Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good
Scottish single malt whisky. Your working progress will benefit. At 02:05 09 September 2020, Richard Pfiffner wrote: On Tuesday, September 8, 2020 at 6:30:53 PM UTC-7, wro= te: On Tuesday, September 8, 2020 at 9:14:39 PM UTC-4, wro= te: Only used two boxes of band-aids on my fingers and drank two bottles of= good Cuban rum. So, can we assume that the R/B ratio of one bottle of rum to one box of= Band-Aids can be used as a measure of performance? Try three bottles of ru= m and report back with the results. If you end up needing a tourniquet, ple= ase let us know. Mark, the ratio is consistent with the measure of pain! I liken this orde= al to a couple of other projects that I have tackled in the past, I basical= ly said to myself ,"What the hell did I do this for". The tourniquet sugges= tion is a great idea, not sure that it would stop the flow, but certainly w= ould prolong the suffering.=20 On to the next step in this ordeal, will be building back up with filler = and primer and on to the final coat or two or three of acrylic urethane the= n sanding down to 3000 grit and buffing, I might need more rum. If a low number grit does not easily take off the hard finish use a finer g= rit until it cuts easily then move to a 80 or 65 grit. An electric grinder= with adjustable speed is what I have used. In my opinion an orbital is no= t needed. Use no pressure on the sander let the paper cut. http://www.craggyaero.com/ventus.htm Richard www.craggyaero.com |
On Wednesday, September 9, 2020 at 4:45:06 AM UTC-4, Colin Roney wrote:
Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good Scottish single malt whisky. Your working progress will benefit. At 02:05 09 September 2020, Richard Pfiffner wrote: On Tuesday, September 8, 2020 at 6:30:53 PM UTC-7, wro= te: On Tuesday, September 8, 2020 at 9:14:39 PM UTC-4, wro= te: Only used two boxes of band-aids on my fingers and drank two bottles of= good Cuban rum. So, can we assume that the R/B ratio of one bottle of rum to one box of= Band-Aids can be used as a measure of performance? Try three bottles of ru= m and report back with the results. If you end up needing a tourniquet, ple= ase let us know. Mark, the ratio is consistent with the measure of pain! I liken this orde= al to a couple of other projects that I have tackled in the past, I basical= ly said to myself ,"What the hell did I do this for". The tourniquet sugges= tion is a great idea, not sure that it would stop the flow, but certainly w= ould prolong the suffering.=20 On to the next step in this ordeal, will be building back up with filler = and primer and on to the final coat or two or three of acrylic urethane the= n sanding down to 3000 grit and buffing, I might need more rum. If a low number grit does not easily take off the hard finish use a finer g= rit until it cuts easily then move to a 80 or 65 grit. An electric grinder= with adjustable speed is what I have used. In my opinion an orbital is no= t needed. Use no pressure on the sander let the paper cut. http://www.craggyaero.com/ventus.htm Richard www.craggyaero.com Thanks for the suggestion Colin, I could never forgive myself for drinking Scottish Whiskey, I would be contributing to the Kennedy dynasty and for that I could never forgive myself. Rum is much better, we call it the juice of the Caribbean gods, many a pirate sailed these blue waters while indulging it that fine roasted sugar cane fermented nectar. I will keep your suggestion in mind just in case the rum gets too depleted. Bob |
I think he meant, use the Scotch to strip the gelcoat. That might work...
