LAK 12 Polar
Old September 9th 20, 10:53 PM posted to rec.aviation.soaring
Paul Remde
Default LAK 12 Polar
Hi,
Does anyone have a copy of the Dick Johnson report on the LAK 12 sailplane? I'm trying to access it to get a polar to enter into a customer's new LXNAV S80 variometer. The SSA web site shows the document, but the flash player is not currently working in any web browser. Has anyone downloaded it previously? I called the SSA and they said they don't currently have access to it either.
Thanks,
Paul Remde
Old September 9th 20, 11:26 PM posted to rec.aviation.soaring
http://www.airlomba.net/download.php?fileID=aftelak12
On Wednesday, September 9, 2020 at 4:53:31 PM UTC-5, Paul Remde wrote:
Hi,
Thanks,
Paul Remde
Old September 9th 20, 11:33 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Someone emailed the Dick Johnson LAK 12 Flight Test Evaluation document to me. I'm all set. Thank you Michael!!!
Best Regards,
Paul Remde
________________________________
Hi,
Thanks,
Paul Remde
Old September 10th 20, 02:39 AM posted to rec.aviation.soaring
FYI to all regarding the Flash Player requirement on the SSA website for reading the Johnson reports. You can down load the full issues in PDF or some other format that doesn't require Flash Player. Then, just skip to your page, not as fast but works in a pinch.
Doug
W24
Old September 10th 20, 02:57 AM posted to rec.aviation.soaring
Doug
W24
How do you get to the PDF download button without the Flash player? I tried looking around the SSA Soaring Mag archive page now hoping to find a way to download issues, but no luck.
Old September 10th 20, 05:57 AM posted to rec.aviation.soaring
Mike Reid
I found that if you do a Soaring Archive Search, the search results offer the option of a PDF download. There may be an easier way, but I haven't found it.
Mike
Old September 10th 20, 02:29 PM posted to rec.aviation.soaring
Mike
Thank you! I now see that if you get a link through the other parts of the archive, e.g., the "Johnson Reports" page, it looks like this:
https://www.ssa.org/archive/ViewIssu...nth=07&Page=30
If you edit that URL to delete "View", then it becomes a link that downloads the PDF. For example edit the above to:
https://www.ssa.org/archive/Issue.as...nth=07&Page=30
Old September 10th 20, 08:03 PM posted to rec.aviation.soaring
Colin Roney
Paul The Lak 12 polar is as near as dammit to a Nimbus2A/B. Same span and
wing section.
At 21:53 09 September 2020, Paul Remde wrote:
Hi,
sailplane?=
LXN=
play=
it
acces=
s to it either. =20
Thanks,
Paul Remde
Old September 12th 20, 06:13 AM posted to rec.aviation.soaring
Frank Whiteley
On Wednesday, September 9, 2020 at 3:53:31 PM UTC-6, Paul Remde wrote:
Hi,
Thanks,
Paul Remde
As Flash is deprecated, you have to allow it in your browser. There will be not support for Flash in most browsers after the end of the year. There is a project underway to convert, before the end of the year, the archive viewer to HTML5 and still keep the archive word searchable, consistently up to date, and hopefully useful in other ways.
Frank Whiteley
ASH 25M Polar [email protected] Soaring 0 November 24th 17 10:03 AM
What Polar Dan[_13_] Soaring 5 April 19th 12 06:06 AM
LX-Polar Program GM Soaring 6 September 24th 08 04:27 AM
K8 Polar Mike Schumann Soaring 2 July 22nd 06 04:10 PM
Looking for ASW-15B polar with weight [email protected] Soaring 3 April 24th 06 12:28 AM
