On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote:
On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' |
On Monday, October 26, 2020 at 11:47:54 PM UTC-4, AS wrote:
On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' Vas ist loss? Habenzie eine foto? |
On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' |
On Monday, October 26, 2020 at 10:47:54 PM UTC-5, AS wrote:
On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' Uli, Hook capacity up as normal. Hook TE probe to Static port on instrument, and ship's static port to Pitot port on instrument. TE is negative Pitot (for proper TE Compensation), and the airspeed portion doesn't care if pitot is higher or static is lower. It's all about the delta. Airspeed will read correctly in this configuration, and the vario is now TE compensated. Tested and verified in my Kestrel 19 just over a year ago. Steve Leonard |
On Wednesday, October 28, 2020 at 8:24:19 PM UTC-4, Steve Leonard wrote:
On Monday, October 26, 2020 at 10:47:54 PM UTC-5, AS wrote: On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' Uli, Hook capacity up as normal. Hook TE probe to Static port on instrument, and ship's static port to Pitot port on instrument. TE is negative Pitot (for proper TE Compensation), and the airspeed portion doesn't care if pitot is higher or static is lower. It's all about the delta. Airspeed will read correctly in this configuration, and the vario is now TE compensated. Tested and verified in my Kestrel 19 just over a year ago. Steve Leonard Hi Steve - thanks for the explanation! That makes sense but it was not how it was hooked up. It was plumbed according to the port designations, so I didn't trust the ASI indication. I replaced the Sollfahrtgeber with an early Cambridge vario soon after I got the ship and relied on the McCready ring for speed to fly. I still have the instrument around, though - cool mechanics! :-) Uli 'AS' |
On Wednesday, October 28, 2020 at 8:29:12 PM UTC-6, AS wrote:
On Wednesday, October 28, 2020 at 8:24:19 PM UTC-4, Steve Leonard wrote: On Monday, October 26, 2020 at 10:47:54 PM UTC-5, AS wrote: On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' Uli, Hook capacity up as normal. Hook TE probe to Static port on instrument, and ship's static port to Pitot port on instrument. TE is negative Pitot (for proper TE Compensation), and the airspeed portion doesn't care if pitot is higher or static is lower. It's all about the delta. Airspeed will read correctly in this configuration, and the vario is now TE compensated. Tested and verified in my Kestrel 19 just over a year ago. Steve Leonard Hi Steve - thanks for the explanation! That makes sense but it was not how it was hooked up. It was plumbed according to the port designations, so I didn't trust the ASI indication. I replaced the Sollfahrtgeber with an early Cambridge vario soon after I got the ship and relied on the McCready ring for speed to fly. I still have the instrument around, though - cool mechanics! :-) Uli 'AS' I have one on the shelf in the garage. Doubt it's serviceable. Frank Whiteley |
On Wednesday, October 28, 2020 at 9:29:12 PM UTC-5, AS wrote:
On Wednesday, October 28, 2020 at 8:24:19 PM UTC-4, Steve Leonard wrote: On Monday, October 26, 2020 at 10:47:54 PM UTC-5, AS wrote: On Monday, October 26, 2020 at 8:12:11 PM UTC-4, Dave Nadler wrote: On Monday, October 26, 2020 at 12:31:10 PM UTC-4, Nathan Lemmon wrote: ...you might need a SOLLFAHRTGEBER. H301 only, right? I had one of these in my H301 but took it out when TE became a 'thing'. The instrument had one Pitot port for the ASI, one Static pressure port for the Vario and one for the capacity. Not sure how the speed indicator's readout would be influenced if one would feed it TE as reference. Still, it is one neat conversation piece. ;-) Uli 'AS' Uli, Hook capacity up as normal. Hook TE probe to Static port on instrument, and ship's static port to Pitot port on instrument. TE is negative Pitot (for proper TE Compensation), and the airspeed portion doesn't care if pitot is higher or static is lower. It's all about the delta. Airspeed will read correctly in this configuration, and the vario is now TE compensated. Tested and verified in my Kestrel 19 just over a year ago. Steve Leonard Hi Steve - thanks for the explanation! That makes sense but it was not how it was hooked up. It was plumbed according to the port designations, so I didn't trust the ASI indication. I replaced the Sollfahrtgeber with an early Cambridge vario soon after I got the ship and relied on the McCready ring for speed to fly. I still have the instrument around, though - cool mechanics! :-) Uli 'AS' Well, if you hook it up as labeled, it works just fine. The vario is not TE compensated, though. The airspeed should have been correct. Sometimes, you have to think back and forth between MPH on the SFG, and Knots on your ASI. I have one sitting on my shelf, too, Frank. If you don't think yours doesn't work, you could always send it to Steve's Home for Wayward Glider Stuff. :-) Steve Leonard |
I have one sitting on my shelf, too, Frank. If you don't think yours doesn't work, you could always send it to Steve's Home for Wayward Glider Stuff. :-) Steve Leonard Steve - I have to correct myself he the TE was plumbed to Static and I think that will throw off the ASI. Uli 'AS' |
On Thursday, October 29, 2020 at 1:58:44 PM UTC-5, AS wrote:
Well, if you hook it up as labeled, it works just fine. The vario is not TE compensated, though. The airspeed should have been correct. Sometimes, you have to think back and forth between MPH on the SFG, and Knots on your ASI. I have one sitting on my shelf, too, Frank. If you don't think yours doesn't work, you could always send it to Steve's Home for Wayward Glider Stuff. :-) Steve Leonard Steve - I have to correct myself he the TE was plumbed to Static and I think that will throw off the ASI. Uli 'AS' Yes, that would through it off. Would read high by about 40%. If you have a spot in the panel, give it a go! STF would not be correct for the Caproni, but a cool addition to the panel! Steve Leonard |
On Friday, October 30, 2020 at 6:07:00 AM UTC-4, Steve Leonard wrote:
On Thursday, October 29, 2020 at 1:58:44 PM UTC-5, AS wrote: Well, if you hook it up as labeled, it works just fine. The vario is not TE compensated, though. The airspeed should have been correct. Sometimes, you have to think back and forth between MPH on the SFG, and Knots on your ASI. I have one sitting on my shelf, too, Frank. If you don't think yours doesn't work, you could always send it to Steve's Home for Wayward Glider Stuff. :-) Steve Leonard Steve - I have to correct myself he the TE was plumbed to Static and I think that will throw off the ASI. Uli 'AS' Yes, that would through it off. Would read high by about 40%. If you have a spot in the panel, give it a go! STF would not be correct for the Caproni, but a cool addition to the panel! Steve Leonard 80mm? |
Glasflugel Libelle H-301/-301B POH | thermalrider[_2_] | Soaring | 0 | December 6th 12 12:23 AM |
Attention US Standard Class Pilots | [email protected] | Soaring | 51 | February 13th 12 10:44 PM |
Attention Region 12 Pilots! | [email protected] | Soaring | 0 | January 4th 12 06:19 AM |
USA: Attention New York State Pilots | Tim Hanke | Soaring | 0 | June 28th 06 08:06 PM |
Attention French Pilots! | MK | Soaring | 1 | November 8th 04 06:10 PM |