On Wed, 09 Sep 2020 08:27:30 -0700, dtarmichael wrote:
I think he meant, use the Scotch to strip the gelcoat. That might work... Scotch is a bit smooth for that: use Hokonui, a bootleg spirit that used to be (and maybe still is) brewed and distilled in the deep south of the South Island, NZ. Rough as guts, traditionally sold in brown glass beer bottles with a label showing an atomic mushroom cloud. It'll strip anything, not just stomach linings. -- Martin | martin at Gregorie | gregorie dot org |
On Wed, 09 Sep 2020 04:06:05 -0700, wrote:
On Wednesday, September 9, 2020 at 4:45:06 AM UTC-4, Colin Roney wrote: Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good Scottish single malt whisky. Your working progress will benefit. At 02:05 09 September 2020, Richard Pfiffner wrote: On Tuesday, September 8, 2020 at 6:30:53 PM UTC-7, wro= te: On Tuesday, September 8, 2020 at 9:14:39 PM UTC-4, wro= te: Only used two boxes of band-aids on my fingers and drank two bottles of= good Cuban rum. So, can we assume that the R/B ratio of one bottle of rum to one box of= Band-Aids can be used as a measure of performance? Try three bottles of ru= m and report back with the results. If you end up needing a tourniquet, ple= ase let us know. Mark, the ratio is consistent with the measure of pain! I liken this orde= al to a couple of other projects that I have tackled in the past, I basical= ly said to myself ,"What the hell did I do this for". The tourniquet sugges= tion is a great idea, not sure that it would stop the flow, but certainly w= ould prolong the suffering.=20 On to the next step in this ordeal, will be building back up with filler = and primer and on to the final coat or two or three of acrylic urethane the= n sanding down to 3000 grit and buffing, I might need more rum. If a low number grit does not easily take off the hard finish use a finer g= rit until it cuts easily then move to a 80 or 65 grit. An electric grinder= with adjustable speed is what I have used. In my opinion an orbital is no= t needed. Use no pressure on the sander let the paper cut. http://www.craggyaero.com/ventus.htm Richard www.craggyaero.com Thanks for the suggestion Colin, I could never forgive myself for drinking Scottish Whiskey, I would be contributing to the Kennedy dynasty and for that I could never forgive myself. Rum is much better, we call it the juice of the Caribbean gods, many a pirate sailed these blue waters while indulging it that fine roasted sugar cane fermented nectar. I will keep your suggestion in mind just in case the rum gets too depleted. Bob Do the Kennedy Clan still have dibs on that post-Prohibition money- spinner? Enquiring minds want to know. -- Martin | martin at Gregorie | gregorie dot org |
On Wednesday, September 9, 2020 at 11:40:09 AM UTC-4, Martin Gregorie wrote:
On Wed, 09 Sep 2020 04:06:05 -0700, wrote: On Wednesday, September 9, 2020 at 4:45:06 AM UTC-4, Colin Roney wrote: Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good Scottish single malt whisky. Your working progress will benefit. At 02:05 09 September 2020, Richard Pfiffner wrote: On Tuesday, September 8, 2020 at 6:30:53 PM UTC-7, wro= te: On Tuesday, September 8, 2020 at 9:14:39 PM UTC-4, wro= te: Only used two boxes of band-aids on my fingers and drank two bottles of= good Cuban rum. So, can we assume that the R/B ratio of one bottle of rum to one box of= Band-Aids can be used as a measure of performance? Try three bottles of ru= m and report back with the results. If you end up needing a tourniquet, ple= ase let us know. Mark, the ratio is consistent with the measure of pain! I liken this orde= al to a couple of other projects that I have tackled in the past, I basical= ly said to myself ,"What the hell did I do this for". The tourniquet sugges= tion is a great idea, not sure that it would stop the flow, but certainly w= ould prolong the suffering.