NOS needs a rather healthy mixture to begin with (As I recall it helps
with cooling)... NOS adds a bunch of heat to the engine, so no, it doesn't help with cooling. Basically, it's a safer way to add oxygen to the incoming air than injecting oxygen directly... so since the incoming air is now much more oxygen rich, you need a bunch more fuel, or your mixture will go very lean. In that sense, it's an alternative to turbocharging... but the NOS bottle will last a minute or so, OK for one takeoff... then what? :-) Paul, turbo Cardinal mode |
On Sat, 5 Jul 2003 01:06:22 -0700, "Paul Millner"
wrote: NOS needs a rather healthy mixture to begin with (As I recall it helps with cooling)... NOS adds a bunch of heat to the engine, so no, it doesn't help with cooling. Ummmm..no, that;'s not what I said. I said it requires a rather healthy mixture which helps with the cooling (need created by the NOS) Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) Basically, it's a safer way to add oxygen to the incoming air than injecting oxygen directly... so since the incoming air is now much more oxygen rich, you need a bunch more fuel, or your mixture will go very lean. In that sense, it's an alternative to turbocharging... but the NOS bottle will last a minute or so, OK for one takeoff... then what? :-) Paul, turbo Cardinal mode |
