Velocity squared is NOT a distance. It's just nonsense.
Le mardi 20 octobre 2020 Ã* 18:54:01 UTC+2, Kenn Sebesta a écritÂ*: On Tuesday, October 20, 2020 at 12:02:17 PM UTC-4, Tango Whisky wrote: 40 kts corresponds to 20.58 m/s. (20.58 m/s) ^2/3 doesn't make any sense unit-wise, and the numerical result would be 7.36. My Ventus cM touches down at 40 kts and has a hydraulic disc brake which works pretty well. Stopping distance without hitting the nose on the ground (on grass) is 170 m. Ah, I see the problems. You've made a mistake in the order of operations AND I've made a typo. The exponential resolves before the division so it's not v^(2/3). However, even worse is the typo: the equation is (v^2)/12. Derivation is he https://gist.github.com/kubark42/61a...e0f6e7abefe643 Despite the typo, the calculation was correct for your plane 20^2/12 = 33.33m. Please do note that this calculation is meaningless beyond giving how much the tailwheel moment limits you to before you tip forward onto your nose. However, your real-world 170m distance supports my theory that for modern glass planes the limiting factor is not the weight distribution between the main and tail wheels. |
At 06:35 21 October 2020, Tango Whisky wrote:
Velocity squared is NOT a distance. It's just nonsense. Actually, v^2 is proportional to energy per unit mass. As is braking distance under constant braking force (unless your mass is changing, e.g. still dumping ballast). J. |
Beringer Disc Brake Kit for Schemm-Hirth gliders - experience and effectiveness? | WaltWX[_2_] | Soaring | 35 | October 20th 17 08:15 AM |
SZD-55 Wheel Brake Adjustment | WDM | Soaring | 2 | January 20th 11 09:25 AM |
looking for wheel/tire/brake | Brad[_2_] | Soaring | 1 | July 29th 10 02:56 AM |
SZD-55 Wheel Brake | David Pye[_2_] | Soaring | 4 | September 19th 07 03:10 AM |
SZD-55 Wheel Brake | David Pye[_2_] | Soaring | 0 | September 18th 07 06:01 PM |