=20 On to the next step in this ordeal, will be building back up with filler = and primer and on to the final coat or two or three of acrylic urethane the= n sanding down to 3000 grit and buffing, I might need more rum. If a low number grit does not easily take off the hard finish use a finer g= rit until it cuts easily then move to a 80 or 65 grit. An electric grinder= with adjustable speed is what I have used. In my opinion an orbital is no= t needed. Use no pressure on the sander let the paper cut. http://www.craggyaero.com/ventus.htm Richard www.craggyaero.com Thanks for the suggestion Colin, I could never forgive myself for drinking Scottish Whiskey, I would be contributing to the Kennedy dynasty and for that I could never forgive myself. Rum is much better, we call it the juice of the Caribbean gods, many a pirate sailed these blue waters while indulging it that fine roasted sugar cane fermented nectar. I will keep your suggestion in mind just in case the rum gets too depleted. Bob Do the Kennedy Clan still have dibs on that post-Prohibition money- spinner? Enquiring minds want to know. -- Martin | martin at Gregorie | gregorie dot org Martin, I do believe that the Kennedy clan still gets royalties on every bottle of Scotch whiskey imported to this country. Just recently a Kennedy was finally defeated for political office in Mass, what took those people so long. Maybe that Kennedy could come on down and help sand gelcoat now that he is out of work. |
On Wed, 09 Sep 2020 12:49:27 -0700, wrote:
On Wednesday, September 9, 2020 at 11:40:09 AM UTC-4, Martin Gregorie wrote: On Wed, 09 Sep 2020 04:06:05 -0700, wrote: On Wednesday, September 9, 2020 at 4:45:06 AM UTC-4, Colin Roney wrote: Rum? Can`t stand it. It`s like drinking liquid rubber. Why not try a good Scottish single malt whisky. Your working progress will benefit. At 02:05 09 September 2020, Richard Pfiffner wrote: On Tuesday, September 8, 2020 at 6:30:53 PM UTC-7, wro= te: On Tuesday, September 8, 2020 at 9:14:39 PM UTC-4, wro= te: Only used two boxes of band-aids on my fingers and drank two bottles of= good Cuban rum. So, can we assume that the R/B ratio of one bottle of rum to one box of= Band-Aids can be used as a measure of performance? Try three bottles of ru= m and report back with the results. If you end up needing a tourniquet, ple= ase let us know. Mark, the ratio is consistent with the measure of pain! I liken this orde= al to a couple of other projects that I have tackled in the past, I basical= ly said to myself ,"What the hell did I do this for". The tourniquet sugges= tion is a great idea, not sure that it would stop the flow, but certainly w= ould prolong the suffering.=20 On to the next step in this ordeal, will be building back up with filler = and primer and on to the final coat or two or three of acrylic urethane the= n sanding down to 3000 grit and buffing, I might need more rum. If a low number grit does not easily take off the hard finish use a finer g= rit until it cuts easily then move to a 80 or 65 grit. An electric grinder= with adjustable speed is what I have used. In my opinion an orbital is no= t needed. Use no pressure on the sander let the paper cut. http://www.craggyaero.com/ventus.htm Richard www.craggyaero.com Thanks for the suggestion Colin, I could never forgive myself for drinking Scottish Whiskey, I would be contributing to the Kennedy dynasty and for that I could never forgive myself. Rum is much better, we call it the juice of the Caribbean gods, many a pirate sailed these blue waters while indulging it that fine roasted sugar cane fermented nectar. I will keep your suggestion in mind just in case the rum gets too depleted. Bob Do the Kennedy Clan still have dibs on that post-Prohibition money- spinner? Enquiring minds want to know. -- Martin | martin at Gregorie | gregorie dot org Martin, I do believe that the Kennedy clan still gets royalties on every bottle of Scotch whiskey imported to this country. Just recently a Kennedy was finally defeated for political office in Mass, what took those people so long. Maybe that Kennedy could come on down and help sand gelcoat now that he is out of work. :-) -- Martin | martin at Gregorie | gregorie dot org |
ASW24 - electric valve system | Norbert Gulczynski | Soaring | 1 | January 25th 15 01:13 PM |
1998 ASW24 water bag leak where bag meets PVC valve | Barny | Soaring | 2 | April 4th 11 04:57 AM |
ASW24 Left aileron needed | Barny | Soaring | 0 | October 18th 10 12:09 AM |
Looking to Purchase used ASW24 Right Aileron | Robert Fidler | Soaring | 0 | August 3rd 07 09:11 PM |
Waterbags for the ASW24 | Udo Rumpf | Soaring | 0 | October 4th 03 03:54 PM |
