On Tuesday, September 15, 2020 at 11:25:21 PM UTC-7, Matthew Scutter wrote:
On Wednesday, September 16, 2020 at 4:07:16 AM UTC+2, 2G wrote: On Monday, September 14, 2020 at 11:54:00 PM UTC-7, Matthew Scutter wrote: On Tuesday, September 15, 2020 at 7:29:17 AM UTC+2, 2G wrote: On Monday, September 14, 2020 at 9:06:08 PM UTC-7, wrote: Hi Eric, I agree with you in principle, that for higher output powers, things must get bigger/heavier. However, I don't think this is the case here. The 2x batteries they use (datasheet below) are spec'd for ~40 kW discharge rate. The more realistic limiting factor might be how quickly they can dissipate heat from the batteries' internal resistance out of the battery compartment, but according to Matthew, this hasn't been a problem. http://www.front-electric-sustainer....% 20v1.25.pdf They would have to have a bigger inverter to handle the 40% higher input current when the batteries discharge from 4.2v-3.0v, but these ~20 kW class inverters weigh nothing (1-2 kg) compared to the batteries. https://www.mgm-compro.com/brushless...e-controllers/ I'd be interested to hear FES's reasoning, or other owners' experiences on why the power dropoff is so significant. Patrick Grady I am amazed that this is even being speculated upon. How hard is it to do FES climb performance runs? You simply take off and climb until the battery (or controller) shuts down. Then, you repeat this test 5-10 times. Then you repeat that test for a different glider. Why isn't this data readily available? I can only guess that this test has been done and it is not favorable to FES. There are many FES installations out there - if you have one, do this test and report the results. Tom Not readily available? It's in the flight manual. If I adjust for 5.3kWh vs 4kWh batteries and 350kg weight of the Diana 2, it's ~2000m, which matches my napkin math from partial runs. As for why owners haven't tried it - it sounds boring... 5.3.4 Powered flight performance 5.3.4.1 Rate of climb The maximum rate of climb is available only for a few minutes with fully charged battery packs. As battery voltage is reduced, the maximum achievable climb rate is lower. The average rate of climb depends mostly on the type of sailplane and its take-off weight. Maximum attainable altitude gain that in standard atmosphere conditions depends on the type of sailplane, its weight and aerodynamic qualities. To achieve the maximum altitude gain, use about 15kW of power. Do not use full power as the efficiency of the system is lower. Usually, 80-85 km/h is best for the climb with positive flap setting (the same setting as used while thermaling). Here are rough numbers: • 1600 m (5200 ft) for UL sailplanes at 300kg take-off weight, i.e. Silent 2 Electro • 1400 m (4500 ft) for the 18m class sailplanes at 400kg take-off weight (without water ballast), i.e. LAK17A FES • 1200 m (3900 ft) for the 18m class sailplanes at 450kg take-off weight (without water ballast); LAK17B FES, Ventus 2cxa FES, Discus 2c FES, HPH 304ES 5.3.4.2 Cruise flight The maximum range of powered cruising flight, without the water ballast, is around 100km (62 miles), depending on lift-sink conditions. The optimum cruise speed and flap position depend on the type of sailplane. Usually, it is about 90 km/h (48 kts) at around 3000-3300 RPM and 4kW of power with a positive flap setting, as used in thermals. And you REALLY believe that? If so, I've got a bridge for sale. No, I want to see the INDEPENDENT verification of this data. Tom Only on RAS do you get called biased or asked if you really believe your own experiences owning and operating - couldn't make it up if you tried. Regrettably my certification as an independent standards body is still processing. My only comment on the manuals data validity would be the 4kW is not applicable to all types, the cruising flight power estimate should be scaled like the climb altitude. The heavier HpH Sharks at eGlide this year told me they were cruising with 5-6kW. Oh, so you admit that the manual is wrong - my bad! Tom |
On Friday, 18 September 2020 at 03:16:19 UTC+1, 2G wrote:
On Tuesday, September 15, 2020 at 11:25:21 PM UTC-7, Matthew Scutter wrote: Only on RAS do you get called biased or asked if you really believe your own experiences owning and operating - couldn't make it up if you tried. Regrettably my certification as an independent standards body is still processing. My only comment on the manuals data validity would be the 4kW is not applicable to all types, the cruising flight power estimate should be scaled like the climb altitude. The heavier HpH Sharks at eGlide this year told me they were cruising with 5-6kW. Oh, so you admit that the manual is wrong - my bad! Tom Are you actually interested in this subject or not? A friend has a Ventus 2 with a FES I asked him about time or distance endurance, and I'm inclined to believe someone I've known for over 30 years, without needing certified statements from other witnesses, plus half their curriculum vitae, as suggested by some over-argumentative type on here. |
On Friday, September 18, 2020 at 2:16:26 AM UTC-7, andy l wrote:
On Friday, 18 September 2020 at 03:16:19 UTC+1, 2G wrote: On Tuesday, September 15, 2020 at 11:25:21 PM UTC-7, Matthew Scutter wrote: Only on RAS do you get called biased or asked if you really believe your own experiences owning and operating - couldn't make it up if you tried.. Regrettably my certification as an independent standards body is still processing. My only comment on the manuals data validity would be the 4kW is not applicable to all types, the cruising flight power estimate should be scaled like the climb altitude. The heavier HpH Sharks at eGlide this year told me they were cruising with 5-6kW. Oh, so you admit that the manual is wrong - my bad! Tom Are you actually interested in this subject or not? A friend has a Ventus 2 with a FES I asked him about time or distance endurance, and I'm inclined to believe someone I've known for over 30 years, without needing certified statements from other witnesses, plus half their curriculum vitae, as suggested by some over-argumentative type on here. I am VERY interested in this subject. You have me waiting with bated breath - what are your friend's results? Tom |
Thunderbird 4-ship departure - Thunderbirds 4 ship departure sun n fun 2010 (Custom).jpg | Glen in Orlando | Aviation Photos | 0 | April 22nd 10 09:10 PM |
F-104 Three Ship | Glen in Orlando | Aviation Photos | 0 | October 9th 09 07:00 PM |
T6 Formation flight with Ship to Ship and ATC COMS - Video | [email protected] | Piloting | 5 | September 10th 09 06:09 PM |
OT T6 Formation flight with Ship to Ship and ATC COMS - Video | A Lieberma[_2_] | Owning | 0 | September 10th 09 12:47 AM |
OT - T6 Formation flight with Ship to Ship and ATC COMS - Video | [email protected] | Instrument Flight Rules | 0 | September 10th 09 12:47 AM |
