another pilot's actions in an emergency. All soaring pilots are pilots. |
Lake Elsinore, 1-26 crash landing video | David Reitter | Soaring | 2 | July 13th 12 09:33 PM |
Short field landing Lake Providence LA (0M8) with ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | July 21st 09 12:06 AM |
South Lake Tahoe Class D | Ray | Piloting | 2 | May 15th 05 03:31 AM |
Lake Tahoe | Ross Richardson | Owning | 5 | March 28th 05 07:04 PM |
DONNER LAKE TAHOE 2005 TRUCKEE,CA PHOTOS | DONNER LAKE 2005 | Piloting | 3 | January 16th 05 08:06 AM |
