wing tape
Old August 9th 20, 06:04 AM posted to rec.aviation.soaring
Ben Hirashima
Default wing tape
I've been using the wing tape sold by Craggy, but I'm not happy with it. It's very stretchy, which is good, but it sinks into the gaps that it's covering, which sort of defeats the purpose. Do the Bowlus or 3M tapes sink into the gap?
Old August 9th 20, 03:18 PM posted to rec.aviation.soaring
Dan Marotta
Default wing tape
I've used 3M white electrical tape when I was flying a single seater.Â*
It worked very well but, if left on for a long time (my ship was
hangared), it leaves a gummy residue when removed.Â* That's easy enough
to clean up with acetone or tape residue remover.
Dan, 5J
Old August 9th 20, 04:17 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default wing tape
Ben,
About your comment that, "...but it sinks into the gaps that it's covering, which sort of defeats the purpose." Why do you feel that the tape sinking into the gap between the wing root and the fuselage is something to be avoided?
To me the main purpose of wing tape is to seal the gap against air intrusion, not necessarily to continue the wing's airfoil without deformation. It seems that all wing tape "sinks" to one extent or another.
My $0.02.
Old August 10th 20, 05:02 PM posted to rec.aviation.soaring
Ben Hirashima
Default wing tape
On Sunday, August 9, 2020 at 8:17:11 AM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Ben,
My $0.02.
If the main purpose of wing tape is to seal against air intrusion, that problem could be better solved with a simple rubber gasket where the wing joins the fuselage.
It's just common sense that you would not want any departures from a smooth surface at the wing root. If you want to claim that it doesn't make a difference aerodynamically, then show me the data.
Old August 10th 20, 06:59 PM posted to rec.aviation.soaring
Tim Taylor
Default wing tape
The best tape is the 3M 483, but the price has gotten so out of hand that it is hard to justify. It will not sink in as much as the other tapes. One option is to make some thin mylar covers that you tape over with the softer tape. This will prevent the tape from sinking into the gap.
I still have a few rolls of 483 that use only when I can’t use something else. I have been researching alternatives and looking to buy some to test.
3M white electrical tape is what I use for anything that doesn’t need 483.
Old August 10th 20, 08:28 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default wing tape
Why is this the best?????
Michael Opitz
Default wing tape
hand that
i=
One=
softe=
r tape. This will prevent the tape from sinking into the gap. =20
I still have a few rolls of 483 that use only when I can=E2=80=99t
use
some=
buy some
t=
o test.=20
doesn=E2=80=99t
ne=
ed 483.
One of our club members was a master machinist and came up with
the idea to slice the 1" 483 tape into 1/2" rolls in order to double
the amount of uses one could get from an expensive roll of that
tape. Unfortunately, he passed away, but beforehand had cut me
about 15 rolls of it. It lasted me for years, but as I finally neared
the end of my supply, I Googled the 483 tape and looked for
equivalents from sources other than 3M. I found something similar,
but just a little stiffer, on a closeout in 2" x 60!! yard rolls which I
bought and had another club machinist slice into 4 x 1/2" - 60!!
yard rolls. Due to its length, one roll will go for a long time. I
probably have 20 or 30 rolls left, so if you want to try one, send me
an email. $10 + shipping. Pics at:
https://photos.app.goo.gl/deSxU1mUj7XctTXY7
RO
Old August 11th 20, 01:26 PM posted to rec.aviation.soaring
Don Grillo[_2_]
Default wing tape
My question is, With Wing and tail tape on why do I get a very loud howling when I Fly faster than 90 knots. And get no howling if I don’t tape the wings and tail.?
LAK17a/18.
I don’t mean to hijack this thread.
Old August 11th 20, 01:48 PM posted to rec.aviation.soaring
Tango Eight
Default wing tape
LAK17a/18.
90% of the time this is a loose tape edge on lower wing root, 6 - 12" in front of trailing edge. Inspect with pocket knife or similar after flight. It may still look sealed.
T8
Old August 9th 20, 04:40 PM posted to rec.aviation.soaring
Default wing tape
Ben,
The Craggy tape is the exact same as Bowlus.
Richard
Wing Tape Craig[_2_] Soaring 0 May 5th 11 05:09 PM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Wing Tape - Does Thickness Affect Performance? Charles McLaurin Soaring 2 January 30th 07 06:00 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
