As is the new LAK 17c FES https://www.youtube.com/watch?v=rxe6DIfPKb4
More prop clearance, 16s batteries and higher max RPM for 2.5 m/s climb rate. The angle of attack of the wing is smaller, back to what it was on the 17a (vs the 17b that was based on the fuselage of the LAK 19) These gliders are sustainers only. Looks like the Silent 2 is rated for self-launch. As is the miniLak FES, also a 13.5M glider. It works well for them because they are lighter than the 18M gliders. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Monday, October 12, 2020 at 3:18:05 PM UTC-5, Mana wrote:
As is the new LAK 17c FES https://www.youtube.com/watch?v=rxe6DIfPKb4 More prop clearance, Looks like keeping the tail down is interesting at 1:30 in the video. What does the POH ask you to do with the stick? If you use it to hold down the tail and hit a bump, then how high can the tail bounce before entering lawn mower mode? Technically self launch, but with grass or tiger country, the tow line didn't look all that long and having the batteries full seems wise. |
Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud.
Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. |
On Friday, October 16, 2020 at 7:11:13 AM UTC-7, waremark wrote:
Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. I would like to know if it can even launch to 2,100 ft without the motor/controller overheating. Tom |
On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote:
Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier. That won't change between an electric vs petrol engine. The longer the propeller, the faster the tips move. |
On Friday, October 16, 2020 at 4:53:50 PM UTC-7, John Foster wrote:
On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote: Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier. That won't change between an electric vs petrol engine. The longer the propeller, the faster the tips move. My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can. Tom |
The CalAir A-9b, for instance...
On 10/16/2020 8:50 PM, 2G wrote: On Friday, October 16, 2020 at 4:53:50 PM UTC-7, John Foster wrote: On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote: Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier. That won't change between an electric vs petrol engine. The longer the propeller, the faster the tips move. My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can. Tom -- Dan, 5J |
To follow up, if my simple arithmetic is correct, a 94 inch propeller
spun at 2,700 rpm achieves a tip speed of about 1,107 feet per second.Â* According to NASA, 1,100 fps at sea level is the speed of sound.Â* At a typical summer density altitude of, say, 8,800' MSL, the CalAir's prop tips are supersonic. But I may have screwed up the math... On 10/17/2020 10:09 AM, Dan Marotta wrote: The CalAir A-9b, for instance... On 10/16/2020 8:50 PM, 2G wrote: On Friday, October 16, 2020 at 4:53:50 PM UTC-7, John Foster wrote: On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote: Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier.Â*Â* That won't change between an electric vs petrol engine.Â* The longer the propeller, the faster the tips move. My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can. Tom -- Dan, 5J |
Your math seems correct, but the speed of sound varies with temperature, and not pressure, so if your density altitude is 8800' because it is 90º F, then the speed of sound is 1252 fps and the tips are subsonic.
Mike |
On Saturday, October 17, 2020 at 9:16:27 AM UTC-7, Dan Marotta wrote:
To follow up, if my simple arithmetic is correct, a 94 inch propeller spun at 2,700 rpm achieves a tip speed of about 1,107 feet per second.Â* According to NASA, 1,100 fps at sea level is the speed of sound.Â* At a typical summer density altitude of, say, 8,800' MSL, the CalAir's prop tips are supersonic. But I may have screwed up the math... On 10/17/2020 10:09 AM, Dan Marotta wrote: The CalAir A-9b, for instance... On 10/16/2020 8:50 PM, 2G wrote: On Friday, October 16, 2020 at 4:53:50 PM UTC-7, John Foster wrote: On Friday, October 16, 2020 at 8:11:13 AM UTC-6, waremark wrote: Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud. Any idea what the endurance is of that aircraft? As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that. Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier.Â*Â* That won't change between an electric vs petrol engine.Â* The longer the propeller, the faster the tips move. My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can. Tom -- Dan, 5J What MG has such a prop? That is about 2.4m, 0.85m larger than the ASH26/31.. Tom |
Why Isn't Vx The Best Rate Of Climb? | RandyL | Piloting | 18 | September 28th 06 07:50 PM |
figuring Rate of Climb | Michael Horowitz | Home Built | 1 | June 19th 05 03:16 AM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Rate of climb | Dillon Pyron | Home Built | 3 | May 8th 04 01:08 PM |
Climb Rate for DG-600M | Steve B | Soaring | 5 | August 25th 03 08:17 AM |
