wing tape
Old August 10th 20, 08:28 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Default wing tape
On Monday, August 10, 2020 at 10:59:48 AM UTC-7, Tim Taylor wrote:
The best tape is the 3M 483, but the price has gotten so out of hand that it is hard to justify. It will not sink in as much as the other tapes. One option is to make some thin mylar covers that you tape over with the softer tape. This will prevent the tape from sinking into the gap.
I still have a few rolls of 483 that use only when I can’t use something else. I have been researching alternatives and looking to buy some to test.
3M white electrical tape is what I use for anything that doesn’t need 483.
Why is this the best?????
  #42
Old August 11th 20, 01:26 PM posted to rec.aviation.soaring
Don Grillo[_2_]
Default wing tape
My question is, With Wing and tail tape on why do I get a very loud howling when I Fly faster than 90 knots. And get no howling if I don’t tape the wings and tail.?
LAK17a/18.
I don’t mean to hijack this thread.
  #43
Old August 11th 20, 01:48 PM posted to rec.aviation.soaring
Tango Eight
Default wing tape
LAK17a/18.
90% of the time this is a loose tape edge on lower wing root, 6 - 12" in front of trailing edge. Inspect with pocket knife or similar after flight. It may still look sealed.
T8
  #44
Old August 13th 20, 05:07 AM posted to rec.aviation.soaring
ProfJ
Default wing tape
On Sunday, 9 August 2020 at 17:10:32 UTC-6, wrote:
Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require.
Also much thicker.
Gaffer tape is designed specifically not to leave glue residue behind when removed (specifically useful eg. in the film industry, where tape has to be applied to carpets, clothing, sets etc.). It's basically less-sticky duct tape. I wouldn't use it on a glider, unless you have a phobia about glue residue.
  #45
Old August 13th 20, 02:15 PM posted to rec.aviation.soaring
AS
Default wing tape
Also much thicker.
I put mine on two seasons ago and it hasn't come off yet. I guess it has something to do with good surface preparation as well.
Uli
'AS'
Wing Tape Craig[_2_] Soaring 0 May 5th 11 05:09 PM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
Wing Tape - Does Thickness Affect Performance? ContestID67 Soaring 87 February 1st 07 03:24 PM
Wing Tape - Does Thickness Affect Performance? Charles McLaurin Soaring 2 January 30th 07 06:00 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
