SSA Sailplane Tracker
Old August 31st 20, 01:25 AM posted to rec.aviation.soaring
2G
Default SSA Sailplane Tracker
On Sunday, August 30, 2020 at 2:30:04 PM UTC-7, Tim Newport-Peace wrote:
At 18:08 30 August 2020, 2G wrote:
On Sunday, August 30, 2020 at 9:00:36 AM UTC-7, Martin Gregorie wrote:
On Sun, 30 Aug 2020 06:35:48 -0700, Bill Tisdale wrote:
I cannot get glideportaero to load this morning 8/30/2020. Both Link
from SSA Sailplane Tracker or directly to the glideportaero url. No
response, too long to load, error messages. Any ideas?
If your PC has the ping and traceroute commands installed, try them to
see if/where there's a network problem. IIRC they are standard issue for
Windows and definitely for Linux. Dunno about Apple kit. They are run
from the command line. In case you haven't used them:
Both are run from the command line:
ping glideport.aero
shows success or failure at contacting the URP you give it.
traceroute glideport.aero
shows every step along the way from you to the URL on success and
otherwise shows where the fault lies and what the fault is.
You don't need these programs all the time, but they are very useful in
working out whether a connection is broken and if so, where.
Martin | martin at
Gregorie | gregorie dot org
I tried traceroute, but that command is not supported under Win10. Ping
is,
and I got 4 reasonable responses. The IP address for glideport.aero is
http://107.170.23.252/. When I enter that in the search bar I get
connected
to glideport.aero.
Tom
Use tracert not traceroute
A better one is https://www.pingplotter.com/download
Tom
SSA Sailplane Tracker Nick Kennedy Soaring 2 August 17th 14 12:46 AM
GliderPort/Sailplane Tracker instructions (for contest staff)? noel.wade Soaring 1 July 1st 13 03:20 AM
Sailplane Tracker oddness/bug (15-m and Open Nats) noel.wade Soaring 10 June 27th 13 10:57 PM
SSA Sailplane Tracker problem Grider Pirate Soaring 7 April 11th 10 02:22 PM
SSA Creates National Sailplane Tracker List - Free to SSA Members Frank[_12_] Soaring 16 October 11th 09 05:42 AM
