On Thu, 24 Sep 2020 09:49:32 -0700, Steve Koerner wrote:
There is also one more mode of tracking that can also work at high bandwidth - phone tracking. Like other ground based systems it suffers dropouts (more so than ADS-b in my experience with it). The beauty of the phone tracking app is that it doesn't require expensive avionics. The phone tracking system seems to have lost favor. I'm not sure if it's still supported. Phones don't necessarily provide good coverage everywhe I've sat over the middle of Huntingdon, a market town 15 miles NW of Cambradge, at 3000-3200 ft and had exactly zero phone signal: The British telcos keep coverage as near-pancake-shaped as possible because that reduces the transmitter power bills and anyway they don't seem to think anybody needs to use a phone above 500ft or so. I expect its the same in Holland, Belgium and much of France. Is this also the case in the flatter parts of the USA? -- Martin | martin at Gregorie | gregorie dot org |
On Thursday, September 24, 2020 at 3:17:58 PM UTC-4, Martin Gregorie wrote:
On Thu, 24 Sep 2020 09:49:32 -0700, Steve Koerner wrote: There is also one more mode of tracking that can also work at high bandwidth - phone tracking. Like other ground based systems it suffers dropouts (more so than ADS-b in my experience with it). The beauty of the phone tracking app is that it doesn't require expensive avionics. The phone tracking system seems to have lost favor. I'm not sure if it's still supported. Phones don't necessarily provide good coverage everywhe I've sat over the middle of Huntingdon, a market town 15 miles NW of Cambradge, at 3000-3200 ft and had exactly zero phone signal: The British telcos keep coverage as near-pancake-shaped as possible because that reduces the transmitter power bills and anyway they don't seem to think anybody needs to use a phone above 500ft or so. I expect its the same in Holland, Belgium and much of France. Is this also the case in the flatter parts of the USA? -- Martin | martin at Gregorie | gregorie dot org My recent experience is that yes the phone app (IGCdroid) still works, and reasonably well. If you look later at the flight log as received by Glideport.aero you will usually see the whole flight in detail, same as looking at the IGC file collected within the phone. What is invisible (unless you watch the flight in real time on Glideport) is that the cell reception drops in and out. The acummulated data is sent once reception is restored. To see the dropouts I have used a macro text editor on the IGC files to leave only the last B record before each "LPLT::SND" line which denotes the app sending a data packet. The resulting IGC-like file can be looked at in software such as SeeYou and then you can see which areas did not have cell coverage in the air. I find that they are approximately repeated if you fly the same route again. And they differ when you fly in opposite directions along the same route (may be related to pilot's body blocking the signal in a certain direction). Generally the dropouts are on the order of 10-15 minutes, but sometimes longer, up to an hour, in our area (VT-NH, wooded, hilly, somewhat populated relative to Nevada, with the population often complaining about spotty cell coverage). It's possible I'd get better coverage if I'd put the cellphone in a better location in the cockpit, I've had it several inches behind my back. (No carbon fiber in my glider.) It's a lot of fun for spectating, and costs almost nothing, only requires a phone with data plan, not FLARM nor a transponder nor satellite-based devices (other than the phone's GPS reception). But for search and rescue the utility would be limited, since the last data packet may be sent many minutes, even an hour, before the crash or landout, as cell service is fairly likely to be lost once on the ground. I also carry a PLB, but would need to be able to activate it after the crash. Thus an OGN network, logging FLARM signals, if it were set up in our area (there is none so far), would be a useful complement. |
How to find an iPhone app similar to the app for Android phones, to work with Gliderport.aero?
SSA Sailplane Tracker | Nick Kennedy | Soaring | 2 | August 17th 14 12:46 AM |
GliderPort/Sailplane Tracker instructions (for contest staff)? | noel.wade | Soaring | 1 | July 1st 13 03:20 AM |
Sailplane Tracker oddness/bug (15-m and Open Nats) | noel.wade | Soaring | 10 | June 27th 13 10:57 PM |
SSA Sailplane Tracker problem | Grider Pirate | Soaring | 7 | April 11th 10 02:22 PM |
SSA Creates National Sailplane Tracker List - Free to SSA Members | Frank[_12_] | Soaring | 16 | October 11th 09 05:42 AM |
