On Sat, 05 Jul 2003 03:54:46 GMT, "Lynn Coffelt"
wrote: very early T-38's used hydraulic powered "ailerons" on the main landing gear doors to help retract the main gear in flight. The wing was so thin that there wasn't much room for conventional retraction mechanism. Seemed to work OK, but later models found room for conventional mechanism. Did it use a shrink scheme to retract the oleo strut while the gear retracted??? Been a while! JSC, which flies T-38Bs, used the part of the MLG door on the gear to increase the drag so they could chase the Orbiter. It had a spring normally or something and they fixed it in place. If I knew where my SETP proceedings were, I'd dig it out. The paper was by John McBride and Dick Grey. It was probably given in about '79 or so. Mary -- Mary Shafer Retired aerospace research engineer "Turn to kill, not to engage." LCDR Willie Driscoll, USN |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Military Aviation | 11 | July 8th 03 03:30 AM |
